    olá pessoal
    Essa é a primeira vez q estou configurando o postfix e já estou com problemas!!!hehehe
    qdo envio um email d uma estacao da rede da uma messagem de erro no outlook de Relay access denied!!!
    mas da estacao consigo pingar o smtp.teste.com.br e o pop.teste.com.br
    aki está o meu log
    Apr 25 23:58:08 laboratorio postfix/postfix-script: warning: /var/spool/postfix/etc/localtime and /etc/localtime differ
    Apr 25 23:58:08 laboratorio postfix/postfix-script: starting the Postfix mail system
    Apr 25 23:58:08 laboratorio postfix/master[3004]: daemon started
    Apr 25 23:02:11 laboratorio postfix/smtpd[3016]: connect from unknown[192.168.0.15]
    Apr 25 23:02:11 laboratorio postfix/smtpd[3016]: BA68E11B1C4: client=unknown[192.168.0.15]
    Apr 25 23:02:11 laboratorio postfix/smtpd[3016]: reject: RCPT from unknown[192.168.0.15]: 554 <costa@teste.com.br>: Recipient address rejected: Relay access denied; from=<ribeiro@teste.com.br> to=<costa@teste.com.br>
    Apr 25 23:02:17 laboratorio postfix/smtpd[3016]: disconnect from unknown[192.168.0.15]
    Apr 25 23:03:13 laboratorio postfix/smtpd[3016]: connect from unknown[192.168.0.15]
    Apr 25 23:03:13 laboratorio postfix/smtpd[3016]: 0EAA111B1C4: client=unknown[192.168.0.15]
    Apr 25 23:03:13 laboratorio postfix/smtpd[3016]: reject: RCPT from unknown[192.168.0.15]: 554 <ribeiro@teste.com.br>: Recipient address rejected: Relay access denied; from=<ribeiro@teste.com.br> to=<ribeiro@teste.com.br>
    Apr 25 23:03:18 laboratorio postfix/smtpd[3016]: disconnect from unknown[192.168.0.15]
    aki a configuracao do Postfix
    command_directory = /usr/sbin
    daemon_directory = /usr/libexec/postfix
    mail_owner = postfix
    default_privs = nobody
    myhostname = mail.teste.com.br
    mydomain = teste.com.br
    mynetworks = 168.168.0.0/24, 127.0.0.0/8
    relay_domains = $mydestination
    alias_maps = hash:/etc/postfix/aliases
    mailbox_command = /usr/bin/procmail
    default_transport = smtp
    smtpd_banner = $myhostname ESMTP $mail_name ($mail_version)
    debug_peer_level = 2
    debugger_command =
    PATH=/usr/bin:/usr/X11R6/bin
    xxgdb $daemon_directory/$process_name $process_id & sleep 5
    sendmail_path = /usr/sbin/sendmail.postfix
    newaliases_path = /usr/bin/newaliases.postfix
    mailq_path = /usr/bin/mailq.postfix
    setgid_group = postdrop
    sample_directory = /usr/share/doc/postfix-1.1.11/samples
    readme_directory = /usr/share/doc/postfix-1.1.11/README_FILES
    alias_database = hash:/etc/postfix/aliases
    aki
    o conteudo do arquivo
    /etc/postfix/relay
    192.168.0 OK
    teste.com.br OK
    o q estou fazendo d errado???
    agradeco desde ja a colaboracao d todos
    karfax
    Falta:
    local_delivery_agent =
    mailbox_command =
    e falta voce explicar de onde voce achou que o postfix está lendo o arq. /etc/postfix/relay
    E falta muito mais coisa...
    Sds,
    Certo mas oq coloco em
    local_delivery_agent = ????????
    mailbox_command =???????
    ah para o arq. /etc/postfix/relay
    executei o seguinte comando!!!
    postmap /etc/postfix/relay
    o q mais falta configurar????
  4. pra liberar o relay vc precisa alterar isso:
    pra isso:
    relay_domains = $mynetworks
    Valeu 1c3_m4n qdo chegar em casa vou testar!!!
    qualquer coisa posto novamente!!!
  1. Relay Access Denied
    Por RVR777 no fórum Servidores de Rede
    Último Post: 12-08-2005, 11:47
  2. Erro ao enviar E-mail para fora Relay access denied
    Por pagjunior no fórum Servidores de Rede
    Último Post: 21-06-2005, 08:00
  3. Msg "Relay access denied" no maillog...
    Por kallunga no fórum Servidores de Rede
    Último Post: 14-05-2005, 20:55
  4. Relay Access Denied...ainda nao consegui..alguem me ajuda.!
    Por chroot no fórum Servidores de Rede
    Último Post: 18-12-2004, 13:47
  5. Relay Access Denied
    Último Post: 06-11-2004, 09:57
