    adrianoc
    Padrão DNS dinâmico, bind9+dhcp não conversam.
    Pessoal,
    segui este artigo de cabo a rabo http://www.vivaolinux.com.br/artigos...hp?codigo=1049
    mas estou com problema no arquivo .jnl, acompanhando o meu syslog abaixo, podem perceber que o sistema tenta criá-lo mas não consegue. já tentei criar este arquivo com touch, mas não resolve não sei o que mais fazer. tb estou mandando meus confs. se alguém puder me dar uma luz fico muito grato. ogribado.
    ########### INICIANDO O BIND
    Jan 25 18:21:51 ptbh-deb named[13567]: starting BIND 9.2.4 -u bind
    Jan 25 18:21:52 ptbh-deb named[13567]: using 1 CPU
    Jan 25 18:21:52 ptbh-deb named[13567]: loading configuration from '/etc/bind/named.conf'
    Jan 25 18:21:52 ptbh-deb named[13567]: listening on IPv4 interface lo, 127.0.0.1#53
    Jan 25 18:21:52 ptbh-deb named[13567]: listening on IPv4 interface eth0, 201.17.135.86#53
    Jan 25 18:21:52 ptbh-deb named[13567]: listening on IPv4 interface eth1, 13.13.13.1#53
    Jan 25 18:21:52 ptbh-deb named[13567]: zone 'ptbh.net.br' allows updates by IP address, which is insecure
    Jan 25 18:21:52 ptbh-deb named[13567]: zone '13.13.in-addr-arpa' allows updates by IP address, which is insecure
    Jan 25 18:21:52 ptbh-deb named[13567]: command channel listening on 127.0.0.1#953
    Jan 25 18:21:52 ptbh-deb named[13567]: zone 0.in-addr.arpa/IN: loaded serial 1
    Jan 25 18:21:52 ptbh-deb named[13567]: zone 127.in-addr.arpa/IN: loaded serial 1
    Jan 25 18:21:52 ptbh-deb named[13567]: zone 255.in-addr.arpa/IN: loaded serial 1
    Jan 25 18:21:52 ptbh-deb named[13567]: zone ptbh.net.br/IN: loaded serial 1
    Jan 25 18:21:52 ptbh-deb named[13567]: zone 13.13.in-addr-arpa/IN: loaded serial 1
    Jan 25 18:21:52 ptbh-deb named[13567]: zone localhost/IN: loaded serial 1
    Jan 25 18:21:52 ptbh-deb named[13567]: running
    ######## Estação pegando IP e tentando atualizar zona.
    Jan 25 18:21:56 ptbh-deb named[13567]: client 127.0.0.1#1825: updating zone 'ptbh.net.br/IN': adding an RR
    Jan 25 18:21:56 ptbh-deb named[13567]: journal file /etc/bind/ptbh.db.jnl does not exist, creating it
    Jan 25 18:21:56 ptbh-deb named[13567]: /etc/bind/ptbh.db.jnl: create: permission denied
    Jan 25 18:21:56 ptbh-deb named[13567]: client 127.0.0.1#1825: updating zone 'ptbh.net.br/IN': error: journal open failed: un$
    Jan 25 18:21:56 ptbh-deb dhcpd: Unable to add forward map from ptbh-r.ptbh.net.br to 13.13.13.14: timed out
    Jan 25 18:21:56 ptbh-deb dhcpd: DHCPREQUEST for 13.13.13.14 from 00:60:67:06:5b:cd (ptbh-r) via eth1
    Jan 25 18:21:56 ptbh-deb dhcpd: DHCPACK on 13.13.13.14 to 00:60:67:06:5b:cd (ptbh-r) via eth1
    #############named.conf
    options {directory "/var/cache/bind"; auth-nxdomain yes;};
    zone "." {type hint; file "/etc/bind/db.root";};
    zone "localhost" {type master;file "/etc/bind/db.local";};
    zone "127.in-addr.arpa" {type master;file "/etc/bind/db.127";};
    zone "0.in-addr.arpa" {type master;file "/etc/bind/db.0";};
    zone "255.in-addr.arpa" {type master;file "/etc/bind/db.255";};
    include "/etc/bind/named.conf.local";
    controls {inet 127.0.0.1 port 953 allow { 127.0.0.1; 13.13.13.1; }; };
    zone "ptbh.net.br" {type master; allow-update {127.0.0.1; 13.13.13.1; }; file "/etc/bind/ptbh.db";};
    zone "13.13.in-addr-arpa" {type master; allow-update {127.0.0.1; 13.13.13.1; }; file "/etc/bind/ptbh.rev";};
    ############### zona local
    $ORIGIN ptbh.net.br.
    $TTL 604800;
    @ IN SOA dns1.ptbh.net.br. adm.ptbh.net.br. (
    1 ; Serial
    604800 ; Refresh
    864000 ; Retry
    2419200 ; Expire
    604800 ) ; Negative Cache TTL
    @ IN NS dns1.ptbh.net.br.
    @ IN MX 5 mail
    @ IN A 13.13.13.1
    ptbh-deb IN A 13.13.13.1
    mail IN A 13.13.13.1
    www IN A 13.13.13.1
    ftp IN A 13.13.13.1
    ######### reverso
    ;$ORIGIN 13.13.in-addr.arpa.
    $TTL 604800;
    1 ; Serial
    604800 ; Refresh
    86400 ; Retry
    2419200 ; Expire
    1 IN PTR adm.ptbh.net.br.
    adrianoc
    Padrão Dns dinámico
    Pessoal,
    depois de muita insistência consegui resolver .... a estação estão atualizando zona, já consigo tratar as máquinas pelo seu próprio hostname. Se alguém interessar eu posso postar aqui a configuração do bind.
    o problema estava na permissão dos arquivos e do próprio diretório do /etc/bind. mudei pra 770 e os arquivos que criei pelo root, mudei pro bind.
    desta forma foi possível criar o arquivo .jnl e funfar legal.
    mas ainda estou com problema no DNS reverso, não sei direito o que é, mas acho que tem algo haver com "IP válido".
    Continuo na luta.
    Padrão bind
    se puder enviar o conf pra rodrigo aroba linkweb com br eu agradeço
