    Moderador Avatar de Bruno
    Nov 2002
    Guarapuava-PR
    Padrão squid com kernel
    galera eu uso slackware 10.1 tive que recompilar o kernel para que o mesmo reconheça mais de 1gb de memoria ram
    depois de compilado ele naum instala o squid
    alguem sabe pq
    da o seguinte erro quando executo o comando make
    Making all in lib
    make[1]: Entering directory `/squid/squid-2.5.STABLE7/lib'
    source='Array.c' object='Array.o' libtool=no \
    depfile='.deps/Array.Po' tmpdepfile='.deps/Array.TPo' \
    depmode=gcc3 /bin/sh ../cfgaux/depcomp \
    gcc -DHAVE_CONFIG_H -I. -I. -I../include -I../include -I../include -g -O2 -Wall -c `test -f Array.c || echo './'`Array.c
    In file included from /usr/include/bits/posix1_lim.h:153,
    from /usr/include/limits.h:144,
    from /usr/lib/gcc-lib/i486-slackware-linux/3.3.4/include/limits.h:122,
    from /usr/lib/gcc-lib/i486-slackware-linux/3.3.4/include/syslimits.h:7,
    from /usr/lib/gcc-lib/i486-slackware-linux/3.3.4/include/limits.h:11,
    from /usr/include/sys/param.h:22,
    from ../include/util.h:48,
    from Array.c:52:
    /usr/include/bits/local_lim.h:36:26: linux/limits.h: No such file or directory
    In file included from ../include/util.h:48,
    from Array.c:52:
    /usr/include/sys/param.h:23:26: linux/limits.h: No such file or directory
    /usr/include/sys/param.h:24:25: linux/param.h: No such file or directory
    In file included from /usr/include/sys/socket.h:35,
    from /usr/include/netinet/in.h:24,
    from /usr/include/netdb.h:28,
    from ../include/util.h:51,
    from Array.c:52:
    /usr/include/bits/socket.h:304:24: asm/socket.h: No such file or directory
    make[1]: *** [Array.o] Error 1
    make[1]: Leaving directory `/squid/squid-2.5.STABLE7/lib'
    make: *** [all-recursive] Error 1
    qual o kernel que vc esta usando?
    Nov 2002
    Guarapuava-PR
    2.6.10
    Bom...eu tenho o slackware 10.0..kernel 2.4.26, compilei o squid 2.5 numa boa...e antes de instalar o squid eu ja tinha recompilado o kernel pra usar usb, memoria..etc. Nao tive problemas.
    A um tempo eu tentei usar o kernel 2.6.10 e nao tive bons resultados...no seu caso pode estar havendo imcompatibilidade de versao...tenta o squid 3.0...é uma alternativa mais rapida e menos trabalhosa.
    Nov 2002
    Guarapuava-PR
    é eu tinha instalado o slackware 10.1 dai mudei para o kernel 2.6.10
    agora eu to reinstalando o slackware 20 e vou instalar outro kernel
    compile um kernel que realmente esta estavel...leia a documentacao do squid que vc esta instalando pra ver se e compativel com seu kernel...sempre acontece essas incompatibilidade com o lancamento do novo kernel...
    por exemplo: o kernel 2.4.26 nao funcina legal com o squid 3.0PRE, da um erro de memory pools. ai instalei o squid 2.5 e resolveu o problema.
    Nov 2002
    Guarapuava-PR
    eu instalei o slackware 10.0 e o kernel 2.4.29 ja ta tudo rodando menos o iptables
    eu ja habilitei e nada
    Nov 2002
    Guarapuava-PR
    eu ja habilitei e o iptables e nada
