    winck
    nao estou conseguindo instalar o amsn, tenho pouca experiencia em linux, e gostaria q alguem me ajudace...
    obrigado!!
  2. se vc nao falar oq ta dando de errado ninguem vai poder te ajudar...
    winck
    [root@tstlinux root]# ls
    amsn-0_94 Desktop smb.conf vsftpd-1.2.0
    amsn-0_94.tar.gz install.log upgrade.log vsftpd-1.2.0.tar.gz
    anaconda-ks.cfg install.log.syslog upgrade.log.syslog vsftpd-1.2.0.tar.gz.1
    [root@tstlinux root]# cd amsn-0_94
    [root@tstlinux amsn-0_94]# ls
    abook.tcl blocking.tcl GNUGPL migmd5.tcl remote.tcl
    alarm.tcl chatwindow.tcl groups.tcl mutex.tcl skins
    amsn combobox.tcl gui.tcl notes.tcl skins.tcl
    amsn.debianmenu config.tcl HELP plugins smileys.tcl
    amsn.desktop CREDITS hotmail.tcl plugins.tcl sndplay
    amsn-remote ctadverts.tcl hotmlog.htm png.tcl socks.tcl
    amsn-remote-CLI ctthemes.tcl icons preferences.tcl sxml.tcl
    amsn.spec cvs_date lang progressbar.tcl TODO
    anigif.tcl des.tcl langlist protocol.tcl trayicon.tcl
    AppMain.tcl dock.tcl lang.tcl proxy.tcl utils
    automsg.tcl docs loging.tcl README xmms.tcl
    balloon.tcl FAQ Makefile remote.help
    [root@tstlinux amsn-0_94]# ./amsn
    /usr/bin/env: wish: Arquivo ou diretório não encontrado
  4. se vc olhar na documentacao dele ou mesmo no site no FAQ vc vai ver que eh necessario instalar o tcl e o tk pra rodar o amsn...
    sem eles nao existe o comando wish q vai rodar o msn
    winck
    [root@tstlinux unix]# ls
    aclocal.m4 install-sh tclLoadDl.c tclUnixChan.c tclUnixSock.c
    confdefs.h ldAix tclLoadDld.c tclUnixEvent.c tclUnixTest.c
    config.cache Makefile.in tclLoadDyld.c tclUnixFCmd.c tclUnixThrd.c
    config.log README tclLoadNext.c tclUnixFile.c tclUnixThrd.h
    configure tclAppInit.c tclLoadOSF.c tclUnixInit.c tclUnixTime.c
    configure.in tclConfig.sh.in tclLoadShl.c tclUnixNotfy.c tclXtNotify.c
    dltest tclLoadAix.c tcl.m4 tclUnixPipe.c tclXtTest.c
    installManPage tclLoadAout.c tcl.spec tclUnixPort.h
    [root@tstlinux unix]# ./configure
    loading cache ./config.cache
    checking whether to use symlinks for manpages... no
    checking whether to compress the manpages... no
    checking whether to add a package name suffix for the manpages... no
    checking for gcc... no
    checking for cc... no
    configure: error: no acceptable cc found in $PATH
  1. problemas para instalar o apache !!!!!!
    Por noir no fórum Servidores de Rede
    Respostas: 18
    Último Post: 20-07-2004, 15:41
  2. Problemas para Instalar pacotes perl para o amavis
    Por moon_knight no fórum Servidores de Rede
    Último Post: 24-06-2004, 19:24
  3. Problema para instalar o Amavis no RedHat
    Por bestwest no fórum Servidores de Rede
    Respostas: 9
    Último Post: 19-02-2004, 09:11
  4. Problemas para instalar o PPTP(.tar.gz)! Não compila nada!
    Por LinuxAthos no fórum Servidores de Rede
    Último Post: 04-08-2003, 08:09
  5. Problema para instalar o openssh
    Último Post: 22-11-2002, 14:06
