  1. Povo:
    Estou com problemas na interface gráfica do meu Fedora Core 3...
    Apesar de aparecer a tela de login, e tal, não consigo logar em nenhuma das interfaces (KDE, Metisse, Xfce), somente no xterm de segurança...
    Bem, acho que tem relação com um programinha que converte html para pdf
    que eu não consegui instalar...
    No script de instalação ele sobrescrevia meu "C2CPDemoClient" no /usr/sbin
    Talvez tenha a ver, porque no /etc/kde/kdm tem uns scripts que sao
    interpretados por esse programa...
    Que eu faço?
    Ah, o servidor X eh o xorg...
    karfax
    Dificil dizer sem ver seu xorg.log...
    HTH,
  3. Onde acho esse log?
    karfax
    Em /var/log/...
    []s,
  5. X Window System Version 6.8.1
    Release Date: 17 September 2004
    X Protocol Version 11, Revision 0, Release 6.8.1
    Build Operating System: Linux 2.4.21-14.ELsmp i686 [ELF]
    Current Operating System: Linux gmicro33 2.6.9-1.667 #1 Tue Nov 2 14:41:25 EST 2004 i686
    Build Date: 20 October 2004
    Build Host: tweety.build.redhat.com
    Before reporting problems, check http://wiki.X.Org
    to make sure that you have the latest version.
    Module Loader present
    OS Kernel: Linux version 2.6.9-1.667 (bhcompile@tweety.build.redhat.com) (gcc version 3.4.2 20041017 (Red Hat 3.4.2-6.fc3)) #1 Tue Nov 2 14:41:25 EST 2004
    Markers: (--) probed, (**) from config file, (==) default setting,
    (++) from command line, (!!) notice, (II) informational,
    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
    (==) Log file: "/var/log/Xorg.0.log", Time: Wed Feb 2 15:49:36 2005
    (==) Using config file: "/etc/X11/xorg.conf"
    (==) ServerLayout "Default Layout"
    (**) |-->Screen "Screen0" (0)
    (**) | |-->Monitor "Monitor0"
    (**) | |-->Device "Videocard0"
    (**) |-->Input Device "Mouse0"
    (**) |-->Input Device "Keyboard0"
    (**) FontPath set to "unix/:7100"
    (**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
    (==) ModulePath set to "/usr/X11R6/lib/modules"
    (WW) Open APM failed (/dev/apm_bios) (No such file or directory)
    (II) Module ABI versions:
    X.Org ANSI C Emulation: 0.2
    X.Org Video Driver: 0.7
    X.Org XInput driver : 0.4
    X.Org Server Extension : 0.2
    X.Org Font Renderer : 0.4
    (II) Loader running on linux
    (II) LoadModule: "bitmap"
    (II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
    (II) Module bitmap: vendor="X.Org Foundation"
    compiled for 6.8.1, module version = 1.0.0
    Module class: X.Org Font Renderer
    ABI class: X.Org Font Renderer, version 0.4
    (II) Loading font Bitmap
    (II) LoadModule: "pcidata"
    (II) Loading /usr/X11R6/lib/modules/libpcidata.a
    (II) Module pcidata: vendor="X.Org Foundation"
    ABI class: X.Org Video Driver, version 0.7
    (++) using VT number 7
    (II) PCI: Probing config type using method 1
    (II) PCI: Config type is 1
    (II) PCI: stages = 0x03, oldVal1 = 0x00000000, mode1Res1 = 0x80000000
    (II) PCI: PCI scan (all values are in hex)
    (II) PCI: 00:00:0: chip 1039,0648 card 1043,8086 rev 51 class 06,00,00 hdr 80
    (II) PCI: 00:01:0: chip 1039,0003 card 0000,0000 rev 00 class 06,04,00 hdr 01
    (II) PCI: 00:02:0: chip 1039,0963 card 0000,0000 rev 25 class 06,01,00 hdr 80
    (II) PCI: 00:02:1: chip 1039,0016 card 0000,0000 rev 00 class 0c,05,00 hdr 00
    (II) PCI: 00:02:5: chip 1039,5513 card 1043,8087 rev 00 class 01,01,80 hdr 00
    (II) PCI: 00:02:7: chip 1039,7012 card 1043,80b0 rev a0 class 04,01,00 hdr 00
    (II) PCI: 00:03:0: chip 1039,7001 card 1043,8087 rev 0f class 0c,03,10 hdr 80
    (II) PCI: 00:03:1: chip 1039,7001 card 1043,8087 rev 0f class 0c,03,10 hdr 00
