    Bom galera. Tou precisando da ajuda de vocês.
    Tenho um servidor com Debian woody kernel2.4 instalado nele,
    mas a interface gráfica não ta funcionando.
    Quando dou o startx, aparece o seguinte erro:
    Vou colocar só o final do arquivo ""/var/log/XFree86.0.log" aqui:
    (II) Keyboard "Keyboard0" handled by legacy driver
    (**) Option "Protocol" "IMPS/2"
    (**) DevInputMice: Protocol: "IMPS/2"
    (**) Option "AlwaysCore"
    (**) DevInputMice: always reports core events
    (**) Option "Device" "/dev/input/mice"
    (EE) xf86OpenSerial: Cannot open device /dev/input/mice
    No such device.
    (EE) DevInputMice: cannot open input device
    (EE) PreInit failed for input device "DevInputMice"
    (II) UnloadModule: "mouse"
    (II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
    Could not init font path element unix/:7100, removing from list!
    Fatal server error:
    could not open default font 'fixed'
    When reporting a problem related to a server crash, please send
    the full server output, not just the last messages.
    This can be found in the log file "/var/log/XFree86.0.log".
    Please report problems to submit@bugs.debian.org.
    Se alguem poder me ajudar fico grato.
    Obrigado :toim:
  2. mouse não configurado ou configurado errado!
    pode ser também que vc tenha um link /dev/mouse apontando um dispositivo inválido.
  3. eh o device errado mesmo, edita o xorg.conf e altera o device do mouse para /dev/psaux
    galera eu dei uma olha no que vcs me mandou alterei e nada ainda.,
    vou postar meu arq de XF86Config-4
    ## BEGIN DEBCONF SECTION
    # XF86Config-4 (XFree86 server configuration file) generated by dexconf, the
    # Debian X Configuration tool, using values from the debconf database.
    # Edit this file with caution, and see the XF86Config-4 manual page.
    # (Type "man XF86Config-4" at the shell prompt.)
    # If you want your changes to this file preserved by dexconf, only make changes
    # before the "### BEGIN DEBCONF SECTION" line above, and/or after the
    # "### END DEBCONF SECTION" line below.
    # To change things within the debconf section, run the command:
    # dpkg-reconfigure xserver-xfree86
    # as root. Also see "How do I add custom sections to a dexconf-generated
    # XF86Config or XF86Config-4 file?" in /usr/share/doc/xfree86-common/FAQ.gz.
    Section "Files"
    FontPath "unix/:7100" # local font server
    # if the local font server has problems, we can fall back on these
    FontPath "/usr/lib/X11/fonts/misc"
    FontPath "/usr/lib/X11/fonts/cyrillic"
    FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
    FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
    FontPath "/usr/lib/X11/fonts/Type1"
    FontPath "/usr/lib/X11/fonts/Speedo"
    FontPath "/usr/lib/X11/fonts/100dpi"
    FontPath "/usr/lib/X11/fonts/75dpi"
    EndSection
    Section "Module"
    Load "GLcore"
    Load "bitmap"
    Load "dbe"
    Load "ddc"
    Load "dri"
    Load "extmod"
    Load "freetype"
    Load "glx"
    Load "int10"
    Load "pex5"
    Load "record"
    Load "speedo"
    Load "type1"
    Load "vbe"
    Load "xie"
    EndSection
    Section "InputDevice"
    Identifier "Generic Keyboard"
    Driver "keyboard"
    Option "CoreKeyboard"
    Option "XkbRules" "xfree86"
    Option "XkbModel" "pc104"
    Option "XkbLayout" "us"
    EndSection
    Identifier "Configured Mouse"
    Driver "mouse"
    Option "CorePointer"
    Option "Device" "/dev/psaux"
    Option "Protocol" "PS/2"
    Option "Emulate3Buttons" "true"
    Option "ZAxisMapping" "4 5"
    EndSection
    Identifier "Generic Mouse"
    Driver "mouse"
    Option "SendCoreEvents" "true"
    Option "Protocol" "ImPS/2"
    EndSection
    Section "Device"
    Identifier "Generic Video Card"
    Driver "ati"
    Option "UseFBDev" "true"
    EndSection
    Section "Monitor"
    Identifier "Generic Monitor"
    HorizSync 28-49
    VertRefresh 43-72
    Option "DPMS"
    EndSection
    Section "Screen"
    Identifier "Default Screen"
    Device "Generic Video Card"
    Monitor "Generic Monitor"
    DefaultDepth 24
    SubSection "Display"
    Depth 1
    Modes "1024x768" "800x600" "640x480"
    EndSubSection
    Depth 4
    EndSubSection
    Depth 8
    EndSubSection
    Depth 15
    EndSubSection
    Depth 16
    EndSubSection
    Depth 24
    EndSubSection
    EndSection
    Section "ServerLayout"
    Identifier "Default Layout"
    Screen "Default Screen"
    InputDevice "Generic Keyboard"
    InputDevice "Configured Mouse"
    InputDevice "Generic Mouse"
    EndSection
    Section "DRI"
    Mode 0666
    EndSection
    obrigado.
  5. To me especializando em fazer pergunta cretina, mas, o mouse é ps2? Está conectado? A porta do mouse está funcionando?
  1. startx
    Por eutomaluko no fórum Servidores de Rede
    Último Post: 11-09-2004, 08:56
  2. STARTX NAUM ABRE COM KDE
    Respostas: 7
    Último Post: 19-08-2004, 21:17
  3. chamar bbox pelo "startx" ao inves do KDE..como??
    Por dpcl no fórum Servidores de Rede
    Respostas: 11
    Último Post: 15-06-2004, 14:47
  4. Erro Startx (X11)
    Por alexzr no fórum Servidores de Rede
    Último Post: 02-03-2004, 16:53
  5. Como mudar o startx.
    Último Post: 19-11-2003, 08:50
