    Padrão postfix problema com alias e outras cositas+
    Ola pessoal, tenho um server rodando postfix com dominio vituais usando mysql. e ta dando erro quando coloco + de uma conta para direcionar o email. da o seguinte erro:
    Jan 20 12:03:52 perola postfix/qmgr[1758]: 9AF2822EF5B: from=<[email protected]>, size=1334, nrcpt=2 (queue active)
    Jan 20 12:03:52 perola postfix/pipe[4991]: 9AF2822EF5B: to=<[email protected]>, relay=maildrop, delay=3045, status=deferred (mailer configuration error)
    Jan 20 12:03:52 perola postfix/pipe[4990]: 4BD9B22EF4F: to=<[email protected]>, relay=maildrop, delay=7276, status=deferred (mailer configuration error)
    Jan 20 12:03:52 perola postfix/pipe[4991]: warning: pipe flag `D' requires maildrop_destination_recipient_limit = 1
    Jan 20 12:03:52 perola postfix/pipe[4990]: warning: pipe flag `D' requires maildrop_destination_recipient_limit = 1
    Quando colo apenas uma conta roda blz veja:
    Jan 20 11:16:09 perola postfix/qmgr[1758]: A699822EF63: from=<[email protected]>, size=1404, nrcpt=1 (queue active)
    Jan 20 11:16:09 perola amavis[4850]: (04850-01) Passed CLEAN, [205.161.6.35] <[email protected]> -> <[email protected]>, Message-ID: <[email protected]>, Hits: 0.785, 8951 ms
    Jan 20 11:16:09 perola postfix/pipe[4874]: A699822EF63: to=<[email protected]>, relay=maildrop, delay=1, status=sent (autonomainformatica.com.br)
    Jan 20 11:16:09 perola postfix/qmgr[1758]: A699822EF63: removed
    Jan 20 11:16:09 perola postfix/smtp[4868]: 54FCD22EF4C: to=<[email protected]>, orig_to=<[email protected]>, relay=127.0.0.1[127.0.0.1], delay=11, status=sent (250 2.6.0 Ok, id=04850-01, from MTA: 250 Ok: queued as A699822EF63)
    Outra coisa que erro e esse que aparece sempre que logo no webmail:
    Jan 20 09:42:04 perola imapd: Error: Input/output error
    Jan 20 09:42:04 perola imapd: Check for proper operation and configuration
    Jan 20 09:42:04 perola imapd: of the File Access Monitor daemon (famd).
    Jan 20 09:42:05 perola imapd: Failed to create cache file: maildirwatch ([email protected])
    Valeu!!
    Verifique se no seu arquivo main.cf do postfix existe o parametro:
    Se não existir, adicione e reinicialize o postfix.
    Citação Postado originalmente por riqui
    Obrigado, funcionou!!!