    (II) PCI: 00:03:3: chip 1039,7002 card 1043,8087 rev 00 class 0c,03,20 hdr 00
    (II) PCI: 00:04:0: chip 1039,0900 card 1043,80ff rev 91 class 02,00,00 hdr 00
    (II) PCI: 01:00:0: chip 10de,0322 card 1682,1351 rev a1 class 03,00,00 hdr 00
    (II) PCI: End of PCI scan
    (II) Host-to-PCI bridge:
    (II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
    (II) Bus 0 I/O range:
    [0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
    (II) Bus 0 non-prefetchable memory range:
    [0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
    (II) Bus 0 prefetchable memory range:
    (II) PCI-to-PCI bridge:
    (II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
    (II) Bus 1 non-prefetchable memory range:
    [0] -1 0 0xe7000000 - 0xe7ffffff (0x1000000) MX[B]
    (II) Bus 1 prefetchable memory range:
    [0] -1 0 0xeff00000 - 0xfebfffff (0xed00000) MX[B]
    (II) PCI-to-ISA bridge:
    (II) Bus -1: bridge is at (0:2:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
    (--) PCI:*(1:0:0) nVidia Corporation NV34 [GeForce FX 5200] rev 161, Mem @ 0xe7000000/24, 0xf0000000/27, BIOS @ 0xeffe0000/17
    (II) Addressable bus resource ranges are
    [1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
    (II) OS-reported resource ranges:
    [0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
    [1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
    [2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
    [3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
    [4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
    [5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
    [6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
    (II) PCI Memory resource overlap reduced 0xe8000000 from 0xebffffff to 0xe7ffffff
    (II) Active PCI resource ranges:
    [0] -1 0 0xe5000000 - 0xe5000fff (0x1000) MX[B]
    [1] -1 0 0xe5800000 - 0xe5800fff (0x1000) MX[B]
    [2] -1 0 0xe6000000 - 0xe6000fff (0x1000) MX[B]
    [3] -1 0 0xe6800000 - 0xe6800fff (0x1000) MX[B]
    [4] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
    [5] -1 0 0xeffe0000 - 0xefffffff (0x20000) MX[B](B)
    [6] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MX[B](B)
    [7] -1 0 0xe7000000 - 0xe7ffffff (0x1000000) MX[B](B)
    [8] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
    [9] -1 0 0x0000a000 - 0x0000a07f (0x80) IX[B]
    [10] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
    [11] -1 0 0x0000b400 - 0x0000b40f (0x10) IX[B]
    [12] -1 0 0x0000e600 - 0x0000e61f (0x20) IX[B]
    (II) Active PCI resource ranges after removing overlaps:
    (II) OS-reported resource ranges after removing overlaps with PCI:
    (II) All system resource ranges:
    [5] -1 0 0xe5000000 - 0xe5000fff (0x1000) MX[B]
    [6] -1 0 0xe5800000 - 0xe5800fff (0x1000) MX[B]
    [7] -1 0 0xe6000000 - 0xe6000fff (0x1000) MX[B]
    [8] -1 0 0xe6800000 - 0xe6800fff (0x1000) MX[B]
    [9] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
    [10] -1 0 0xeffe0000 - 0xefffffff (0x20000) MX[B](B)
    [11] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MX[B](B)
    [12] -1 0 0xe7000000 - 0xe7ffffff (0x1000000) MX[B](B)
    [13] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
    [14] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
    [15] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
    [16] -1 0 0x0000a000 - 0x0000a07f (0x80) IX[B]
    [17] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
    [18] -1 0 0x0000b400 - 0x0000b40f (0x10) IX[B]
    [19] -1 0 0x0000e600 - 0x0000e61f (0x20) IX[B]
    (II) LoadModule: "dbe"
    (II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
    (II) Module dbe: vendor="X.Org Foundation"
    Module class: X.Org Server Extension
