    fpmazzi
    Padrão MDMPD
    Pessoal percebi ke no meu servidor qdo starto o linux qdo esta carregando tudo diz ke este servico falhou, alguem sabe me dizer ke servico eh esse??
    grato
    FPMAZZI
    Padrão MDMPD
    cara, vai no diretório /etc/init.d/ (ou equivalente na sua distro) e ache o script. Lá vc fica sabendo...
    fpmazzi
    Padrão MDMPD
    pessoal li, re li, pesquisei com meus amigos aki e nao conseguimos decifarar para que serve este serviço ke esta dando falha ao iniciar o Linux, fui ao /etc/init.d e li o script mdmpd, eu estou postando ele abaixo:
    [[email protected] init.d]# cat mdmpd|less
    #!/bin/bash
    # mdmdp This starts, stops, and reloads the mdmpd-based
    # multipath device monitoring and management facility
    # chkconfig: 2345 99 99
    # description: multipath device monitoring and management
    # Copyright 2002 Red Hat, Inc.
    PATH=/sbin:/usr/sbin:$PATH
    RETVAL=0
    prog=mdmpd
    # Source function library.
    . /etc/rc.d/init.d/functions
    # Make sure configuration file exists and has information we can use
    # MAILADDR or PROGRAM or both must be set in order to run mdadm --monitor
    #[ -f /etc/mdadm.conf ] || exit 0
    #grep '^\(MAILADDR\|PROGRAM\) .' /etc/mdadm.conf >/dev/null 2>&1 || exit 0
    usage ()
    echo "Usage: service $prog {start|stop|status|restart|condrestart}"
    RETVAL=1
    start ()
    ulimit -S -c 0 >/dev/null 2>&1
    # clean up in case we went down unexpectedly
    rm -f /var/run/$prog/*
    echo -n $"Starting $prog: "
    mdmpd
    # hack: wait for mdadm to die, assume success if it doesn't die quickly
    usleep 100000
    pid=`pidof -o $$ -o $PPID -o %PPID -x $prog`
    if [ -n "$pid" ] ; then
    success $"mdmpd"
    touch /var/lock/subsys/$prog
    echo "$pid" > /var/run/$prog.pid
    RETVAL=0
    else
    failure $"mdmpd"
    RETVAL=1
    fi
    echo
    stop ()
    echo -n $"Stopping $prog: "
    killproc $prog
    echo
    rm -f /var/run/$prog.pid
    rm -f /var/lock/subsys/$prog
    restart ()
    stop
    start
    condrestart ()
    [ -e /var/lock/subsys/$prog ] && restart
    case "$1" in
    start) start ;;
    stop) stop ;;
    status) status $prog ;;
    restart|reload) restart ;;
    condrestart) condrestart ;;
    *) usage ;;
    esac
    exit $RETVAL
    se alguem puder ajudar agradeco...
    Padrão MDMPD
    tbm tenho esta duvida sera ke alguem poderia nos ajudar
    Jair...
    :clap: :good:
