    Padrão meu snort ta varrendo tudo..
    e ae galera, eu ja instalei e configurei o snort, ta tudo ok, so que ele ta varrendo tudo, e so queria q ele olhasse a interface ppp0. alguem pode me ajudar?
    uso debian 3.0 rc2
    snort 2.3
    posta o meu snort.conf
    #preprocessor portscan: $EXTERNAL_NET 4 3 portscan.log
    var EXTERNAL_NET any
    var HOME_NET 192.168.0.0/24
    # Set up the external network addresses as well. A good start may be "any"
    var EXTERNAL_NET !$HOME_NET
    preprocessor portscan-ignorehosts: 192.168.0.0/24
    # Configure your server lists. This allows snort to only look for attacks to
    # systems that have a service up. Why look for HTTP attacks if you are not
    # running a web server? This allows quick filtering based on IP addresses
    # These configurations MUST follow the same configuration scheme as defined
    # above for $HOME_NET.
    # List of DNS servers on your network
    var DNS_SERVERS $HOME_NET
    # List of SMTP servers on your network
    var SMTP_SERVERS $HOME_NET
    # List of web servers on your network
    var HTTP_SERVERS $HOME_NET
    # List of sql servers on your network
    var SQL_SERVERS $HOME_NET
    # List of telnet servers on your network
    var TELNET_SERVERS $HOME_NET
    # List of snmp servers on your network
    var SNMP_SERVERS $HOME_NET
    var HTTP_PORTS 80
    # Ports you want to look for SHELLCODE on.
    var SHELLCODE_PORTS !80
    # Ports you do oracle attacks on
    var ORACLE_PORTS 1521
    # other variables
    # AIM servers. AOL has a habit of adding new AIM servers, so instead of
    # modifying the signatures when they do, we add them to this list of servers.
    var AIM_SERVERS [64.12.24.0/24,64.12.25.0/24,64.12.26.14/24,64.12.28.0/24,64.12.29.0/24,64.12.161.0/24,64.12.163.0/24,205.188.5.0/24,205.188.9.0/24]
    # Path to your rules files (this can be a relative path)
    # Note for Windows users: You are advised to make this an absolute path,
    # such as: c:\snort\rules
    var RULE_PATH /etc/snort/rules
    preprocessor flow: stats_interval 0 hash 2
    preprocessor frag2
    preprocessor stream4: disable_evasion_alerts detect_scans
    preprocessor stream4_reassemble
    # http_inspect: normalize and detect HTTP traffic and protocol anomalies
    # lots of options available here. See doc/README.http_inspect.
    # unicode.map should be wherever your snort.conf lives, or given
    # a full path to where snort can find it.
    preprocessor http_inspect: global iis_unicode_map unicode.map 1252
    preprocessor http_inspect_server: server default profile all ports { 80 8080 8180 } oversize_dir_length 500
    preprocessor rpc_decode: 111 32771
    preprocessor bo
    preprocessor telnet_decode
    output log_tcpdump: tcpdump.log
    postei o principal
    fico no aguardo.
    muda isso ae pra interface q vc quer q ele olhe
    blz vou fazer isso agora, eu to usando esse comando pra start o snort
    /usr/local/bin/snort -u snort -g snort -D -c /etc/snort/snort.conf -l /var/log/snort/
    so quando do um ps aux n vejo nem um processo do snort rodando :roll:
    dps da uma olhada nos artigos aki do site q tem uma artigo do snort q eu fiz pra ele nao ficar jogando tudo qto ehlixo no log.... eh uma versao antiga mas a conf deve ser a mesma
    Citação Postado originalmente por 1c3_m4n
    já dei uma olhada vlw,
    to com alguma duvidas, os comandos pra gerenciar, por exmplo
    se eu digito snort -v -i ppp0 ele mostra em tempo real o trafico da rede, mas ao digitar
    não me retonar nada, como eu sei se ele ta funcionando do jeito que eu quero?
    pois no ps aux n mostra nada de snort
    vlw pela ajuda
    obrigado a todos
    no ps nao ta mostrando nada????? xiiii
    olha no logs dele se ele ta iniciando certinho
    Mar 9 15:28:48 firewall snort: Initializing daemon mode
    Mar 9 15:28:48 firewall snort: PID path stat checked out ok, PID path set to /var/run/
    Mar 9 15:28:48 firewall snort: Writing PID "18019" to file "/var/run//snort_eth0.pid"
    Mar 9 15:28:48 firewall snort: Parsing Rules file /etc/snort/snort.conf
    Mar 9 15:28:48 firewall snort: FATAL ERROR: ERROR /etc/snort/snort.conf(50): Couldn't resolve hostname ppp0
    e agora?
    EXTERNAL_NET coloca any de novo e startei, agora apareceu isso
    Mar 9 15:33:27 firewall snort: Writing PID "18030" to file "/var/run//snort_eth0.pid"
    Mar 9 15:33:27 firewall snort: Parsing Rules file /etc/snort/snort.conf
    Mar 9 15:33:27 firewall snort: ,-----------[Flow Config]----------------------
    Mar 9 15:33:27 firewall snort: | Stats Interval: 0
    Mar 9 15:33:27 firewall snort: | Hash Method: 2
    Mar 9 15:33:27 firewall snort: | Memcap: 10485760
    Mar 9 15:33:27 firewall snort: | Rows : 4099
    Mar 9 15:33:27 firewall snort: | Overhead Bytes: 16400(%0.16)
    Mar 9 15:33:27 firewall snort: `----------------------------------------------
    Mar 9 15:33:27 firewall snort: FATAL ERROR: /etc/snort/snort.conf(293) => Unable to open the IIS Unicode Map file '/etc/snort/unicode.map'.
    ajeitei, agora ele ta rodando blz, so falta alguem me fala qual eh o parametro no snort.conf para ele so varre a interface ppp0
    putz vc ta usando modem neh, volta teu external_net pra any....
    aheuhaueh deu lag aki, minha msg saiu 3h dps
    baum achei meu artigo: http://www.linuxit.com.br/section-viewarticle-149.html
    se vc ta iniciando ele com a opcao -i ppp0, ele soh ta varrendo essa interface
    Acho legal voce por pra logar em uma base mysql e usar um snortreporter para ver as saidas fica mto mais facil
    falows