    ABI class: X.Org Server Extension, version 0.2
    (II) Loading extension DOUBLE-BUFFER
    (II) LoadModule: "extmod"
    (II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
    (II) Module extmod: vendor="X.Org Foundation"
    (II) Loading extension SHAPE
    (II) Loading extension MIT-SUNDRY-NONSTANDARD
    (II) Loading extension BIG-REQUESTS
    (II) Loading extension SYNC
    (II) Loading extension MIT-SCREEN-SAVER
    (II) Loading extension XC-MISC
    (II) Loading extension XFree86-VidModeExtension
    (II) Loading extension XFree86-Misc
    (II) Loading extension XFree86-DGA
    (II) Loading extension DPMS
    (II) Loading extension TOG-CUP
    (II) Loading extension Extended-Visual-Information
    (II) Loading extension XVideo
    (II) Loading extension XVideo-MotionCompensation
    (II) Loading extension X-Resource
    (II) LoadModule: "fbdevhw"
    (II) Loading /usr/X11R6/lib/modules/linux/libfbdevhw.a
    (II) Module fbdevhw: vendor="X.Org Foundation"
    compiled for 6.8.1, module version = 0.0.2
    (II) LoadModule: "glx"
    (II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
    (II) Module glx: vendor="X.Org Foundation"
    (II) Loading sub module "GLcore"
    (II) LoadModule: "GLcore"
    (II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
    (II) Module GLcore: vendor="X.Org Foundation"
    (II) Loading extension GLX
    (II) LoadModule: "record"
    (II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
    (II) Module record: vendor="X.Org Foundation"
    compiled for 6.8.1, module version = 1.13.0
    (II) Loading extension RECORD
    (II) LoadModule: "freetype"
    (II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.so
    (II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
    compiled for 6.8.1, module version = 2.1.0
    (II) Loading font FreeType
    (II) LoadModule: "type1"
    (II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
    (II) Module type1: vendor="X.Org Foundation"
    compiled for 6.8.1, module version = 1.0.2
    (II) Loading font Type1
    (II) Loading font CID
    (II) LoadModule: "dri"
    (II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
    (II) Module dri: vendor="X.Org Foundation"
    (II) Loading sub module "drm"
    (II) LoadModule: "drm"
    (II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
    (II) Module drm: vendor="X.Org Foundation"
    (II) Loading extension XFree86-DRI
    (II) LoadModule: "nv"
    (II) Loading /usr/X11R6/lib/modules/drivers/nv_drv.o
    (II) Module nv: vendor="X.Org Foundation"
    compiled for 6.8.1, module version = 1.0.1
    Module class: X.Org Video Driver
    (II) LoadModule: "mouse"
    (II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
    (II) Module mouse: vendor="X.Org Foundation"
    Module class: X.Org XInput Driver
    ABI class: X.Org XInput driver, version 0.4
    (II) LoadModule: "kbd"
    (II) Loading /usr/X11R6/lib/modules/input/kbd_drv.o
    (II) Module kbd: vendor="X.Org Foundation"
    (II) NV: driver for NVIDIA chipsets: RIVA 128, RIVA TNT, RIVA TNT2,
    Unknown TNT2, Vanta, RIVA TNT2 Ultra, RIVA TNT2 Model 64,
    Aladdin TNT2, GeForce 256, GeForce DDR, Quadro, GeForce2 MX/MX 400,
    GeForce2 MX 100/200, GeForce2 Go, Quadro2 MXR/EX/Go,
    GeForce2 Integrated GPU, GeForce2 GTS, GeForce2 Ti, GeForce2 Ultra,
    Quadro2 Pro, GeForce4 MX 460, GeForce4 MX 440, GeForce4 MX 420,
    GeForce4 MX 440-SE, GeForce4 440 Go, GeForce4 420 Go,
    GeForce4 420 Go 32M, GeForce4 460 Go, GeForce4 440 Go 64M,
    GeForce4 410 Go 16M, Quadro4 500 GoGL, Quadro4 550 XGL, Quadro4 NVS,
    GeForce4 MX 440 with AGP8X, GeForce4 MX 440SE with AGP8X,
    GeForce4 MX 420 with AGP8X, GeForce4 448 Go, GeForce4 488 Go,
