    aeamorim
    Olá pessoal, estou com um problema que está ocorrendo tanto no conectiva como no fedora e no slackware, o problema eh o seguinte:
    instalei um servidor pdc que está funcionando tudo ok, porém estou disponibilizando alguns programas para serem acessados em rede, estes programas são feitos em delphi, e quando tento executar dá um erro de execução e o windows fala que o programa executou uma operação ilegal e pede para enviar o relatorio.
    segue o smb.conf para analise
    Código :
    # This is the main Samba configuration file. You should read the
    # smb.conf(5) manual page in order to understand the options listed
    # here. Samba has a huge number of configurable options (perhaps too
    # many!) most of which are not shown in this example
    # Any line which starts with a ; (semi-colon) or a # (hash)
    # is a comment and is ignored. In this example we will use a #
    # for commentry and a ; for parts of the config file that you
    # may wish to enable
    # NOTE: Whenever you modify this file you should run the command "testparm"
    # to check that you have not made any basic syntactic errors.
    #======================= Global Settings =====================================
    [global]
    	netbios name = zeus
    ;	netbios name = serverapp
    # workgroup = NT-Domain-Name or Workgroup-Name
    	workgroup = olimpia
    ;	workgroup = Minervafvl
    # server string is the equivalent of the NT Description field
    	server string = Servidor de Arquivos
    # This option is important for security. It allows you to restrict
    # connections to machines which are on your local network. The
    # following example restricts access to two C class networks and
    # the "loopback" interface. For more examples of the syntax see
    # the smb.conf man page
    ;   hosts allow = 192.168.1. 192.168.2. 127.
    # if you want to automatically load your printer list rather
    # than setting them up individually then you'll need this
    	printcap name = /etc/printcap
    	load printers = yes
    # It should not be necessary to spell out the print system type unless
    # yours is non-standard. Currently supported print systems include:
    # bsd, sysv, plp, lprng, aix, hpux, qnx
    ;   printing = cups
    # This option tells cups that the data has already been rasterized
    	cups options = raw
    # Uncomment this if you want a guest account, you must add this to /etc/passwd
    # otherwise the user "nobody" is used
    ;  guest account = pcguest
    # this tells Samba to use a separate log file for each machine
    # that connects
    	log file = /var/log/samba/%m.log
    # all log information in one file
    #   log file = /var/log/samba/smbd.log
    # Put a capping on the size of the log files (in Kb).
    	max log size = 50
    # Security mode. Most people will want user level security. See
    # security_level.txt for details.
    # Use password server option only with security = server
    ;   password server = <NT-Server-Name>
    # Password Level allows matching of _n_ characters of the password for
    # all combinations of upper and lower case.
    ;  password level = 8
    ;  username level = 8
    # You may wish to use password encryption. Please read
    # ENCRYPTION.txt, Win95.txt and WinNT.txt in the Samba documentation.
    # Do not enable this option unless you have read those documents
    ;  encrypt passwords = yes
    ;  smb passwd file = /etc/samba/smbpasswd
    # The following are needed to allow password changing from Windows to
    # update the Linux system password also.
    # NOTE: Use these with 'encrypt passwords' and 'smb passwd file' above.
    # NOTE2: You do NOT need these to allow workstations to change only
    #        the encrypted SMB passwords. They allow the Unix password
    #        to be kept in sync with the SMB password.
    ;  unix password sync = Yes
    ;  passwd program = /usr/bin/passwd %u
    ;  passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
    # Unix users can map to different SMB User names
    	username map = /etc/samba/smbusers
    # Using the following line enables you to customise your configuration
    # on a per machine basis. The %m gets replaced with the netbios name
    # of the machine that is connecting
    ;   include = /etc/samba/smb.conf.%m
    # Most people will find that this option gives better performance.
    # See speed.txt and the manual pages for details
    	socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    # Configure Samba to use multiple interfaces
