Ai vai uma otima configuração do smb.conf teste!!!acho que esta bem explicada ideal para iniciante.
[global]
# workgroup = Nome do grupo
workgroup = LINUX
# Comentario do compartilhamento
server string = Compartilhamento servidor Samba
# Quais as maquinas que terao acesso ao Samba
; hosts allow = 192.168.1. 192.168.2. 127.
# Carregar as informacoes sobre as impressoraras
printcap name = /etc/printcap
load printers = yes
# Tipos de spool de Impressao, bsd, sysv, plp, lprng, aix, hpux, qnx, cups
printing = lprng
# Conta convidado
; guest account = pcguest
guest account = ftp
# Log das maquinas samba
log file = /var/log/samba/log.%m
# Tamanho dos logs (em Kb).
max log size = 50
# Nives de detalhamento do Log do samba (0=none, 1=normal, 2 and above not recommended for production box)
debug level = 1
# Nivel de seguranca (security_level.txt para detalhes)
security = user
; security = share
# Senhas criptografadas
# ENCRYPTION.txt, Win95.txt and WinNT.txt in the Samba documentation.
# Do not enable this option unless you have read those documents
encrypt passwords = yes
# Para melhorar o desempenho do samba
# Veja speed.txt e o manual para detalhes
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
# Configure o Samba para usar multiplas interfaces
; interfaces = 192.168.12.2/24 192.168.13.2/24
# Browser Master ou secundario (yes = master, no = secundario)
local master = yes
# Nivel para forçar o Master Browser (Nivel maximo windows 60)
os level = 66
# Contolador de dominio
domain master = yes
# Controlador de dominio preferencial
preferred master = yes
# Use only if you have an NT server on your network that has been
# configured at install time to be a primary domain controller.
; domain controller = <NT-Domain-Controller-SMBName>
# Controlar autenticação no dominio
domain logons = yes
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable it's WINS Server
# Configurar hosts allow com o indereço da lan
wins support = yes
#============================ Share Definitions ==============================
[homes]
comment = Home Directories
browseable = no
writable = yes
# Un-comment the following and create the netlogon directory for Domain Logons
; [netlogon]
; comment = Network Logon Service
; path = /home/netlogon
; guest ok = yes
; writable = no
; share modes = no
# Un-comment the following to provide a specific roving profile share
# the default is to use the user's home directory
;[Profiles]
; path = /home/profiles
; browseable = no
; guest ok = yes
# NOTE: If you have a BSD-style print system there is no need to
# specifically define each individual printer
;[printers]
; comment = All Printers
; path = /var/spool/samba
; browseable = no
; Set public = yes to allow user 'guest account' to print
; guest ok = no
; writable = no
; printable = yes
# This one is useful for people to share files
;[tmp]
; comment = Temporary file space
; path = /tmp
; read only = no
; public = yes
# A publicly accessible directory, but read only, except for people in
# the "staff" group
;[public]
; comment = Public Stuff
; path = /home/samba
; public = yes
; writable = yes
; printable = no
; write list = @staff
# Other examples.
# A private printer, usable only by fred. Spool data will be placed in fred's
# home directory. Note that fred must have write access to the spool directory,
# wherever it is.
;[fredsprn]
; comment = Fred's Printer
; valid users = fred
; path = /homes/fred
; printer = freds_printer
; public = no
; writable = no
; printable = yes
# A private directory, usable only by fred. Note that fred requires write
# access to the directory.
;[fredsdir]
; comment = Fred's Service
; path = /usr/somewhere/private
; public = no
; writable = yes
; printable = no
# a service which has a different directory for each machine that connects
# this allows you to tailor configurations to incoming machines. You could
# also use the %u option to tailor it by user name.
# The %m gets replaced with the machine name that is connecting.
;[pchome]
; comment = PC Directories
; path = /usr/pc/%m
; public = no
; writable = yes
# A publicly accessible directory, read/write to all users. Note that all files
# created in the directory by users will be owned by the default user, so
# any user with access can delete any other user's files. Obviously this
# directory must be writable by the default user. Another user could of course
# be specified, in which case all files would be owned by that user instead.
;[public]
; path = /usr/somewhere/else/public
; public = yes
; only guest = yes
; writable = yes
; printable = no
# The following two entries demonstrate how to share a directory so that two
# users can place files there that will be owned by the specific users. In this
# setup, the directory should be writable by both users and should have the
# sticky bit set on it to prevent abuse. Obviously this could be extended to
# as many users as required.
;[myshare]
; comment = Mary's and Fred's stuff
; path = /usr/somewhere/shared
; valid users = mary fred
; public = no
; writable = yes
; printable = no
; create mask = 0765
[sistema]
comment = compartilhamento dos dados da empresa
path = /dados
public = yes
writable = yes
printable = no
browseable = yes
only guest = yes
guest ok = yes
Citação