    Quadro4 580 XGL, Quadro4 280 NVS, Quadro4 380 XGL,
    GeForce4 MX Integrated GPU, GeForce3, GeForce3 Ti 200,
    GeForce3 Ti 500, Quadro DCC, GeForce4 Ti 4600, GeForce4 Ti 4400,
    0x0252, GeForce4 Ti 4200, Quadro4 900 XGL, Quadro4 750 XGL,
    Quadro4 700 XGL, GeForce4 Ti 4800, GeForce4 Ti 4200 with AGP8X,
    GeForce4 Ti 4800 SE, GeForce4 4200 Go, Quadro4 700 GoGL,
    Quadro4 980 XGL, Quadro4 780 XGL, GeForce FX 5800 Ultra,
    GeForce FX 5800, Quadro FX 2000, Quadro FX 1000,
    GeForce FX 5600 Ultra, GeForce FX 5600, 0x0313, GeForce FX 5600SE,
    0x0316, 0x0317, GeForce FX Go5600, GeForce FX Go5650,
    Quadro FX Go700, 0x031D, 0x031E, 0x031F, GeForce FX 5200,
    GeForce FX 5200 Ultra, GeForce FX 5200, GeForce FX 5200SE,
    GeForce FX Go5200, GeForce FX Go5250, GeForce FX Go5200 32M/64M,
    0x0329, Quadro NVS 280 PCI, Quadro FX 500, GeForce FX Go5300,
    GeForce FX Go5100, 0x032F, GeForce FX 5900 Ultra, GeForce FX 5900,
    GeForce FX 5900XT, GeForce FX 5950 Ultra, 0x0334, Quadro FX 3000,
    GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE,
    GeForce FX 5700VE, 0x0345, GeForce FX Go5700, GeForce FX Go5700,
    0x0349, 0x034B, Quadro FX Go1000, Quadro FX 1100, 0x034F
    (II) Primary Device is: PCI 01:00:0
    (--) Assigning device section with no busID to primary device
    (--) Chipset GeForce FX 5200 found
    (II) resource ranges after xf86ClaimFixedResources() call:
    (II) resource ranges after probing:
    [13] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
    [14] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
    [15] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
    [16] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
    [17] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
    [18] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
    [19] -1 0 0x0000a000 - 0x0000a07f (0x80) IX[B]
    [20] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
    [21] -1 0 0x0000b400 - 0x0000b40f (0x10) IX[B]
    [22] -1 0 0x0000e600 - 0x0000e61f (0x20) IX[B]
    [23] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
    [24] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
    (II) Setting vga for screen 0.
    (II) Loading sub module "int10"
    (II) LoadModule: "int10"
    (II) Loading /usr/X11R6/lib/modules/linux/libint10.a
    (II) Module int10: vendor="X.Org Foundation"
    (II) NV(0): Initializing int10
    (II) NV(0): Primary V_BIOS segment is: 0xc000
    (--) NV(0): Chipset: "GeForce FX 5200"
    (**) NV(0): Depth 24, (--) framebuffer bpp 32
    (==) NV(0): RGB weight 888
    (==) NV(0): Default visual is TrueColor
    (II) Loading sub module "vgahw"
    (II) LoadModule: "vgahw"
    (II) Loading /usr/X11R6/lib/modules/libvgahw.a
    (II) Module vgahw: vendor="X.Org Foundation"
    compiled for 6.8.1, module version = 0.1.0
    (==) NV(0): Using HW cursor
    (--) NV(0): Linear framebuffer at 0xF0000000
    (--) NV(0): MMIO registers at 0xE7000000
    (II) Loading sub module "i2c"
    (II) LoadModule: "i2c"
    (II) Loading /usr/X11R6/lib/modules/libi2c.a
    (II) Module i2c: vendor="X.Org Foundation"
    compiled for 6.8.1, module version = 1.2.0
    (II) Loading sub module "ddc"
    (II) LoadModule: "ddc"
    (II) Loading /usr/X11R6/lib/modules/libddc.a
    (II) Module ddc: vendor="X.Org Foundation"
    (II) NV(0): I2C bus "DDC" initialized.
    (II) NV(0): Probing for analog device on output A...
    (--) NV(0): ...found one
    (II) NV(0): Probing for analog device on output B...
    (--) NV(0): ...can't find one
    (II) NV(0): Probing for EDID on I2C bus A...
    (II) NV(0): I2C device "DDC:ddc2" registered at address 0xA0.
    (II) NV(0): I2C device "DDC:ddc2" removed.