    # If you have multiple network interfaces then you must list them
    # here. See the man page for details.
    ;   interfaces = 192.168.12.2/24 192.168.13.2/24
    # Configure remote browse list synchronisation here
    #  request announcement to, or browse list sync from:
    #	a specific host or from / to a whole subnet (see below)
    ;   remote browse sync = 192.168.3.25 192.168.5.255
    # Cause this host to announce itself to local subnets here
    ;   remote announce = 192.168.1.255 192.168.2.44
    # Browser Control Options:
    # set local master to no if you don't want Samba to become a master
    # browser on your network. Otherwise the normal election rules apply
    	local master = yes
    # OS Level determines the precedence of this server in master browser
    # elections. The default value should be reasonable
    	os level = 33
    # Domain Master specifies Samba to be the Domain Master Browser. This
    # allows Samba to collate browse lists between subnets. Don't use this
    # if you already have a Windows NT domain controller doing this job
    	domain master = yes
    # Preferred Master causes Samba to force a local browser election on startup
    # and gives it a slightly higher chance of winning the election
    	preferred master = yes
    # Enable this if you want Samba to be a domain logon server for
    # Windows95 workstations.
    	domain logons = yes
    # if you enable domain logons then you may want a per-machine or
    # per user logon script
    # run a specific logon batch file per workstation (machine)
    ;   logon script = %m.bat
    # run a specific logon batch file per username
    	logon script = %U.bat
    # Where to store roving profiles (only for Win95 and WinNT)
    #        %L substitutes for this servers netbios name, %U is username
    #        You must uncomment the [Profiles] share below
    	logon path = \\%L\Profiles\%U
    # All NetBIOS names must be resolved to IP Addresses
    # 'Name Resolve Order' allows the named resolution mechanism to be specified
    # the default order is "host lmhosts wins bcast". "host" means use the unix
    # system gethostbyname() function call that will use either /etc/hosts OR
    # DNS or NIS depending on the settings of /etc/host.config, /etc/nsswitch.conf
    # and the /etc/resolv.conf file. "host" therefore is system configuration
    # dependant. This parameter is most often of use to prevent DNS lookups
    # in order to resolve NetBIOS names to IP Addresses. Use with care!
    # The example below excludes use of name resolution for machines that are NOT
    # on the local network segment
    # - OR - are not deliberately to be known via lmhosts or via WINS.
    ; name resolve order = wins lmhosts bcast
    # Windows Internet Name Serving Support Section:
    # WINS Support - Tells the NMBD component of Samba to enable it's WINS Server
    ;   wins support = yes
    # WINS Server - Tells the NMBD components of Samba to be a WINS Client
    #	Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
    ;   wins server = w.x.y.z
    # WINS Proxy - Tells Samba to answer name resolution queries on
    # behalf of a non WINS capable client, for this to work there must be
    # at least one	WINS Server on the network. The default is NO.
    	wins proxy = yes
    # DNS Proxy - tells Samba whether or not to try to resolve NetBIOS names
    # via DNS nslookups. The built-in default for versions 1.9.17 is yes,
    # this has been changed in version 1.9.18 to no.
    	dns proxy = no
    # Case Preservation can be handy - system default is _no_
    # NOTE: These can be set on a per share basis
    	preserve case = no
    	short preserve case = no
    # Default case is normally upper case for all DOS files
    	default case = lower
    # Be very careful with case sensitivity - it can break things!
    	case sensitive = no
    #============================ Share Definitions ==============================
    	idmap uid = 16777216-33554431
    	idmap gid = 16777216-33554431
    	template shell = /bin/false
    	password server = None
    	winbind use default domain = no
    	client code page = 850
    	character set = ISO8859-1
    [homes]
    	comment = Home Directories
    	browseable = no
    	writeable = yes
    # Un-comment the following and create the netlogon directory for Domain Logons
    [netlogon]
    	comment = Network Logon Service
    	path = /home/netlogon
    	guest ok = yes
    	share modes = no
    # Un-comment the following to provide a specific roving profile share
    # the default is to use the user's home directory
    [Profiles]
    	path = /home/profiles
    	browseable = no
    	writeable = yes
    	guest ok = yes
    # NOTE: If you have a BSD-style print system there is no need to
    # specifically define each individual printer
    [printers]
    	comment = All Printers
    	path = /var/spool/samba
    	browseable = no
    # Set public = yes to allow user 'guest account' to print
    	printable = yes
    # This one is useful for people to share files
    ;[tmp]
    ;   comment = Temporary file space
    ;   path = /tmp
    ;   read only = no
    ;   public = yes
    # A publicly accessible directory, but read only, except for people in
    # the "staff" group
    ;[public]
