    Moderador Avatar de Bruno
    Nov 2002
    Guarapuava-PR
    Padrão pppoe radius
    gelera seguinte
    to tentando configurar um serv pppoe com radius
    e naum ta dando certo
    meu log
    May 6 15:55:56 mail pppoe-server[22853]: Session 3 created for client 00:0d:87:86:5f:47 (10.67.15.3) on eth1 using Service-Name ''
    May 6 15:55:56 mail pppd[22853]: Plugin radius.so loaded.
    May 6 15:55:56 mail pppd[22853]: RADIUS plugin initialized.
    May 6 15:55:56 mail pppd[22853]: Plugin radattr.so loaded.
    May 6 15:55:56 mail pppd[22853]: RADATTR plugin initialized.
    May 6 15:55:56 mail pppoe-server[22583]: Session 3 closed for client 00:0d:87:86:5f:47 (10.67.15.3) on eth1
    May 6 15:55:56 mail pppoe-server[22583]: Sent PADT
    May 6 15:55:56 mail named[25335]: lame server resolving 'mailermx.catho.com.br' (in 'catho.com.br'?): 200.255.253.241#53
    May 6 15:55:56 mail named[25335]: unexpected RCODE (REFUSED) resolving 'ns22.egynet.com.eg/A/IN': 193.0.0.193#53
    May 6 15:56:11 mail pppoe-server[22884]: Session 4 created for client 00:0d:87:86:5f:47 (10.67.15.4) on eth1 using Service-Name ''
    May 6 15:56:11 mail pppd[22884]: Plugin radius.so loaded.
    May 6 15:56:11 mail pppd[22884]: RADIUS plugin initialized.
    May 6 15:56:11 mail pppd[22884]: Plugin radattr.so loaded.
    May 6 15:56:11 mail pppd[22884]: RADATTR plugin initialized.
    May 6 15:56:11 mail pppoe-server[22583]: Session 4 closed for client 00:0d:87:86:5f:47 (10.67.15.4) on eth1
    May 6 15:56:11 mail pppoe-server[22583]: Sent PADT
    May 6 15:56:16 mail pppoe-server[22889]: Session 5 created for client 00:0d:87:86:5f:47 (10.67.15.5) on eth1 using Service-Name ''
    May 6 15:56:16 mail pppd[22889]: Plugin radius.so loaded.
    May 6 15:56:16 mail pppd[22889]: RADIUS plugin initialized.
    May 6 15:56:16 mail pppd[22889]: Plugin radattr.so loaded.
    May 6 15:56:16 mail pppd[22889]: RADATTR plugin initialized.
    Nov 2002
    Guarapuava-PR
    Padrão pppoe radius
    no windows ele fala que deu erro 651
    Padrão pppoe radius
    O seu radius esta autenticando aonde?
    No mysql?
    Como ta seu radius? Funcionando blza? Olha o log do radius e do mysql caso vc use!
    Nov 2002
    Guarapuava-PR
    Padrão pppoe radius
    sim
    Nov 2002
    Guarapuava-PR
    Padrão pppoe radius
    o raius ta legal
    Nov 2002
    Guarapuava-PR
    Padrão pppoe radius
    alguem tem ideia
    Padrão pppoe radius
    quando vc for tentar conectar deixa uns terminais abertos com comando!
    coloque o seu mysql para gravar em log as queries e ver se as consultas sql do radius estão chegando no sqlserver!
    term1
    tail -f /var/log/radius.log
    term2
    tail -f /var/log/mysql.log
    pelo que vc mostrou acima, o cliente ja chega no pppoe, tem que ver se o pppoe está chegando no radius, se sim, veja se o radius esta chegando no mysql.
    obs: a maquina teste, esta no mesmo barramento neh? outra coisa, coloca aqui a linha que vc ta inicializando servidor pppoe.
    Nov 2002
    Guarapuava-PR
    Padrão pppoe radius
    ok
    sei que o radius ta chegando no mysql pois ele com o radtest esta ok
    olhando os logs do radius não chega nehuma requisição a ele
    Nov 2002
    Guarapuava-PR
    Padrão pppoe radius
    alguem tem ideia
