    duker
    Tenho um conectiva 10 estou tentanto instalar o vmware 4.5.2 build 8848 mas aparece uma mensagem pedindo o diretório:
    "What is the location of the directory of C header files that match your
    running kernel? [/usr/src/linux/include]"
    o diretório existe normal mas tem um problema quando entro com o endereço dá essa outra mensagem :
    "The path "/usr/src/linux/include" is an existing directory, but it does not
    contain at least one of these directories "linux", "asm", "net" as expected."
    Na realidade têm os diretórios net linux porém o asm tem um monte ficando assim o conteúdo desse diretório:
    drwxrwxr-x 33 root root 4096 2004-06-17 16:50 ./
    drwxr-xr-x 19 root root 4096 2005-03-29 20:24 ../
    drwxrwxr-x 3 root root 4096 2005-03-29 20:23 acpi/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:23 asm-alpha/
    drwxrwxr-x 19 root root 4096 2005-03-29 20:23 asm-arm/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:23 asm-arm26/
    drwxrwxr-x 3 root root 4096 2005-03-29 20:23 asm-cris/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:23 asm-generic/
    drwxrwxr-x 6 root root 4096 2005-03-29 20:23 asm-h8300/
    drwxrwxr-x 11 root root 4096 2005-03-29 20:23 asm-i386/
    drwxrwxr-x 3 root root 4096 2005-03-29 20:23 asm-ia64/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:23 asm-m68k/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:24 asm-m68knommu/
    drwxrwxr-x 42 root root 4096 2005-03-29 20:24 asm-mips/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:24 asm-parisc/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:24 asm-ppc/
    drwxrwxr-x 3 root root 4096 2005-03-29 20:24 asm-ppc64/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:24 asm-s390/
    drwxrwxr-x 24 root root 4096 2005-03-29 20:24 asm-sh/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:24 asm-sparc/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:24 asm-sparc64/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:24 asm-um/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:24 asm-v850/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:24 asm-x86_64/
    drwxrwxr-x 15 root root 12288 2005-03-29 20:24 linux/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:24 math-emu/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:24 media/
    drwxrwxr-x 5 root root 4096 2005-03-29 20:24 net/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:24 pcmcia/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:24 rxrpc/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:24 scsi/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:24 sound/
    drwxrwxr-x 2 root root 4096 2005-03-29 20:24 video/
    A questão é que naum sei o que fazer pois tenho gcc, libgcc e o kernel-sources instalado, pois instalei o perfil desenvolvedor. Gostaria de saber é o que fazer e se alguém já passou por isso me ajude.
  2. tente entrar com o endereco "/usr/src/linux/" e nao ""/usr/src/linux/include"
    colocando ""/usr/src/linux/include" ele na verdade ta procurando a pasta ""/usr/src/linux/include/include", ai nao vai achar nunca
  1. Problemas com rede VMware server 2.0.2
    Por iudemar no fórum Servidores de Rede
    Respostas: 6
    Último Post: 29-09-2010, 10:26
  2. Problemas com horário - VMWARE 2
    Por TiagoRB no fórum Servidores de Rede
    Último Post: 07-04-2009, 12:51
  3. Problema com vmware
    Por duker no fórum Servidores de Rede
    Respostas: 8
    Último Post: 13-11-2005, 13:10
  4. Problemas com VMware
    Por Redy no fórum Servidores de Rede
    Respostas: 6
    Último Post: 27-09-2005, 13:22
  5. Problema com Vmware XP X Mandrake 10
    Por rcmdf no fórum Servidores de Rede
    Último Post: 10-06-2005, 01:37
