    bouncer
    Padrão squid nao faz autenticao
    Problema no squid..seguinte ele...esta configurado pra autencacao..mais nao atentica...
    ele geral loga normal access.log
    que pode ser,,,eu uso slackware 10
    caixa de senha ele nao mostrar que pode ser
    root 1322 0.0 0.8 3596 1028 ? Ss 00:07 0:00 /usr/local/squid/sbin/squid start
    squid 1324 0.8 8.0 11920 10244 ? S 00:07 0:06 (squid) start
    squid 1325 0.0 0.2 1820 364 ? Ss 00:07 0:00 (ncsa_auth) /usr/local/squid/etc/passwd
    squid 1326 0.0 0.2 1820 364 ? Ss 00:07 0:00 (ncsa_auth) /usr/local/squid/etc/passwd
    squid 1327 0.0 0.2 1820 364 ? Ss 00:07 0:00 (ncsa_auth) /usr/local/squid/etc/passwd
    squid 1328 0.0 0.2 1820 364 ? Ss 00:07 0:00 (ncsa_auth) /usr/local/squid/etc/passwd
    squid 1329 0.0 0.2 1820 364 ? Ss 00:07 0:00 (ncsa_auth) /usr/local/squid/etc/passwd
    squid 1330 0.0 0.2 1316 268 ? Ss 00:07 0:00 (unlinkd)
    root 1348 0.0 0.6 2276 788 pts/0 R+ 00:22 0:00 ps aux
    http_port 3128
    icp_port 0
    cache_mem 100 MB
    cache_swap_low 95
    cache_swap_high 98
    maximum_object_size 61440 KB
    maximum_object_size_in_memory 4096 KB
    cache_dir ufs /usr/local/squid/var/cache 900 16 256
    cache_access_log /usr/local/squid/var/logs/access.log
    cache_store_log /usr/local/squid/var/logs/store.log
    cache_log /var/log/squid/cache.log
    emulate_httpd_log on
    log_fqdn on
    ftp_passive on
    refresh_pattern . 0 20% 4320
    #Defaults:
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 21 443 563 70 210 1025-65535
    acl CONNECT method CONNECT
    auth_param basic program /usr/local/squid/libexec/ncsa_auth /usr/local/squid/etc/passwd
    auth_param basic children 5
    auth_param basic realm Digite login e senha:
    auth_param basic credentialsttl 1 hours
    acl blacklist url_regex "/usr/local/squid/etc/blacklist"
    acl whitelist url_regex "/usr/local/squid/etc/whitelist"
    acl password proxy_auth "/usr/local/squid/etc/passwd"
    acl minharede src 192.168.0.0/255.255.255.0
    http_access allow manager localhost all
    http_access deny manager
    http_access deny !Safe_ports
    http_access deny blacklist
    http_access allow whitelist all
    http_access allow minharede
    http_access allow password
    http_access deny all
    icp_access allow all
    miss_access allow all
    cache_effective_user squid
    cache_effective_group squid
    httpd_accel_host virtual
    httpd_accel_port 80
    httpd_accel_with_proxy on
    visible_hostname proxy.ddd.com.br
    cache_mgr ddd
    error_directory /usr/local/squid/share/errors/Portuguese
    Padrão Re: squid nao faz autenticao
    Cara eu tenho algumas desconfianças no seu squid.conf mas o correto seria vc dar um squid -k check pra que ele te a lista de erros e as linhas onde elas se encontram, dai conseguimos encontrar rapidinho o problema!!!
    Valeu qualquer coisas post ai !!!!
    pedro_lemes
    O squid nao valida o acesso por usuario, mesmo que esteja configurado para proxy transparente. Pra conseguir validar por usuario (login), vc deve configurar o navegador do cliente pra olhar o ip e porta do seu proxy.
    No caso do Internet Explorer:
    Va no menu FERRAMENTAS->OPCOES. Depois vá ate a aba CONEXOES e clique no botao CONFIGURACOES DA LAN.
    Marque a opcao USAR UM SERVIDOR PROXY..., digite o IP do seu proxy squid no campo ENDERECO e o numero da porta no campo PORTA. (no seu caso, é a 3128).
    É fazer e funcionar.
    um abraco.
    bouncer
    Padrão afff
    cara ja fiz isso..e mesmo coisa..nada de nada
    Padrão Re: afff
    Vc naum esta usando proxy transparente né? ce tiver infelizmente não irá funcionar a autenticação!!
    vc ja fez o squid -k que o gatoseco passou para vc fazer?
    Citação Postado originalmente por bouncer