    (--) NV(0): DDC detected a CRT:
    (II) NV(0): Manufacturer: SAM Model: 107 Serial#: 1279602999
    (II) NV(0): Year: 2004 Week: 41
    (II) NV(0): EDID Version: 1.3
    (II) NV(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
    (II) NV(0): Sync: Separate
    (II) NV(0): Max H-Image Size [cm]: horiz.: 31 vert.: 23
    (II) NV(0): Gamma: 2.20
    (II) NV(0): DPMS capabilities: Off; RGB/Color Display
    (II) NV(0): Default color space is primary color space
    (II) NV(0): First detailed timing is preferred mode
    (II) NV(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
    (II) NV(0): blueX: 0.150 blueY: 0.060 whiteX: 0.312 whiteY: 0.329
    (II) NV(0): Supported VESA Video Modes:
    (II) NV(0): 720x400@70Hz
    (II) NV(0): 640x480@60Hz
    (II) NV(0): 640x480@67Hz
    (II) NV(0): 640x480@72Hz
    (II) NV(0): 640x480@75Hz
    (II) NV(0): 800x600@56Hz
    (II) NV(0): 800x600@60Hz
    (II) NV(0): 800x600@72Hz
    (II) NV(0): 800x600@75Hz
    (II) NV(0): 832x624@75Hz
    (II) NV(0): 1024x768@60Hz
    (II) NV(0): 1024x768@70Hz
    (II) NV(0): 1024x768@75Hz
    (II) NV(0): 1152x870@75Hz
    (II) NV(0): Manufacturer's mask: 0
    (II) NV(0): Supported Future Video Modes:
    (II) NV(0): #0: hsize: 1024 vsize 768 refresh: 85 vid: 22881
    (II) NV(0): #1: hsize: 800 vsize 600 refresh: 85 vid: 22853
    (II) NV(0): #2: hsize: 640 vsize 480 refresh: 85 vid: 22833
    (II) NV(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
    (II) NV(0): #4: hsize: 1152 vsize 864 refresh: 75 vid: 20337
    (II) NV(0): Supported additional Video Mode:
    (II) NV(0): clock: 94.5 MHz Image Size: 312 x 234 mm
    (II) NV(0): h_active: 1024 h_sync: 1072 h_sync_end 1168 h_blank_end 1376 h_border: 0
    (II) NV(0): v_active: 768 v_sync: 769 v_sync_end 772 v_blanking: 808 v_border: 0
    (II) NV(0): Ranges: V min: 50 V max: 160 Hz, H min: 30 H max: 71 kHz, PixClock max 110 MHz
    (II) NV(0): Monitor name: SyncMaster
    (II) NV(0): Serial No: HXAXA06761
    (II) NV(0): Probing for EDID on I2C bus B...
    (II) NV(0): ... none found
    (--) NV(0): CRTC 0 appears to have a CRT attached
    (II) NV(0): Using CRT on CRTC 0
    (--) NV(0): VideoRAM: 131072 kBytes
    (==) NV(0): Using gamma correction (1.0, 1.0, 1.0)
    (II) NV(0): Monitor0: Using hsync range of 30.00-71.00 kHz
    (II) NV(0): Monitor0: Using vrefresh range of 50.00-160.00 Hz
    (II) NV(0): Clock range: 12.00 to 350.00 MHz
    (II) NV(0): Not using default mode "1280x960" (hsync out of range)
    (II) NV(0): Not using default mode "640x480" (hsync out of range)
    (II) NV(0): Not using default mode "1280x1024" (hsync out of range)
    (II) NV(0): Not using default mode "640x512" (hsync out of range)
    (II) NV(0): Not using default mode "1600x1200" (hsync out of range)
    (II) NV(0): Not using default mode "800x600" (hsync out of range)
    (II) NV(0): Not using default mode "1792x1344" (hsync out of range)
    (II) NV(0): Not using default mode "896x672" (hsync out of range)
    (II) NV(0): Not using default mode "1856x1392" (hsync out of range)
    (II) NV(0): Not using default mode "928x696" (hsync out of range)
    (II) NV(0): Not using default mode "1920x1440" (hsync out of range)
    (II) NV(0): Not using default mode "960x720" (hsync out of range)
    (II) NV(0): Not using default mode "1152x864" (hsync out of range)
    (II) NV(0): Not using default mode "576x432" (hsync out of range)
    (WW) (1400x1050,Monitor0) mode clock 122MHz exceeds DDC maximum 110MHz
    (II) NV(0): Not using default mode "1400x1050" (hsync out of range)
    (II) NV(0): Not using default mode "700x525" (hsync out of range)
    (II) NV(0): Not using default mode "1920x1200" (hsync out of range)
    (II) NV(0): Not using default mode "960x600" (hsync out of range)
