    brunow
    Padrão dns funciona localmente mas nao resolve
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    // query-source address * port 53;
    dump-file "/var/named/dump/named_dump.db";
    statistics-file "/var/named/dump/named.stats";
    memstatistics-file "/var/named/dump/named.memstats";
    // remove this next line if you want named to listen on
    // all available interfaces, or adjust add new ones as
    // you see fit
    listen-on { 127.0.0.1/32; };
    // a caching only nameserver config
    zone "." {
    type hint;
    file "named.ca";
    zone "0.0.127.in-addr.arpa" {
    type master;
    file "named.local";
    zone "0.168.192.in-addr.arpa"{
    type master;
    file "/var/named/192.168.0.rev";
    zone "empresa.com.br" {
    type master;
    file "/var/named/empresa.com.br";
    /var/named/name.local
    @ IN SOA servidor.empresa.com.br. root.empresa.com.br. (
    20050121 ; Serial
    3600 ; Refresh
    900 ; Retry
    1209600 ; Expire
    43200 ) ; Minimum
    @ IN NS servidor.empresa.com.br.
    1 IN PTR localhost.
    /var/named/192.168.rev
    $TTL 43200
    20050122
    3600
    900
    1209600
    43200 )
    1 IN PTR servidor.empresa.com.br.
    $TTL 86400
    20050122 ; serial;
    3600 ; refresh
    900 ; retry
    1209600 ; expire
    43200 ; default_ttl
    servidor.empresa.com.br. IN A 192.168.0.1
    www IN CNAME empresa.com.br.
    meu log
    Jan 24 11:13:53 renata named[7120]: starting BIND 9.2.3 -u named -t /var/named
    Jan 24 11:13:53 renata named[7120]: using 1 CPU
    Jan 24 11:13:53 renata named[7120]: loading configuration from '/etc/named.conf'
    Jan 24 11:13:53 renata named[7120]: /etc/named.conf:15: option 'memstatistics-file' is not implemented
    Jan 24 11:13:53 renata named[7120]: no IPv6 interfaces found
    Jan 24 11:13:53 renata named[7120]: listening on IPv4 interface lo, 127.0.0.1#53
    Jan 24 11:13:53 renata named[7120]: command channel listening on 127.0.0.1#953
    Jan 24 11:13:53 renata named[7120]: named.local:1: no TTL specified; using SOA MINTTL instead
    Jan 24 11:13:53 renata named[7120]: zone 0.0.127.in-addr.arpa/IN: loaded serial 20050121
    Jan 24 11:13:53 renata named[7120]: zone 0.168.192.in-addr.arpa/IN: loaded serial 20050122
    Jan 24 11:13:53 renata named[7120]: zone empresa.com.br/IN: loaded serial 20050122
    Jan 24 11:13:53 renata named[7120]: running
    Bom galera estes são meus arquivos, meu problema é o seguinte.
    dou um ping www.empresa.com.br, ele não pinga se dou um
    host www.empresa.com.br ele me retornar
    Host www.linuxstar.com.br not found: 2(SERVFAIL)
    nslook
    > www.empresa.com.br
    Server: 200.204.0.10
    Address: 200.204.0.10#53
    ** server can't find www.empresa.com.br: NXDOMAIN
    alguem poderia me ajudar a resolver isto.
    i ae. galera esse poste foi de um amigo eu com base nessa configuracoes rodei o dns mas ele da o mesmo erro alguem conseguiu resolve isso pq ele nao posto o resultado Grato Bruno
    Padrão dns
    mude o listen-on para { 0.0.0.0; } e libera a porta 53 no seu firewall.
    karfax
    servidor.empresa.com.br. IN A 192.168.0.1 << Este deveria ser seu ip fixo, mas voce colocou um ip reservado para rede interna.
    www IN CNAME empresa.com.br. << isto está errado, feita a alteração acima, deveria resolver para um nome de host, não para o nome do domínio,
    www IN CNAME servidor.empresa.com.br.
    Sds,
    obrigado amigos ja resolvi esse problema agora estou com outro meu dns funciona tudo normal mas o reveso nao funciona fora da rede so dentro da rede pq sera ?
    Quem fornece teu link?? se for adsl eh residencial ou empresarial??
    falows
