    garupeiro
    Padrão Alguem mande um yum.conf d presente
    Ae galera gostaria se saber se alguem tem o yum.conf do FC3 ja com bastante repositorios e tal se alguem tiver se pode me passar ele??? ops:
    posta no vivaolinux que a galera ajuda!
    aqui niguem ajuda e nada la pelo menos tem varios artigos e tutoriais aki nao ta com nada nao
    www.vivaolinux.com.br
    Underlinux SUX aki e muita panelinha.... :@:
    garupeiro
    Como o Amigo Visitante disse acabei achando la no vivaolinux o yum.conf com bastante repositorios
    # This is a yum.conf for Fedora Core 3.
    # It uses Fedora mirrors to make things faster,
    # since the main Red Hat Fedora site is pretty slow.
    # Also, if you look down in the "Alternate Repositories"
    # section, you'll notice some disabled repositories.
    # If you want to use them, just do:
    # yum --enablerepo <reponame> <command>
    # Where <reponame> is the name of the repo, and <command>
    # is your normal yum command.
    # Authors:
    # Maxwell Kanat-Alexander (max at fedorafaq dot org)
    # Sindre Pedersn Bjørdal (foolish at fedorafaq dot org)
    # Date: 6 February 2005
    # Changes
    # 6 February 2005
    # + Fedora Extras!
    # + Dries Mirrors
    # + Fixed a Livna mirror.
    # 26 November 2004
    # + Updated ATrpms per Axel Thimm's request.
    # 22 November 2004
    # + Updated for Fedora Core 3
    # 04 November 2004
    # + Fixed and checked-over for publishing
    # 17 July 2004 (Sindre)
    # + Replaced Base, debug, updates-released and updates mirrors with faster ones.
    # + Added the official servers to base and updates, commented of course.
    # + Tested all non-commented parts, everything works.
    # 29 May 2004
    # + Tested commented-out parts: all work except subpop.net
    # + Livna and NewRPMs mirrors!
    # 22 May 2004
    # + Incorporated Darrenn's fixes for Fedora Core 2!
    # + Commented-out parts may still not work properly
    # 29 Feb 2004
    # + Updated a lot of mirrors, for speed
    # + Fixed one ATrpms mirror
    # + Added Dries and spc, two more FreshRPMs-compatible repos
    # 9 Jan 2004
    # + Updated ATrpms for their new directory structure.
    # 31 Dec 2003
    # + Added JPackage, commented out
    # + Standard Red Hat Fedora Core sites commented-out by default
    # + Removed dulug from debug, since it doesn't have debug
    # 29 Dec 2003
    # + Added mirrors for the flash-plugin, since some go down.
    # + Added base-debuginfo, commented out
    [main]
    cachedir=/var/cache/yum
    debuglevel=2
    logfile=/var/log/yum.log
    pkgpolicy=newest
    distroverpkg=fedora-release
    tolerant=1
    exactarch=0
    # Added this because some mirrors go down and then retying takes forever.
    retries=1
    timeout=10
    # Basic Repos are in /etc/yum.conf.d/ #
    ## Fedora Extras ##
    [extras]
    name=Fedora Extras - $releasever - $basearch
    baseurl=http://fr2.rpmfind.net/linux/fedora/extras/$releasever/$basearch/
    http://mirrors.kernel.org/fedora/extras/$releasever/$basearch/
    http://mirror.hiwaay.net/redhat/fedora/linux/extras/$releasever/$basearch/
    http://www.mirrorservice.org/sites/download.fedora.redhat.com/pub/fedora/linux/extras/$releasever/$basearch/
    # http://download.fedora.redhat.com/pub/fedora/linux/extras/$releasever/$basearch/
    gpgcheck=0
    gpgkey=http://download.fedora.redhat.com/pub/fedora/linux/extras/RPM-GPG-KEY-Fedora-Extras
    ## Livna.org ##
    [livna-stable]
    name=Livna.org - Fedora Compatible Packages (stable)
    baseurl=http://rpm.livna.org/fedora/$releasever/$basearch/RPMS.stable
    http://livna.cat.pdx.edu/fedora/$releasever/$basearch/RPMS.stable
    #gpgcheck=1
    [livna-unstable]
    name=Livna.org - Fedora Compatible Packages (unstable)
    baseurl=http://rpm.livna.org/fedora/$releasever/$basearch/RPMS.unstable
    http://livna.cat.pdx.edu/fedora/$releasever/$basearch/RPMS.unstable
    #gpgcheck=1
    [livna-testing]
    name=Livna.org - Fedora Compatible Packages (testing)
