    JiGaBo0-forgotpasswd
    Padrão SCSI Error - USB..mass storage
    uso debian sarge(Testig)
    kernel: 2.6.8-1-386
    ao tentar montar o pendrive q comprei..
    # mount /dev/sda1 /mnt/pendrive/
    mount: /dev/sda1 is not a valid block device
    # mount -t vfat /dev/sda1 /mnt/pendrive/
    dei uma verificada...... descobri isto:
    alguem pode dar uma ajuda ??
    usb 3-6: New high speed USB device using address 7
    scsi3 : SCSI emulation for USB Mass Storage device
    vendor: USB 2.0 model: Flash Disk Rev: 0.00
    Type: Direct-Access ANSI SCSI revision: 02
    SCSI device sda: 2048000 512-byte hdwr sectors (1049)MB
    sda: assuming Write Enable
    sda: assuming drive cache: write through
    SCSI error: host 3 id 0 lun 0 return code = 8000002
    Sense class 7, sense error 0, extended sense 0
    /dev/scsi/host3/bus0/target0/lun0: p1
    Attached scsi removable disk sda at scsi3, channel 0, id 0, lun 0
    dando mais uma olhada verifiquei que minha usb tah trabalhando a 1.0.. meu pen drive.. eh USB 2.0 conforme visto em cima!.... eu li no manual da placa mae, e minha USB eh 2.0..... tah trabalhando a 1.0 nao sei pq... ae fika a pergunta.. como aumentar o speed dela...pra USB 2.0 ???????
    blackforc:/home/daniel# dmesg
    S
    Security Scaffold v1.0.0 initialized
    NET: Registered protocol family 16
    EISA bus registered
    PCI: PCI BIOS revision 2.10 entry at 0xfdb01, last bus=2
    PCI: Using configuration type 1
    mtrr: v2.0 (20020519)
    Uncovering SIS963 that hid as a SIS503 (compatible=0)
    Enabling SiS 96x SMBus.
    Linux Plug and Play Support v0.97 (c) Adam Belay
    ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
    RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
    serio: i8042 KBD port at 0x60,0x64 irq 1
    input: AT Translated Set 2 keyboard on isa0060/serio0
    EISA: Probing bus 0 at eisa0
    EISA: Detected 0 cards.
    NET: Registered protocol family 2
    IP: routing cache hash table of 2048 buckets, 16Kbytes
    TCP: Hash tables configured (established 16384 bind 32768)
    NET: Registered protocol family 8
    NET: Registered protocol family 20
    ACPI: (supports S0 S1 S4 S5)
    RAMDISK: cramfs filesystem found at block 0
    RAMDISK: Loading 4296 blocks [1 disk] into ram disk... done.
    VFS: Mounted root (cramfs filesystem) readonly.
    Freeing unused kernel memory: 204k freed
    vesafb: probe of vesafb0 failed with error -6
    Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
    ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
    SIS5513: IDE controller at PCI slot 0000:00:02.5
    SIS5513: chipset revision 0
    SIS5513: not 100% native mode: will probe irqs later
    SIS5513: SiS 962/963 MuTIOL IDE UDMA133 controller
    ide0: BM-DMA at 0xff00-0xff07, BIOS settings: hdaMA, hdbMA
    ide1: BM-DMA at 0xff08-0xff0f, BIOS settings: hdcMA, hddMA
    /dev/ide/host0/bus0/target0/lun0: p1 p2 p3 p4
    hdc: HL-DT-ST RW/DVD GCC-4521B, ATAPI CD/DVD-ROM drive
    ide1 at 0x170-0x177,0x376 on irq 15
    VFS: Can't find ext3 filesystem on dev hda3.
    VFS: Can't find ext2 filesystem on dev hda3.
    ReiserFS: hda3: found reiserfs format "3.6" with standard journal
    ReiserFS: hda3: using ordered data mode
    usbcore: registered new driver usbfs
    usbcore: registered new driver hub
    ohci_hcd: 2004 Feb 02 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
    ohci_hcd: block sizes: ed 64 td 64
    ACPI: PCI interrupt 0000:00:03.0[A] -> GSI 11 (level, low) -> IRQ 11
    ohci_hcd 0000:00:03.0: Silicon Integrated Systems [SiS] USB 1.0 Controller
    ohci_hcd 0000:00:03.0: irq 11, pci mem d08f8000
    ohci_hcd 0000:00:03.0: new USB bus registered, assigned bus number 1
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 3 ports detected
    ACPI: PCI interrupt 0000:00:03.1 -> GSI 5 (level, low) -> IRQ 5
    ohci_hcd 0000:00:03.1: Silicon Integrated Systems [SiS] USB 1.0 Controller (#2)
    ohci_hcd 0000:00:03.1: irq 5, pci mem d08fe000
    ohci_hcd 0000:00:03.1: new USB bus registered, assigned bus number 2
    hub 2-0:1.0: USB hub found
    hub 2-0:1.0: 3 ports detected
    usb 2-2: new low speed USB device using address 2
    usbcore: registered new driver hiddev
    input: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:03.1-2
    usbcore: registered new driver usbhid
    drivers/usb/input/hid-core.c: v2.0:USB HID core driver
    ts: Compaq touchscreen protocol output
    mice: PS/2 mouse device common for all mice
    input: PC Speaker
    parport: PnPBIOS parport detected.
    parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
    inserting floppy driver for 2.6.8-1-386
    Floppy drive(s): fd0 is 1.44M
    FDC 0 is a post-1991 82077
    Linux agpgart interface v0.100 (c) Dave Jones
    agpgart: Detected SiS 746 chipset
    agpgart: Maximum main memory to use for agp memory: 203M
    agpgart: AGP aperture is 64M @ 0xd0000000
    cpci_hotplug: CompactPCI Hot Plug Core version: 0.2
    pci_hotplug: PCI Hot Plug PCI Core version: 0.5
    shpchp: shpc_init : shpc_cap_offset == 0
    shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
    pciehp: PCI Express Hot Plug Controller Driver version: 0.4
    ACPI: PCI interrupt 0000:00:02.7[C] -> GSI 10 (level, low) -> IRQ 10
    intel8x0_measure_ac97_clock: measured 49668 usecs
    intel8x0: clocking to 48000
    ACPI: PCI interrupt 0000:00:03.2[D] -> GSI 12 (level, low) -> IRQ 12
    ehci_hcd 0000:00:03.2: Silicon Integrated Systems [SiS] USB 2.0 Controller
    ehci_hcd 0000:00:03.2: irq 12, pci mem d0b43000
    ehci_hcd 0000:00:03.2: new USB bus registered, assigned bus number 3
    PCI: cache line size of 64 is not supported by device 0000:00:03.2
    ehci_hcd 0000:00:03.2: USB 2.0 enabled, EHCI 1.00, driver 2004-May-10
    hub 3-0:1.0: USB hub found
    hub 3-0:1.0: 6 ports detected
    usb 2-2: USB disconnect, address 2
    ohci_hcd 0000:00:03.1: wakeup
    usb 2-2: new low speed USB device using address 3
    NET: Registered protocol family 17
    eth0: Media Link On 100mbps full-duplex
    ip_tables: (C) 2000-2002 Netfilter core team
    ip_conntrack version 2.1 (2047 buckets, 16376 max) - 296 bytes per conntrack
    NET: Registered protocol family 10
    Disabled Privacy Extensions on device c02ca840(lo)
    IPv6 over IPv4 tunneling driver
    apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
    apm: overridden by ACPI.
    eth1: no IPv6 routers present
    eth0: no IPv6 routers present
    usb 3-6: new high speed USB device using address 3
    SCSI subsystem initialized
    Initializing USB Mass Storage driver...
    scsi0 : SCSI emulation for USB Mass Storage devices
    Vendor: USB 2.0 Model: Flash Disk Rev: 0.00
    USB Mass Storage device found at 3
    usbcore: registered new driver usb-storage
    USB Mass Storage support registered.
    SCSI device sda: 2048000 512-byte hdwr sectors (1049 MB)
    sda: assuming Write Enabled
    SCSI error: host 0 id 0 lun 0 return code = 8000002
    /dev/scsi/host0/bus0/target0/lun0: p1
    Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
    usb 3-6: USB disconnect, address 3
    usb 3-6: new high speed USB device using address 4
    scsi1 : SCSI emulation for USB Mass Storage devices
    SCSI error: host 1 id 0 lun 0 return code = 8000002
    /dev/scsi/host1/bus0/target0/lun0: p1
    Attached scsi removable disk sda at scsi1, channel 0, id 0, lun 0
    USB Mass Storage device found at 4
    usb 3-6: USB disconnect, address 4
    ohci_hcd 0000:00:03.0: wakeup
    usb 1-3: new full speed USB device using address 2
    usb 1-3: device not accepting address 2, error -110
    usb 1-3: new full speed USB device using address 3
    usb 1-3: device not accepting address 3, error -110
    usb 3-6: new high speed USB device using address 6
    scsi2 : SCSI emulation for USB Mass Storage devices
    SCSI error: host 2 id 0 lun 0 return code = 8000002
    /dev/scsi/host2/bus0/target0/lun0: p1
    Attached scsi removable disk sda at scsi2, channel 0, id 0, lun 0
    USB Mass Storage device found at 6
    lp0: using parport0 (interrupt-driven).
    usb 3-6: USB disconnect, address 6
    usb 3-6: new high speed USB device using address 7
    scsi3 : SCSI emulation for USB Mass Storage devices
    USB Mass Storage device found at 7
    usb 3-6: USB disconnect, address 7
    usb 2-3: new full speed USB device using address 4
    usb 2-3: device not accepting address 4, error -110
    usb 2-3: new full speed USB device using address 5
    usb 2-3: device not accepting address 5, error -110
    agradeco desde jah...
    valews...
    nett
    Eu sei qué é básico, mas voce, já viu no setup ?
