    Padrão probemas com DNS
    Olá pessoal estou precisando da ajuda de vc's pois faz uns 15 dias que estou tentando configurar um servidor DNS local para testes mas nao estou conseguindo!
    peguei um exemplo e o adaptei mas nao consgi fazer fucionar!!!
    aki esta as configuracoes!
    host.conf
    order hosts,bind
    hosts
    # Do not remove the following line, or various programs
    # that require network functionality will fail.
    127.0.0.1 laboratorio.teste.com.br laboratorio localhost.localdomain localhost
    192.168.0.1 laboratorio.teste.com.br laboratorio
    named.conf
    // generated by named-bootconf.pl
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    // query-source address * port 53;
    // a caching only nameserver config
    controls {
    inet 127.0.0.1 allow { localhost; } keys { rndckey; };
    zone "." IN {
    type hint;
    file "named.ca";
    zone "localhost" IN {
    type master;
    file "localhost.zone";
    allow-update { none; };
    zone "teste.com.br" IN {
    type master;
    file "teste.com.br";
    zone "0.0.127.in-addr.arpa" IN {
    type master;
    file "named.local";
    zone "0.168.192.in-addr.arpa" IN {
    type master;
    file "0.168.192";
    include "/etc/rndc.key";
    named.local
    $TTL 86400
    @ IN SOA localhost. root.localhost. (
    1997022700 ; Serial
    28800 ; Refresh
    14400 ; Retry
    3600000 ; Expire
    86400 ) ; Minimum
    IN NS localhost.
    1 IN PTR localhost.
    localhost.zone
    $TTL 86400
    $ORIGIN localhost.
    @ 1D IN SOA @ root (
    42 ; serial (d. adams)
    3H ; refresh
    15M ; retry
    1W ; expiry
    1D ) ; minimum
    1D IN NS @
    1D IN A 127.0.0.1
    teste.com.br
    $TTL 86400
    @ IN SOA laboratorio.teste.com.br. root.teste.com.br. (
    2004101101 ; serial
    3H ; refresh
    30 ; retry
    70D ; expire
    30 ; default_ttl
    www IN CNAME laboratorio
    ftp IN CNAME laboratorio
    ;mail IN CNAME laboratorio
    pop IN CNAME laboratorio
    smtp IN CNAME laboratorio
    @ IN MX 5 laboratorio.teste.com.br.
    @ IN NS 10
    laboratorio IN A 192.168.0.1
    0.168.192
    $TTL 86400
    2004101101 ; serial
    3H ; refresh
    30 ; retry
    70D ; expire
    30 ; default_ttl
    @ IN NS laboratorio.teste.com.br.
    87 IN PTR laboratorio.teste.com.br.
    obs.: qdo ping www.teste.com.br ele me responde normal, mas qdo vou a uma estacao da rede ele nao da resposta!!!
    agradeço desde já a colaboraçao de todos
    ninguem pode me ajudar???
    gmlinux
    netstat -taunp
    olha se a porta 53 do udp e tcp esta subindo na interface desejada (ou 0.0.0.0)
    configura seus clientes para usar seu servidor de nomes