    ;   comment = Public Stuff
    ;   path = /home/samba
    ;   public = yes
    ;   read only = yes
    ;   write list = @staff
    # Other examples.
    # A private printer, usable only by fred. Spool data will be placed in fred's
    # home directory. Note that fred must have write access to the spool directory,
    # wherever it is.
    ;[fredsprn]
    ;   comment = Fred's Printer
    ;   valid users = fred
    ;   path = /homes/fred
    ;   printer = freds_printer
    ;   public = no
    ;   writable = no
    ;   printable = yes
    # A private directory, usable only by fred. Note that fred requires write
    # access to the directory.
    ;[fredsdir]
    ;   comment = Fred's Service
    ;   path = /usr/somewhere/private
    ;   public = no
    ;   writable = yes
    ;   printable = no
    # a service which has a different directory for each machine that connects
    # this allows you to tailor configurations to incoming machines. You could
    # also use the %u option to tailor it by user name.
    # The %m gets replaced with the machine name that is connecting.
    ;[pchome]
    ;  comment = PC Directories
    ;  path = /usr/pc/%m
    ;  public = no
    ;  writable = yes
    # A publicly accessible directory, read/write to all users. Note that all files
    # created in the directory by users will be owned by the default user, so
    # any user with access can delete any other user's files. Obviously this
    # directory must be writable by the default user. Another user could of course
    # be specified, in which case all files would be owned by that user instead.
    ;[public]
    ;   path = /usr/somewhere/else/public
    ;   public = yes
    ;   only guest = yes
    ;   writable = yes
    ;   printable = no
    # The following two entries demonstrate how to share a directory so that two
    # users can place files there that will be owned by the specific users. In this
    # setup, the directory should be writable by both users and should have the
    # sticky bit set on it to prevent abuse. Obviously this could be extended to
    # as many users as required.
    ;[myshare]
    ;   comment = Mary's and Fred's stuff
    ;   path = /usr/somewhere/shared
    ;   valid users = mary fred
    ;   public = no
    ;   writable = yes
    ;   printable = no
    ;   create mask = 0765
    [sistemas]
    	path = /home/sistemas
    	browseable = no
    	writable = no
    [sistemas1]
    	path = /home/sistemas1
    	browseable = no
    	writable = no
    [driver]
    	path = /home/driver
    	writeable = no
    	browseable = no
    [programa]
    	path = /home/programa
    	writeable = yes
    	browseable = no
    [/code]
  2. pode ser problema de permissão, embora vc não tenha especificado o erro...
    seguinte, nenhuma das pastas que está exportando tem permissão de pesquisa (browseable), se o software precisa listas arquivos, ou verificar qquer coisa, não vai conseguir...
    outra, algumas não tem permissão de escrita, isso é meio complicado com programas win, que não tem configuração forte de segurança. Normalmente tem que liberar tudo...
    pode ser preciso mudar permissões e dono dos arquivos, é comum o pessoal copiar os arquivos para as pastas que serão exportadas como root, e depois na hora de acessar não consegue, pois o root não é o usuário padrão do samba...
  1. Erro ao executar o mysql
    Por Kabal no fórum Servidores de Rede
    Último Post: 24-05-2004, 17:33
  2. Erro ao executar make menuconfig?
    Por Hacinn no fórum Servidores de Rede
    Último Post: 04-05-2004, 08:24
  3. erro ao executar programa....
    Por flush no fórum Linguagens de Programação
    Último Post: 25-03-2004, 09:06
  4. Erro ao executar o KSCD
    Último Post: 10-10-2003, 19:23
  5. ERRO AO EXECUTAR MPLAYER
    Por Fabinho no fórum Servidores de Rede
    Último Post: 16-12-2002, 11:48