    (II) NV(0): Not using default mode "2048x1536" (hsync out of range)
    (II) NV(0): Not using default mode "2048x1536" (bad mode clock/interlace/doublescan)
    (II) NV(0): Not using default mode "1400x1050" (width too large for virtual size)
    (II) NV(0): Not using default mode "1280x1024" (width too large for virtual size)
    (II) NV(0): Not using default mode "1280x960" (width too large for virtual size)
    (II) NV(0): Not using default mode "1152x864" (width too large for virtual size)
    (II) NV(0): Not using default mode "1152x768" (width too large for virtual size)
    (--) NV(0): Virtual size is 1024x768 (pitch 1024)
    (**) NV(0): *Mode "1024x768": 94.5 MHz, 68.7 kHz, 85.0 Hz
    (II) NV(0): Modeline "1024x768" 94.50 1024 1088 1184 1376 768 769 772 808 +hsync +vsync
    (**) NV(0): *Default mode "800x600": 56.3 MHz, 53.7 kHz, 85.1 Hz
    (II) NV(0): Modeline "800x600" 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync
    (**) NV(0): *Default mode "640x480": 36.0 MHz, 43.3 kHz, 85.0 Hz
    (II) NV(0): Modeline "640x480" 36.00 640 696 752 832 480 481 484 509 -hsync -vsync
    (**) NV(0): Default mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz
    (II) NV(0): Modeline "832x624" 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync
    (**) NV(0): Default mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
    (II) NV(0): Modeline "800x600" 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync
    (**) NV(0): Default mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
    (II) NV(0): Modeline "800x600" 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync
    (**) NV(0): Default mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
    (II) NV(0): Modeline "800x600" 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync
    (**) NV(0): Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
    (II) NV(0): Modeline "800x600" 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync
    (**) NV(0): Default mode "700x525": 61.0 MHz, 64.9 kHz, 60.0 Hz (D)
    (II) NV(0): Modeline "700x525" 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync
    (**) NV(0): Default mode "640x512": 54.0 MHz, 64.0 kHz, 60.0 Hz (D)
    (II) NV(0): Modeline "640x512" 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync
    (**) NV(0): Default mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
    (II) NV(0): Modeline "640x480" 31.50 640 656 720 840 480 481 484 500 -hsync -vsync
    (**) NV(0): Default mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz
    (II) NV(0): Modeline "640x480" 31.50 640 664 704 832 480 489 491 520 -hsync -vsync
    (**) NV(0): Default mode "640x480": 25.2 MHz, 31.5 kHz, 60.0 Hz
    (II) NV(0): Modeline "640x480" 25.20 640 656 752 800 480 490 492 525 -hsync -vsync
    (**) NV(0): Default mode "640x480": 54.0 MHz, 60.0 kHz, 60.0 Hz (D)
    (II) NV(0): Modeline "640x480" 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync
    (**) NV(0): Default mode "720x400": 35.5 MHz, 37.9 kHz, 85.0 Hz
    (II) NV(0): Modeline "720x400" 35.50 720 756 828 936 400 401 404 446 -hsync +vsync
    (**) NV(0): Default mode "640x400": 31.5 MHz, 37.9 kHz, 85.1 Hz
    (II) NV(0): Modeline "640x400" 31.50 640 672 736 832 400 401 404 445 -hsync +vsync
    (**) NV(0): Default mode "576x432": 54.0 MHz, 67.5 kHz, 75.0 Hz (D)
    (II) NV(0): Modeline "576x432" 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync
    (**) NV(0): Default mode "640x350": 31.5 MHz, 37.9 kHz, 85.1 Hz
    (II) NV(0): Modeline "640x350" 31.50 640 672 736 832 350 382 385 445 +hsync -vsync
    (**) NV(0): Default mode "576x384": 32.5 MHz, 44.2 kHz, 54.8 Hz (D)
    (II) NV(0): Modeline "576x384" 32.50 576 589 657 736 384 385 388 403 doublescan +hsync +vsync
