    Padrão problemas no DNS
    Galera to tendo q confiurar um DNS pra eu poder terminar as configuraçoes do meu apache.Ta dando um erro e ele nao ta encontrando o DNS abaixo serguem respectivamente o db.meusite.com.br, o named e o resolv.conf
    ; BIND reverse data file for empty rfc1918 zone
    ; DO NOT EDIT THIS FILE - it is used for multiple zones.
    ; Instead, copy it, edit named.conf, and use that copy.
    $TTL 86400
    @ IN SOA leandro.com.br. root.leandro.com.br. (
    1 ; Serial
    604800 ; Refresh
    86400 ; Retry
    2419200 ; Expire
    IN NS samba.
    IN MX 10 mail.leandro.com.br
    leandro.com.br. IN A 192.168.1.11
    samba IN A 192.168.1.11
    www IN A CNAME 192.168.1.11
    named.conf
    // This is the primary configuration file for the BIND DNS server named.
    // Please read /usr/share/doc/bind9/README.Debian.gz for information on the
    // structure of BIND configuration files in Debian, *BEFORE* you customize
    // this configuration file.
    // If you are just adding zones, please do that in /etc/bind/named.conf.local
    include "/etc/bind/named.conf.options";
    // prime the server with knowledge of the root servers
    zone "." {
    type hint;
    file "/etc/bind/db.root";
    // be authoritative for the localhost forward and reverse zones, and for
    // broadcast zones as per RFC 1912
    zone "localhost" {
    type master;
    file "/etc/bind/db.local";
    zone "127.in-addr.arpa" {
    type master;
    file "/etc/bind/db.127";
    zone "0.in-addr.arpa" {
    type master;
    file "/etc/bind/db.0";
    zone "leandro.com.br" {
    type master;
    file "/etc/bind/db.leandro.com.br";
    // zone "com" { type delegation-only; };
    // zone "net" { type delegation-only; };
    // From the release notes:
    // Because many of our users are uncomfortable receiving undelegated answers
    "/etc/bind/named.conf" 53L, 1620C
    resolv.conf
    search
    #nameserver 192.168.1.1
    #nameserver 0.0.0.0
    nameserver 192.168.1.11
    Fico agradecido se alguem puder me ajudar.
    garupeiro
    tenta por assim no seu resolv.conf
    nameserver 127.0.01
    search leandro.com.br
    nao entendi pq vc pois assim mesmo a linha tando comentanda
    #nameserver 0.0.0.0
    IN NS samba.
    As 2 entradas acima estão erradas, pois:
    Não existe TLD chamado samba ( o ponto depois de samba define a entrtada como um Top Level Domain como .com ou .com.br) e em mail.leandro.com.br falta um ponto depois do TLD br - se voce não adicionar, o resolver vai acrescentar o $ORIGIN à extensão do nome de dominio, transformando em mail.leandro.com.br.leandro.com.br.
    Sds,
    8)
    Muito obrigado suas dicas resolveram o erro, agora vc poderia so me da mais uma informação, qdo eu rodo o nslookup ele ta dando o seguinte retorno
    > server samba
    Default server: samba
    Address: 192.168.1.12#53
    > www.leandro.com.br
    Server: samba
    ** server can't find www.leandro.com.br: SERVFAIL
    Isso o q pode haver de errado? Pois pelo q me parece ele ainda nao conseguiu resolver a o dns da minha maquina.
    Eu mudei o site q kero criar o dns e ww.lenadro.com.br, mudei e digite www.samba.com.br (samba é o nome da minha maquina) olha a resposta q eu obtive:
    > www.samba.com.br
    Server: samba
    Non-authoritative answer:
    Address: 200.157.179.151
    Alterei as configurações do arquivo db.leandro.com.br que estavam com um erro, ai consegui e seguinte resposta:
    > server samba
    > www.leandro.com.br
    ;; connection timed out; no servers could be reached
    Alguem faz ideia do q pode ser?
