    Padrão Squid autenticado Ajuda
    Sr Gostaria que meu squid so permitisse alguns sites e pra adm liberato total qual alteraçao tenho que fazer segue meu squid.conf !!!
    #Lacier Dias
    #msn: [email protected]
    #Squid.conf - 01/01/2005
    http_port 192.168.1.1:3128
    visible_hostname none
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    # memoria usada:
    cache_mem 32 MB
    #esvazia o cache:
    cache_swap_low 90
    cache_swap_high 93
    maximum_object_size 6144 KB
    minimum_object_size 0 KB
    maximum_object_size_in_memory 100 KB
    ipcache_size 1024
    ipcache_low 90
    ipcache_high 93
    cache_replacement_policy lru
    memory_replacement_policy lru
    # disco usado:
    cache_dir ufs /var/spool/squid/cache 5000 16 256
    cache_log /var/log/squid/cache.log
    cache_store_log /var/log/squid/store.log
    acl sites_proibidos dstdomain "/etc/squid/regras/sites_proibidos"
    acl download_proibidos url_regex -i "/etc/squid/regras/download_proibidos"
    acl multimidia_proibidos urlpath_regex -i "/etc/squid/regras/multimidia_proibidos"
    http_access deny sites_proibidos
    http_access deny download_proibidos !multimidia_proibidos
    auth_param basic program /usr/lib/squid/ncsa_auth /etc/squid/passwd
    auth_param basic children 5
    auth_param basic realm Digite seu Login
    refresh_pattern . 0 20% 4320
    acl all src 0.0.0.0/0.0.0.0
    acl informatica proxy_auth REQUIRED
    acl informatica proxy_auth edu wanderson
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    http_access allow localhost
    http_access allow informatica
    http_access deny manager
    http_access deny !Safe_ports
    http_access deny all
    http_reply_access allow all
    icp_access allow all
    cache_effective_user squid
    cache_effective_group squid
    httpd_accel_port 80
    httpd_accel_host virtual
    httpd_accel_with_proxy on
    Padrão Re: Squid autenticado Ajuda
    Qual sua Distro?
    ... Me passe um propecto de sua nescecidade!
    Falows
    Citação Postado originalmente por edu_uti
    #Lacier Dias
    no_cache deny QUERY
    # memoria usada:
    cache_mem 32 MB
    #esvazia o cache:
    cache_swap_low 90
    cache_swap_high 93
    ipcache_size 1024
    ipcache_low 90
    ipcache_high 93
    # disco usado:
    httpd_accel_port 80
    olha alterei teu conf aonde acho necessário coloque ele e rode!!!
    Ow.... havisa dai ta!@!!!!
    Código :
    #Lacier Dias
    #msn: [email][email protected][/email]
    no_cache deny QUERY
    # memoria usada:
    cache_mem 32 MB
    #esvazia o cache:
    cache_swap_low 90
    cache_swap_high 93
    ipcache_size 1024
    ipcache_low 90
    ipcache_high 93
    # disco usado:
    acl resto proxy_auth REQUIRED
    http_access allow resto
    httpd_accel_port 80