    (**) NV(0): Default mode "512x384": 47.2 MHz, 68.7 kHz, 85.0 Hz (D)
    (II) NV(0): Modeline "512x384" 47.25 512 536 584 688 384 384 386 404 doublescan +hsync +vsync
    (**) NV(0): Default mode "512x384": 39.4 MHz, 60.1 kHz, 75.1 Hz (D)
    (II) NV(0): Modeline "512x384" 39.40 512 520 568 656 384 384 386 400 doublescan +hsync +vsync
    (**) NV(0): Default mode "512x384": 37.5 MHz, 56.5 kHz, 70.1 Hz (D)
    (II) NV(0): Modeline "512x384" 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync
    (**) NV(0): Default mode "512x384": 32.5 MHz, 48.4 kHz, 60.0 Hz (D)
    (II) NV(0): Modeline "512x384" 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync
    (**) NV(0): Default mode "512x384": 22.4 MHz, 35.5 kHz, 87.1 Hz (D)
    (II) NV(0): Modeline "512x384" 22.45 512 516 604 632 384 384 388 409 interlace doublescan +hsync +vsync
    (**) NV(0): Default mode "416x312": 28.6 MHz, 49.7 kHz, 74.7 Hz (D)
    (II) NV(0): Modeline "416x312" 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync
    (**) NV(0): Default mode "400x300": 28.1 MHz, 53.7 kHz, 85.3 Hz (D)
    (II) NV(0): Modeline "400x300" 28.15 400 416 448 524 300 300 302 315 doublescan +hsync +vsync
    (**) NV(0): Default mode "400x300": 24.8 MHz, 46.9 kHz, 75.1 Hz (D)
    (II) NV(0): Modeline "400x300" 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync
    (**) NV(0): Default mode "400x300": 25.0 MHz, 48.1 kHz, 72.2 Hz (D)
    (II) NV(0): Modeline "400x300" 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync
    (**) NV(0): Default mode "400x300": 20.0 MHz, 37.9 kHz, 60.3 Hz (D)
    (II) NV(0): Modeline "400x300" 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync
    (**) NV(0): Default mode "400x300": 18.0 MHz, 35.2 kHz, 56.3 Hz (D)
    (II) NV(0): Modeline "400x300" 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync
    (**) NV(0): Default mode "320x240": 18.0 MHz, 43.3 kHz, 85.2 Hz (D)
    (II) NV(0): Modeline "320x240" 18.00 320 348 376 416 240 240 242 254 doublescan -hsync -vsync
    (**) NV(0): Default mode "320x240": 15.8 MHz, 37.5 kHz, 75.0 Hz (D)
    (II) NV(0): Modeline "320x240" 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync
    (**) NV(0): Default mode "320x240": 15.8 MHz, 37.9 kHz, 72.8 Hz (D)
    (II) NV(0): Modeline "320x240" 15.75 320 332 352 416 240 244 245 260 doublescan -hsync -vsync
    (**) NV(0): Default mode "320x240": 12.6 MHz, 31.5 kHz, 60.1 Hz (D)
    (II) NV(0): Modeline "320x240" 12.60 320 328 376 400 240 245 246 262 doublescan -hsync -vsync
    (**) NV(0): Default mode "360x200": 17.8 MHz, 37.9 kHz, 85.0 Hz (D)
    (II) NV(0): Modeline "360x200" 17.75 360 378 414 468 200 200 202 223 doublescan -hsync +vsync
    (**) NV(0): Default mode "320x200": 15.8 MHz, 37.9 kHz, 85.3 Hz (D)
    (II) NV(0): Modeline "320x200" 15.75 320 336 368 416 200 200 202 222 doublescan -hsync +vsync
    (**) NV(0): Default mode "320x175": 15.8 MHz, 37.9 kHz, 85.3 Hz (D)
    (II) NV(0): Modeline "320x175" 15.75 320 336 368 416 175 191 192 222 doublescan +hsync -vsync
    (**) NV(0): Display dimensions: (310, 230) mm
    (**) NV(0): DPI set to (83, 84)
    (II) Loading sub module "fb"
    (II) LoadModule: "fb"
    (II) Loading /usr/X11R6/lib/modules/libfb.a
    (II) Module fb: vendor="X.Org Foundation"
    ABI class: X.Org ANSI C Emulation, version 0.2
    (II) Loading sub module "xaa"
    (II) LoadModule: "xaa"
    (II) Loading /usr/X11R6/lib/modules/libxaa.a
    (II) Module xaa: vendor="X.Org Foundation"
    (II) Loading sub module "ramdac"
    (II) LoadModule: "ramdac"
    (II) Loading /usr/X11R6/lib/modules/libramdac.a
    (II) Module ramdac: vendor="X.Org Foundation"
    (--) Depth 24 pixmap format is 32 bpp
    (II) do I need RAC? No, I don't.
