  1. boa tarde a todos, meu amigos eu estou com uma dúvida para configurar um Nobreak SU3000-NET em meu servidor DELL. O que acontece é que no manual não está falando niente e o suporte apenas me mandou baixar o pacote .rpm e seguir as instruções que são:
    Installing the PowerChute Business Edition Agent
    Launch the PowerChute Business Edition for Linux installer by entering
    the absolute path to the pbe_agent_redhat_jvm.bin file. This file can
    be found in the Linux directory on the CD-ROM. For example, if the
    CD-ROM is mounted to /mnt/cdrom, you would enter the following at the
    shell prompt...
    /mnt/cdrom/Linux/pbe_agent_linux_jvm.bin
    An RPM package of the PowerChute Business Edition Agent for Linux is also available. This is also found in the Linux directory on the CD-ROM.
    Install the package using the -i (install) option. For example, if the
    shell prompt...
    rpm -i /mnt/cdrom/Linux/pbeagent-xxx.i386.rpm
    ...where xxx is the version of the product.
    This installs PowerChute Business Edition to the default directory,
    /opt/APC/PowerchuteBusinessEdition/Agent.
    This rpm also supports the --prefix option to allow you to specify the
    destination directory. For example,
    rpm -i /mnt/cdrom/Linux/pbeagent-xxx.i386.rpm --prefix /PCBE_Agent
    ...would install the PowerChute Business Edition Agent to he /PCBE_Agent
    directory.
    Once the RPM has been installed, you must configure the Agent for login
    information and the UPS type. This is handled by running the config.sh script located within the PowerChute Business Edition installation directory.
    This utility allows you to create an account name and password, and to configure the UPS by entering the communication type and communication port. After completing the configuration, you may start the PowerChute Business Edition Agent.
    pelo que entendi basta descompactar o devido arquivos .rpm e depois acessar e fazer as devidas alterações no arquivo de configuração config.sh ...
    pois bem, como seguro morreu de velho e eu não tenho onde testar antes a não ser diretamente em meu server, alguém já fez tal configuração?
    birinix
    Caro colega,
    estou esperando o nobreak chegar, possuo uma máqiona para testes...
    qquer coisa eu te aviso.
    PS. Qual o modelo do seu Nobreak?
    nobreak da APC SU3000NET
  4. este visitante aí sou eu :lol:
  5. com a ajuda dos amigos da underlinux eu consegui instalar a nhaca
    :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
    o problema agora é outro, eu não tenho idéia do que o seguinte arquivo faz, se algum puder me ajudar:
    #!/bin/sh
    if [ -z $1 ]
    then clear
    fi
    # config.sh for PCBE rpm install ver 6.3.
    # Configures PCBE 6.3.
    # Stop agent if running
    ps `cat /etc/pbeagent.pid 2>/dev/null | awk "{ print "'$1'" }"` > /dev/null
    if [ $? = 0 -a -e /etc/pbeagent.pid ]
    then
    PID=`cat /etc/pbeagent.pid 2>/dev/null | awk "{ print "'$1'" }"`
    kill $PID 1>/dev/null 2>/dev/null
    rm -f /etc/pbeagent.pid 1>/dev/null 2>/dev/null
    fi
    # Prepare to change parameters
    cd /opt/APC/PowerChuteBusinessEdition/Agent
    /bin/java/jre/1.4/bin/java -jar ./lib/pcbeconfig.jar $1 $2 $3 $4 $5
    teoricamente é o arquivo onde eu irei configurar um cliente e uma senha, além da conexão serial entre meu nobreak e meu server ... se alguém puder me explicar o significado destas linhas eu agradeço ...
  1. Problemas com redirecionamento de servidores.
    Por pirat no fórum Servidores de Rede
    Último Post: 22-10-2003, 07:29
  2. Raid de Servidores
    Último Post: 12-09-2003, 15:21
  3. lista de servidores para este grupo de trabalho
    Por Itise no fórum Servidores de Rede
    Último Post: 08-03-2003, 10:55
  4. IPTABLES- Redirecionamento de Servidor
    Por soyeu no fórum Servidores de Rede
    Último Post: 04-12-2002, 10:33
  5. Passos para conf de uma estacao linux ..
    Por MarcelScan no fórum Servidores de Rede
    Último Post: 04-04-2002, 22:40
