Ai galera, to com um problema que é o seguinte, eu to com um computador em plataforma Conectiva Linux 10, o qual eu coloquei em rede com outras máquinas em plataforma Windows, instalei o samba e configurei, depois disso o Conectiva consegue vixualizar todas as máquinas na rede no entanto nehuma máquina windows consegue ver o Linux. contudo tanto as máquinas Windows conseguem pingar o Linux quanto o Linux Consegue pingar as Windows. se alguém puder me ajudar fico grato. abaixo está a configuração do meu smb.conf. outra coisa é que eu não consegui achar o smbd
[global]
workgroup = SH3
server string = Samuel Linux
printcap name = cups
load printers = yes
printing = cups
log file = /var/log/samba/%m.log
max log size = 50
debug level = 1
security = SHARE
# encrypt passwords = yes
smb passwd file = /etc/samba/smbpasswd
username map = /etc/samba/smbusers
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
add machine script = /usr/sbin/adduser -n -r -g machines -c "Samba machine" -d /dev/null -s /bin/false %u
# see the smb.conf(5) manpage for other important backends, such as tdbsam and ldap
passdb backend = smbpasswd
#============================ Share Definitions ==============================
idmap uid = 16777216-33554431
idmap gid = 16777216-33554431
template shell = /bin/false
winbind use default domain = no
[homes]
comment = Home Directories
browseable = no
writable = yes
# Un-comment the following and create the netlogon directory for Domain Logons
; [netlogon]
; comment = Network Logon Service
; path = /home/netlogon
; guest ok = yes
; writable = no
; share modes = no
# Un-comment the following to provide a specific roving profile share
# the default is to use the user's home directory
;[Profiles]
; path = /home/profiles
; browseable = no
; guest ok = yes
# automatic printer driver download support
[print$]
path = /var/lib/samba/drivers
guest ok = yes
browseable = yes
read only = yes
; since this share is configured as read only, then we need
; a 'write list'. Check the file system permissions to make
; sure this account can copy files to the share. If this
; is setup to a non-root account, then it should also exist
; as a 'printer admin'
write list = root
[printers]
comment = All Printers
path = /var/spool/samba
browseable = no
# Set public = yes to allow user 'guest account' to print
guest ok = no
writable = no
printable = yes
printer admin = root
Citação