    (II) resource ranges after preInit:
    [0] 0 0 0xf0000000 - 0xf7ffffff (0x8000000) MX[B]
    [1] 0 0 0xe7000000 - 0xe7ffffff (0x1000000) MX[B]
    [2] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
    [3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
    [4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
    [5] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
    [6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
    [7] -1 0 0xe5000000 - 0xe5000fff (0x1000) MX[B]
    [8] -1 0 0xe5800000 - 0xe5800fff (0x1000) MX[B]
    [9] -1 0 0xe6000000 - 0xe6000fff (0x1000) MX[B]
    [10] -1 0 0xe6800000 - 0xe6800fff (0x1000) MX[B]
    [11] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
    [12] -1 0 0xeffe0000 - 0xefffffff (0x20000) MX[B](B)
    [13] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MX[B](B)
    [14] -1 0 0xe7000000 - 0xe7ffffff (0x1000000) MX[B](B)
    [15] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
    [16] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
    [17] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
    [18] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
    [19] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
    [20] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
    [21] -1 0 0x0000a000 - 0x0000a07f (0x80) IX[B]
    [22] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
    [23] -1 0 0x0000b400 - 0x0000b40f (0x10) IX[B]
    [24] -1 0 0x0000e600 - 0x0000e61f (0x20) IX[B]
    [25] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
    [26] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
    (==) NV(0): Write-combining range (0xf0000000,0x8000000)
    (II) NV(0): Using XFree86 Acceleration Architecture (XAA)
    Screen to screen bit blits
    Solid filled rectangles
    8x8 mono pattern filled rectangles
    Indirect CPU to Screen color expansion
    Solid Lines
    Scanline Image Writes
    Offscreen Pixmaps
    Setting up tile and stipple cache:
    32 128x128 slots
    32 256x256 slots
    16 512x512 slots
    (==) NV(0): Backing store disabled
    (==) NV(0): Silken mouse enabled
    (**) Option "dpms"
    (**) NV(0): DPMS enabled
    (==) RandR enabled
    (II) Initializing built-in extension MIT-SHM
    (II) Initializing built-in extension XInputExtension
    (II) Initializing built-in extension XTEST
    (II) Initializing built-in extension XKEYBOARD
    (II) Initializing built-in extension LBX
    (II) Initializing built-in extension XC-APPGROUP
    (II) Initializing built-in extension SECURITY
    (II) Initializing built-in extension XINERAMA
    (II) Initializing built-in extension XFIXES
    (II) Initializing built-in extension XFree86-Bigfont
    (II) Initializing built-in extension RENDER
    (II) Initializing built-in extension RANDR
    (II) Initializing built-in extension COMPOSITE
    (II) Initializing built-in extension DAMAGE
    (II) Initializing built-in extension XEVIE
    (**) Option "Protocol" "IMPS/2"
    (**) Mouse0: Device: "/dev/input/mice"
    (**) Mouse0: Protocol: "IMPS/2"
    (**) Option "CorePointer"
    (**) Mouse0: Core Pointer
    (**) Option "Device" "/dev/input/mice"
    (**) Option "Emulate3Buttons" "yes"
    (**) Mouse0: Emulate3Buttons, Emulate3Timeout: 50
    (**) Option "ZAxisMapping" "4 5"
    (**) Mouse0: ZAxisMapping: buttons 4 and 5
    (**) Mouse0: Buttons: 5
    (**) Option "CoreKeyboard"
    (**) Keyboard0: Core Keyboard
    (**) Option "Protocol" "standard"
    (**) Keyboard0: Protocol: standard
    (**) Option "AutoRepeat" "500 30"
    (**) Option "XkbRules" "xorg"
    (**) Keyboard0: XkbRules: "xorg"
    (**) Option "XkbModel" "abnt2"
    (**) Keyboard0: XkbModel: "abnt2"
    (**) Option "XkbLayout" "br"
    (**) Keyboard0: XkbLayout: "br"
    (**) Option "CustomKeycodes" "off"
    (**) Keyboard0: CustomKeycodes disabled
    (II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD)
    (II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
    (II) Mouse0: ps2EnableDataReporting: succeeded
    SetClientVersion: 0 8
    SetGrabKeysState - disabled
    SetGrabKeysState - enabled
    (==) RandR enabled
    (==) RandR enabled
    (==) RandR enabled
    (==) RandR enabled
    (==) RandR enabled
    (==) RandR enabled
    (==) RandR enabled
    (==) RandR enabled
    (==) RandR enabled
    (==) RandR enabled
    (==) RandR enabled
    (==) RandR enabled
    AUDIT: Tue Feb 8 13:32:28 2005: 2842 X: client 4 rejected from local host
    Auth name: MIT-MAGIC-COOKIE-1 ID: -1
    (==) RandR enabled
  1. nao consigo logar
    Por Sergio_ no fórum Assuntos não relacionados
    Respostas: 6
    Último Post: 13-05-2005, 13:59
  2. Não Consigo Logar no PDC
    Último Post: 11-05-2004, 15:57
  3. Não consigo iniciar em modo grafico (KDE)
    Por ricardodru no fórum Servidores de Rede
    Último Post: 06-11-2003, 07:13
  4. Não consigo logar com DHCP depois que migrei do w2k pro win9
    Por ThE_PuNiShEr no fórum Servidores de Rede
    Último Post: 07-08-2003, 12:48
  5. Nao consigo entrar em modo grafico
    Último Post: 28-12-2002, 20:43
