    mariogomide
    Padrão Não consigo imprimir
    Não consigo imprimir em outra máquina.
    A impressora é uma HP Deskjet 970 em uma máquina Debian-BR-CDD. Configurei meu CUPS, mas nada acontece.
    Qual deve ser o protocolo?
    olha oq o error_log do cups mostra
    mariogomide
    O pedaço onde eu criei a impressora ImpLeo e tentei imprimir.
    Código :
    I [04/May/2005:16:48:21 -0300] Setting ImpLeo device-uri to "lpd://XX.XX.XX.XX/dev/lp0" (was "file:/dev/null".)
    I [04/May/2005:16:48:21 -0300] Setting ImpLeo printer-is-accepting-jobs to 1 (was 0.)
    I [04/May/2005:16:48:21 -0300] Setting ImpLeo printer-state to 3 (was 5.)
    I [04/May/2005:16:48:21 -0300] Saving printers.conf...
    I [04/May/2005:16:48:21 -0300] New printer 'ImpLeo' added by 'root'.
    I [04/May/2005:16:48:22 -0300] Started "/usr/lib/cups/cgi-bin/printers.cgi" (pid=10331)
    I [04/May/2005:16:48:26 -0300] Started "/usr/lib/cups/cgi-bin/printers.cgi" (pid=10334)
    I [04/May/2005:16:48:28 -0300] Adding start banner page "none" to job 25.
    I [04/May/2005:16:48:28 -0300] Adding end banner page "none" to job 25.
    I [04/May/2005:16:48:28 -0300] Job 25 queued on 'ImpLeo' by 'root'.
    I [04/May/2005:16:48:28 -0300] Started filter /usr/lib/cups/filter/pstops (PID 10338) for job 25.
    I [04/May/2005:16:48:28 -0300] Started filter /usr/lib/cups/filter/foomatic-rip (PID 10339) for job 25.
    I [04/May/2005:16:48:28 -0300] Started backend /usr/lib/cups/backend/lpd (PID 10340) for job 25.
    I [04/May/2005:16:48:29 -0300] Started "/usr/lib/cups/cgi-bin/printers.cgi" (pid=10345)
    W [04/May/2005:16:48:33 -0300] [Job 25] Network host 'XX.XX.XX.XX' is busy, down, or unreachable; will retry in 30 seconds...
    A rede funciona normalmente na máquina. ping, ssh e tudo mais. No exemplo estou usando o protocolo lpd. Já tentei um monte de outros.[/code]
    pelo q ta ai a impressora tb parece estar configurada certinho, ta me parecendo problema com o samba onde ta a impressora. alias essa impressora ta em outra maquina linux? se for vc nao precisa de samba pra compartilhar ela
    mariogomide
    Pois é. Não tem nada de samba.
    São duas máquinas Debian-BR-CDD.
    como ta a conf da impressora no cups dessa qnao ta imprimindo e na maquina q tem a impressora?
    mariogomide
    Como assim? Que configuração?
    Na máquina da impressora, ela é vista em /dev/lp0
    e aqui está ipp://host/ImpLeo (já tentei um monte aqui...)
    o arquivo de configuracao printers.conf do cups
    mariogomide
    Instalei novamente a impressora.
    Primeiro, instalei ela na máquina a qual a impressora está conetada com o nome hp970c. Tudo funciona localmente!
    Depois, na máquina remota, instalei a impressora com o mesmo nome (hp970c) com o seguinte protocolo: ipp://xx.xx.xx.xx/ipp/hp970c
    Aqui vai o printers.conf da máquina remota.
    <Printer hp970c>
    Info hp
    Location xx.xx.xx.xx
    DeviceURI ipp://xx.xx.xx.xx/ipp/hp970c
    State Idle
    Accepting Yes
    JobSheets none none
    QuotaPeriod 0
    PageLimit 0
    KLimit 0
    </Printer>
    Eu mandei imprimir uma página de teste, mas não imprime.
    Então, aqui vai o que o CUPS me mostra na interface web
    Description: hp
    Printer State: processing, accepting jobs.
    "Unable to get printer status (client-error-forbidden)!"
    Device URI: http://xx.xx.xx.xx:631/ipp/hp970c
    :toim: E agora?? :toim:
    mariogomide
    Esse erro: client-error-forbiden!
    O que fazer para resolvê-lo? Eu me conecto na máquina via ssh, vnc, ping e tudo mais.
    Rodei o nmap nas duas máquinas e o protocolo ipp (porta 631) está aberta.