    baseurl=http://rpm.livna.org/fedora/$releasever/$basearch/RPMS.testing
    http://livna.cat.pdx.edu/fedora/$releasever/$basearch/RPMS.testing
    #gpgcheck=1
    # Jpackage #
    # JPackage is a GREAT repository for Java Software.
    # However, you may have to compile some SRPMs to use it,
    # so it's commented out by default. See
    # <http://mirrors.sunsite.dk/jpackage/1...on-free/SRPMS>
    # For the SRPMs, and <http://www.jpackage.org/rebuilding.php> for
    # the general details.
    # Note: JPackage IS compatible with the fedora.us repositories.
    # You can use JPackage and fedora.us at the same time, without
    # any trouble. It's also compatible with the Alternate Repositories,
    # for the most part.
    [jpackage-generic]
    name=JPackage Cross-Platform Packages
    baseurl=http://mirrors.sunsite.dk/jpackage/1.6/generic/free
    ftp://jpackage.hmdc.harvard.edu/JPac...6/generic/free
    http://sunsite.informatik.rwth-aache...6/generic/free
    failovermethod=priority
    enabled=0
    #gpgcheck=1
    [jpackage-fedora]
    name=JPackage Fedora Packages
    baseurl=http://mirrors.sunsite.dk/jpackage/1.6/fedora-$releasever/free
    ftp://jpackage.hmdc.harvard.edu/JPackage/1.6/fedora-$releasever/free
    http://sunsite.informatik.rwth-aachen.de/ftp/pub/Linux/jpackage/1.6/fedora-$releasever/free
    enabled=0
    #gpgcheck=1
    ## Alternate Repositories ##
    # To use these repos, either use the --enablerepo
    # command-line argument to yum, or change "enabled=0"
    # to "enabled=1". Note: Some packagesfrom these repositories
    # may conflict with the fedora.us packages. If you use these
    # repositories, you may wish to disable the fedora.us and
    # livna.org repositories.
    [freshrpms]
    name=FreshRPMs
    mirrorlist=http://ayo.freshrpms.net/fedora/linux/$releasever/mirrors-freshrpms
    enabled=0
    #gpgcheck=1
    [dag]
    name=Dag APT Repository
    baseurl=http://dag.freshrpms.net/fedora/$releasever/en/$basearch/dag/
    http://dag.atrpms.net/fedora/$releasever/en/$basearch/dag/
    http://ftp.heanet.ie/pub/freshrpms/pub/dag/fedora/$releasever/en/$basearch/dag/
    enabled=0
    #gpgcheck=1
    [dries]
    name=Dries APT/YUM Repository
    baseurl=http://ftp.freshrpms.net/pub/dag/dries/fedora/linux/$releasever/$basearch/dries/RPMS/
    http://mirrors.ircam.fr/pub/dag/dries/fedora/linux/$releasever/$basearch/dries/RPMS/
    http://apt.sw.be/dries/fedora/linux/$releasever/$basearch/dries/RPMS/
    http://dries.studentenweb.org/yum/fedora/linux/$releasever/$basearch/dries/RPMS/
    enabled=0
    #gpgcheck=1
    [newrpms]
    name=NewRPMs
    baseurl=http://newrpms.sunsite.dk/apt/redhat/en/$basearch/fc$releasever
    http://newrpms.atrpms.net/apt/redhat/en/$basearch/fc$releasever
    enabled=0
    #gpgcheck=1
    [atrpms]
    name=ATrpms - Stable
    baseurl=http://apt.atrpms.net/fedora/$releasever/en/$basearch/at-stable
    http://ftp-stud.fht-esslingen.de/atrpms/download.atrpms.net/fedora/$releasever/en/$basearch/at-stable
    http://wftp.tu-chemnitz.de/pub/linux/ATrpms/fedora/$releasever/en/$basearch/at-stable
    enabled=0
    #gpgcheck=1
    [atrpms-testing]
    name=ATrpms - Testing
    baseurl=http://wftp.tu-chemnitz.de/pub/linux/ATrpms/fedora/$releasever/en/$basearch/at-testing
    http://apt.atrpms.net/fedora/$releasever/en/$basearch/at-testing
    http://ftp-stud.fht-esslingen.de/atrpms/download.atrpms.net/fedora/$releasever/en/$basearch/at-testing
    enabled=0
    #gpgcheck=1
    # Warning: Don't enable this "bleeding" repo if you want stable software!
    [atrpms-bleeding]
    name=ATrpms - Bleeding
    baseurl=http://apt.atrpms.net/fedora/$releasever/en/$basearch/at-bleeding
    http://ftp-stud.fht-esslingen.de/atrpms/download.atrpms.net/fedora/$releasever/en/$basearch/at-bleeding
    http://wftp.tu-chemnitz.de/pub/linux/ATrpms/fedora/$releasever/en/$basearch/at-bleeding
    enabled=0
    #gpgcheck=1
    ## Miscellaneous ##
    # Semi-official Macromedia repository containing the flash-plugin rpm.
    [flash]
    name=macromedia.mplug.org - Flash Plugin
    baseurl=http://macromedia.mplug.org/apt/fedora/$releasever
    http://sluglug.ucsc.edu/macromedia/apt/fedora/$releasever
    http://ruslug.rutgers.edu/macromedia/apt/fedora/$releasever
    http://macromedia.rediris.es/apt/fedora/$releasever
    enabled=0
    #gpgcheck=1
    Foi tirado do site http://www.fedorafaq.org/samples/yum.conf
    Com a ajuda do site www.vivaolinux.com.br
    Valeu Galera pela ajuda ae e ta ai se alguem precisa de yum.conf este e bem legal... :clap:
    deixa d ser mane garupeiro....
    como eh q vc q soh faz cagada tem coragem d postar uma merda a mais como essa??
    tah doido??
    para pra pensar oreiudo.... vc sempre usa o portal, e ainda vem xingar os outros??
    vai pro vivaolinux entaum, pq d trairas e idiotas como vc, ninguem, principalmente o under, nao preciso
    vai tarde!!!! :@: :@: :@: :@: :@: :@:
    pra quem quiser conhecer o amigo visitante, q na verdade eh o proprio garupeiro.. olha aque o relatorio do ip do kra q postou xingando o under:
    garupeiro [ 105 Mensagens ] Pesquisar
    Visitante [ 3 Mensagens ] Pesquisar
    vaza 6) 6) 6) 6)
