    Padrão login ssh
    amigos editei o /etc/sshd_config para tentar só 2 vezes login, usei MaxStartups 2
    o q esta errado?
    Padrão login ssh
    #man sshd_config
    MaxStartups
    Specifies the maximum number of concurrent unauthenticated con-
    nections to the sshd daemon. Additional connections will be
    dropped until authentication succeeds or the LoginGraceTime
    expires for a connection. The default is 10.
    MaxAuthTries
    Specifies the maximum number of authentication attempts permitted
    per connection. Once the number of failures reaches half this
    value, additional failures are logged. The default is 6.
    http://www.openbsd.org/cgi-bin/man.c...ry=sshd_config
    Padrão login ssh
    so valeu 1c3_m4n, nao tinha encontrado essa opção MaxAuthTries
    obrigado
    Padrão login ssh
    tentei colocar sua opção, mas nao funcionou
    parece o seguinte erro:
    /etc/ssh/sshd_config: line 39: Bad configuration option: MaxAuthTries
    /etc/ssh/sshd_config: terminating, 1 bad configuration options
    estou usando o slack 10 com o OpenSSH_3.8.1p1
    o que pode ser ?
