    Chuck
    Padrão qmail - erro spawn.o
    e ai galera,
    to instalando o qmail-1.03 com os patch's
    qmail-1.03-mfcheck.3.patch
    qmail-1.03.errno.patch
    big-concurrency.patch
    qmail-1.03.qmail_local.patch
    qmailqueue-patch
    qmail-0.0.0.0.patch
    tarpit.patch
    quando ele vai compilar o ./chkspawn da o seguinte erro
    Oops. Your system's FD_SET() has a hidden limit of 1024 descriptors.
    This means that the qmail daemons could crash if you set the run-time
    concurrency higher than 509. So I'm going to insist that the concurrency
    limit in conf-spawn be at most 509. Right now it's 1000.
    make: *** [spawn.o] Error 1
    to usando o suse 9.1
    gcc-3.3.3.41
    glibc-3.3.3-98
    Valeu,
    Chuck
    Chuck
    opa....editei o arquivo conf-spawn e mudei
    de 1000 para 509. FUNCIONOU!!!
    Valeu
    Chuck
    Super_Diaulas
    nada que um pouco de atenção
