    Padrão UEBIMIAU
    Estou tentado colocar o uebimiau pra func. num mandrake 9.2, mas naum consigo. Dá as seguintes mensagens qdo tento abrir ele:
    Warning: file_exists() [function.file-exists]: SAFE MODE Restriction in effect. The script whose uid is 0 is not allowed to access /tmp/uebimiau owned by uid 72 in /var/www/html/webmail1/smarty/Smarty.class.php on line 860
    Warning: file_exists() [function.file-exists]: SAFE MODE Restriction in effect. The script whose uid is 0 is not allowed to access /tmp/uebimiau owned by uid 72 in /var/www/html/webmail1/smarty/Smarty.class.php on line 1407
    Warning: file_exists() [function.file-exists]: SAFE MODE Restriction in effect. The script whose uid is 0 is not allowed to access /tmp/uebimiau owned by uid 72 in /var/www/html/webmail1/smarty/Smarty.class.php on line 1412
    Warning: mkdir() [function.mkdir]: SAFE MODE Restriction in effect. The script whose uid is 0 is not allowed to access /tmp/uebimiau owned by uid 72 in /var/www/html/webmail1/smarty/Smarty.class.php on line 1412
    Warning: Smarty error: problem creating directory "/tmp/uebimiau//_cached_templates/default" in /var/www/html/webmail1/smarty/Smarty.class.php on line 1543
    Warning: Smarty error: problem writing '/tmp/uebimiau//_cached_templates/default/login.php.' in /var/www/html/webmail1/smarty/Smarty.class.php on line 1543
    Warning: fetch(/tmp/uebimiau//_cached_templates/default/login.php) [function.fetch]: failed to create stream: No such file or directory in /var/www/html/webmail1/smarty/Smarty.class.php on line 633
    Warning: fetch() [function.fetch]: Failed opening '/tmp/uebimiau//_cached_templates/default/login.php' for inclusion (include_path='.:/usr/share/pear') in /var/www/html/webmail1/smarty/Smarty.class.php on line 633
    Help me! Valews
    Padrão UEBIMIAU
    buribai
    Padrão UEBIMIAU
    Bicho, remove ele e instala tudo novamente ....
    buribai
    Padrão UEBIMIAU
    Não esquece de limpar os arquivos temporarios ...
