    Padrão Erros no squid Ninja
    Sr nao estou identificando o que ele esta reclamando !!!
    service squid restart
    Parando o squid: 2005/01/25 16:31:24| aclParseAclLine: IGNORING invalid ACL: acl blockedsites url_regex -i "/etc/squid/bloqueados/block.txt"
    2005/01/25 16:31:24| aclParseAclLine: IGNORING invalid ACL: acl unblockedsites url_regex -i "/etc/squid/bloqueados/unblock.txt"
    2005/01/25 16:31:24| squid.conf line 71: http_access deny blockedsites !unblockedsites
    2005/01/25 16:31:24| aclParseAccessLine: ACL name 'blockedsites' not found.
    2005/01/25 16:31:24| aclParseAccessLine: ACL name 'unblockedsites' not found.
    2005/01/25 16:31:24| aclParseAccessLine: Access line contains no ACL's, skipping
    Segue meu squid.conf
    #Lacier Dias
    #msn: [email protected]
    #Squid.conf - 01/01/2005
    http_port 192.168.1.1:3128
    visible_hostname none
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    # memoria usada:
    cache_mem 32 MB
    #esvazia o cache:
    cache_swap_low 90
    cache_swap_high 93
    maximum_object_size 6144 KB
    minimum_object_size 0 KB
    maximum_object_size_in_memory 100 KB
    ipcache_size 1024
    ipcache_low 90
    ipcache_high 93
    cache_replacement_policy lru
    memory_replacement_policy lru
    # disco usado:
    cache_dir ufs /var/spool/squid/cache 5000 16 256
    cache_log /var/log/squid/cache.log
    cache_store_log /var/log/squid/store.log
    auth_param basic program /usr/lib/squid/ncsa_auth /etc/squid/passwd
    auth_param basic children 5
    auth_param basic realm Digite seu Login
    refresh_pattern . 0 20% 4320
    acl all src 0.0.0.0/0.0.0.0
    acl informatica proxy_auth REQUIRED
    acl informatica proxy_auth edu wanderson
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    http_access allow localhost
    http_access allow informatica
    http_access deny manager
    http_access deny !Safe_ports
    http_access deny all
    http_reply_access allow all
    icp_access allow all
    cache_effective_user squid
    cache_effective_group squid
    httpd_accel_port 80
    httpd_accel_host virtual
    httpd_accel_with_proxy on
    Você colocou alguma coisa dentro dos arquivos "/etc/squid/bloqueados/unblock.txt" e "/etc/squid/bloqueados/block.txt" ?
    Se o arquivo está vazio ou se as permissões estão erradas, ele dá pau nas ACL's... é como se a sintaxe estivesse errada.
    Abraços!
    Padrão isso mesmo
    Faça essas verificações ... e o teu conf ta meio bagunçado!
    ce quiser eu dou um grau nele!
    Citação Postado originalmente por xstefanox
    Abraços!
