    guardian_metal
    Padrão mkntpwd e ldap
    To montando um servidor de ldap + samba com phpldapadmin e estou precisando do executável "mkntpwd". Onde acho isso?
    Uso conectiva 10.
    Voce tentou
    #apt-get install mkntpwd
    guardian_metal
    Já e não funciona.
    Nesta pasta:
    /usr/share/doc/samba-doc-3.0.10/examples/LDAP/smbldap-tools/mkntpwd
    tem o seguinte:
    [[email protected] mkntpwd]# ls
    Makefile getopt.c getopt.h md4.c mkntpwd.c mkntpwd.h smbdes.c
    mas quanto dou um./Makefile, me retorna a saída abaixo:
    [[email protected] mkntpwd]# ./Makefile
    ./Makefile: line 1: DEBUG: command not found
    ./Makefile: line 1: OPTIMIZE: command not found
    ./Makefile: line 1: ARCH: command not found
    ./Makefile: line 1: VISUAL: command not found
    ./Makefile: line 1: PERMUTE: command not found
    ./Makefile: line 1: STATIC: command not found
    ./Makefile: line 52: OBJS: command not found
    ./Makefile: line 1: OBJS: command not found
    ./Makefile: line 54: mkntpwd:: command not found
    ./Makefile: line 1: CC: command not found
    ./Makefile: line 1: CFLAGS: command not found
    ./Makefile: line 1: XLIBS: command not found
    ./Makefile: line 55: -o: command not found
    ./Makefile: line 57: clean:: command not found
    ./Makefile: line 60: install:: command not found
    ./Makefile: line 1: PREFIX: command not found
    install: imposs�el fazer stat em `mkntpwd': Arquivo ou diret�io n� encontrado
    Não sei agora como compilar este mkntpwd para fazê-lo funcionar.
