  1. O que há de errado com o meu squid.conf. O squid inicializa, o cache.log não registra nada de erro e o access.log não registra nada, tá vazio....
    segue abaixo o meu squid.conf
    http_port 3128
    icp_port 3130
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    cache_mem 64 MB
    memory_replacement_policy lru
    cache_dir ufs /var/spool/squid 4000 24 256
    auth_param basic children 5
    auth_param basic realm Squid proxy-caching web server
    auth_param basic credentialsttl 2 hours
    refresh_pattern . 0 20% 4320
    acl all src 0.0.0.0/0.0.0.0
    acl rede src 192.168.0.0/255.255.255.0
    acl adsl src 192.168.1.0/255.255.255.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    acl sites dstdomain "/etc/squid/sites.denied"
    acl ban url_regex -i "/etc/squid/ban.lst"
    acl noban url_regex -i "/etc/squid/noban.lst"
    http_access deny sites
    http_access deny ban !noban
    http_access allow rede
    http_access allow adsl
    http_access allow localhost
    http_access deny all
    http_reply_access allow all
    icp_access allow all
    visible_hostname e3corr.e3corr.com.br
    httpd_accel_port 80
    httpd_accel_host virtual
    httpd_accel_with_proxy on
    error_directory /etc/squid/errors
    coredump_dir /var/spool/squid
    e este é o cache.log:
    5/02/25 15:44:43| Squid Cache (Version 2.5.STABLE1): Exiting normally.
    2005/02/25 15:44:45| Starting Squid Cache version 2.5.STABLE1 for i386-redhat-linux-gnu...
    2005/02/25 15:44:45| Process ID 2520
    2005/02/25 15:44:45| With 1024 file descriptors available
    2005/02/25 15:44:45| DNS Socket created at 0.0.0.0, port 32790, FD 5
    2005/02/25 15:44:45| Adding nameserver 192.168.0.1 from /etc/resolv.conf
    2005/02/25 15:44:45| Adding nameserver 200.180.128.68 from /etc/resolv.conf
    2005/02/25 15:44:45| Adding nameserver 200.199.241.17 from /etc/resolv.conf
    2005/02/25 15:44:45| Unlinkd pipe opened on FD 10
    2005/02/25 15:44:45| Swap maxSize 4096000 KB, estimated 315076 objects
    2005/02/25 15:44:45| Target number of buckets: 15753
    2005/02/25 15:44:45| Using 16384 Store buckets
    2005/02/25 15:44:45| Max Mem size: 65536 KB
    2005/02/25 15:44:45| Max Swap size: 4096000 KB
    2005/02/25 15:44:45| Rebuilding storage in /var/spool/squid (CLEAN)
    2005/02/25 15:44:45| Using Least Load store dir selection
    2005/02/25 15:44:45| Set Current Directory to /var/spool/squid
    2005/02/25 15:44:45| Loaded Icons.
    2005/02/25 15:44:46| Accepting HTTP connections at 0.0.0.0, port 3128, FD 11.
    2005/02/25 15:44:46| Accepting ICP messages at 0.0.0.0, port 3130, FD 12.
    2005/02/25 15:44:46| WCCP Disabled.
    2005/02/25 15:44:46| Ready to serve requests.
    2005/02/25 15:45:09| Done scanning /var/spool/squid swaplog (0 entries)
    2005/02/25 15:45:09| Finished rebuilding storage from disk.
    2005/02/25 15:45:09| 0 Entries scanned
    2005/02/25 15:45:09| 0 Invalid entries.
    2005/02/25 15:45:09| 0 With invalid flags.
    2005/02/25 15:45:09| 0 Objects loaded.
    2005/02/25 15:45:09| 0 Objects expired.
    2005/02/25 15:45:09| 0 Objects cancelled.
    2005/02/25 15:45:09| 0 Duplicate URLs purged.
    2005/02/25 15:45:09| 0 Swapfile clashes avoided.
    2005/02/25 15:45:09| Took 23.4 seconds ( 0.0 objects/sec).
    2005/02/25 15:45:09| Beginning Validation Procedure
    2005/02/25 15:45:09| Completed Validation Procedure
    2005/02/25 15:45:09| Validated 0 Entries
    2005/02/25 15:45:09| store_swap_size = 0k
    2005/02/25 15:45:10| storeLateRelease: released 0 objects
  2. Deixa teu conf assim:
    Código :
    no_cache deny QUERY
    auth_param basic realm spectrum
    acl Safe_ports port 20
    acl Safe_ports port 25
    http_access deny manager
    http_access deny !Safe_ports
    apague o access.log cache.log e store.log restart o squid e teste
    falows
  3. fiz como tu disse, e continua a mesma coisa...
    não entendo o pq...
  4. Só não entendí uma coisa.. pq vc diz que teu squid tá errado? não inicia?
    qual as msgs de erro?
    buribai
    kra ,
    vc criou os diretorios de cache ???
    Pode ser isso ???
  1. O que há de errado nas configurações abaixo:
    Por JulianoVB no fórum Redes
    Último Post: 11-08-2014, 09:45
  2. O que há de errado nesta validação de login
    Por triplox no fórum Linguagens de Programação
    Último Post: 05-06-2009, 23:43
  3. O que há de errado nesse script?????
    Por analistaslack no fórum Linguagens de Programação
    Respostas: 15
    Último Post: 28-12-2006, 18:15
  4. O que há de errado com esta ACL
    Por cvr no fórum Servidores de Rede
    Último Post: 06-10-2006, 08:47
  5. Squid. O que tem de errado?
    Por jadirorza no fórum Servidores de Rede
    Respostas: 22
    Último Post: 16-07-2005, 15:21
