    Padrão DNS que coisa louca viu
    /etc/named.conf
    // generated by named-bootconf.pl
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    // query-source address * port 53;
    dump-file "/var/named/dump/named_dump.db";
    statistics-file "/var/named/dump/named.stats";
    memstatistics-file "/var/named/dump/named.memstats";
    // remove this next line if you want named to listen on
    // all available interfaces, or adjust add new ones as
    // you see fit
    listen-on { 127.0.0.1/32; };
    // a caching only nameserver config
    zone "." {
    type hint;
    file "named.ca";
    zone "0.0.127.in-addr.arpa" {
    type master;
    file "named.local";
    zone "0.168.192.in-addr.arpa"{
    type master;
    file "/var/named/192.168.0.rev";
    zone "empresa.com.br" {
    type master;
    file "/var/named/empresa.com.br";
    /var/named/name.local
    @ IN SOA servidor.empresa.com.br. root.empresa.com.br. (
    20050121 ; Serial
    3600 ; Refresh
    900 ; Retry
    1209600 ; Expire
    43200 ) ; Minimum
    @ IN NS servidor.empresa.com.br.
    1 IN PTR localhost.
    /var/named/192.168.rev
    $TTL 43200
    20050122
    3600
    900
    1209600
    43200 )
    1 IN PTR servidor.empresa.com.br.
    $TTL 86400
    20050122 ; serial;
    3600 ; refresh
    900 ; retry
    1209600 ; expire
    43200 ; default_ttl
    servidor.empresa.com.br. IN A 192.168.0.1
    www IN CNAME empresa.com.br.
    meu log
    Jan 24 11:13:53 renata named[7120]: starting BIND 9.2.3 -u named -t /var/named
    Jan 24 11:13:53 renata named[7120]: using 1 CPU
    Jan 24 11:13:53 renata named[7120]: loading configuration from '/etc/named.conf'
    Jan 24 11:13:53 renata named[7120]: /etc/named.conf:15: option 'memstatistics-file' is not implemented
    Jan 24 11:13:53 renata named[7120]: no IPv6 interfaces found
    Jan 24 11:13:53 renata named[7120]: listening on IPv4 interface lo, 127.0.0.1#53
    Jan 24 11:13:53 renata named[7120]: command channel listening on 127.0.0.1#953
    Jan 24 11:13:53 renata named[7120]: named.local:1: no TTL specified; using SOA MINTTL instead
    Jan 24 11:13:53 renata named[7120]: zone 0.0.127.in-addr.arpa/IN: loaded serial 20050121
    Jan 24 11:13:53 renata named[7120]: zone 0.168.192.in-addr.arpa/IN: loaded serial 20050122
    Jan 24 11:13:53 renata named[7120]: zone empresa.com.br/IN: loaded serial 20050122
    Jan 24 11:13:53 renata named[7120]: running
    Bom galera estes são meus arquivos, meu problema é o seguinte.
    dou um ping www.empresa.com.br, ele não pinga se dou um
    host www.empresa.com.br ele me retornar
    Host www.linuxstar.com.br not found: 2(SERVFAIL)
    nslook
    > www.empresa.com.br
    Server: 200.204.0.10
    Address: 200.204.0.10#53
    ** server can't find www.empresa.com.br: NXDOMAIN
    alguem poderia me ajudar a resolver isto.
    visitante
    por favor me ajudem
    garupeiro
    Vc ja olhou no resolv.conf ??????
    aponta la o ser servidor!!!
    Citação Postado originalmente por garupeiro
    search empresa.com.br
    nameserver 192.168.0.1
    nameserver 200.204.0.10
    visitante
    o galera me ajudem por favor vai
    ola galera da under, agradeco pelas 89 visita a meu post e por apenas um tentara me ajudar.
    Mas gracas a deus eu conseguir resolver sozinho, mas mesmo assim valeu pela ajuda. se alguem quiser saber como foi resolvido poste o e-mail ae no forum que lhe envio o resultado.
    garupeiro
    do mesmo jeito q vc queria ajuda via forum vc deveria colocar o seu problema resolvido tbm aki no forum e nao por email....
    Flw
    brunow
    amigo poderia deixa seu email ou msn para pode entra em contato eu fiz minha configurancoes baseada na sua o dns funciona localmente mas tb nao resolve nada da o mesmo erro poderia posta a configuracao q funcionou com vc ou deixa seu email ou msn Grato Bruno
