- Compilando kernel
Compilando kernel
Eu tentando compilar o kernel 2.6.11.8 mas ele acusa dependencia
server-linux:/usr/src/linux # make xconfig
* Unable to find the QT installation. Please make sure that the
* QT development package is correctly installed and the QTDIR
* environment variable is set to the correct location.
make[1]: *** [scripts/kconfig/.tmp_qtcheck] Error 1
make: *** [xconfig] Error 2
Mas eu jah fiz a instalação do QT. Me deem uma mao ae.
Compilando kernel
Ai o conteudo da variável QTDIR
Neste caminho realmente se encontra os arquivos QT
server-linux:/usr/src # echo $QTDIR
/usr/lib/qt3
Compilando kernel
aki tb deu isso, fiz assim:
export QTDIR=/usr
Compilando kernel
fiz export QTDIR=/usr
O comando rodou legal
server-linux:/usr/src/linux # echo $QTDIR
/usr
Mas na hora de dar o #make xconfig dah a mesma coisa
Compilando kernel
Vc vai ter q caçar onde estao os arquivos do QT q ele precisa, tenta /usr/share/qt, /usr/include,etc..
da um find / -name qt*
e tenta com os dirs q vc tem ai
Compilando kernel
cara, pus no /etc/profile e rodou legal, do jeitnho que vc tava tentando.
Compilando kernel
server-linux:/ # find -name qt*
./etc/X11/qtrc
./etc/X11/qt_gtk_fnt2fntrc
./etc/X11/qt_plugins_3.3rc
./etc/opt/kde3/share/icons/crystalsvg/16x16/apps/qt.png
./etc/opt/kde3/share/icons/crystalsvg/32x32/apps/qt.png
./etc/opt/kde3/share/icons/crystalsvg/48x48/apps/qt.png
./opt/kde3/share/apps/kstyle/themes/qtplatinum.themerc
./opt/kde3/share/apps/kstyle/themes/qtmotifplus.themerc
./opt/kde3/share/apps/kstyle/themes/qtcde.themerc
./opt/kde3/share/apps/kstyle/themes/qtmotif.themerc
./opt/kde3/share/apps/kstyle/themes/qtwindows.themerc
./opt/kde3/share/apps/kstyle/themes/qtsgi.themerc
./opt/kde3/share/icons/crystalsvg/64x64/apps/qtella.png
./opt/kde3/share/config/SuSE/default/qtrc
./opt/kde3/share/services/searchproviders/qt.desktop
./opt/kde3/share/services/kresources/konnector/qtopia.desktop
./opt/kde3/include/qobex/qttylock.h
./srv/www/cgi-bin/qtest
./usr/bin/qtconfig
./usr/lib/qt3
./usr/lib/qt3/bin/qtconfig
./usr/lib/qt3/translations/qt_ar.qm
./usr/lib/qt3/translations/qt_de.qm
./usr/lib/qt3/translations/qt_cs.qm
./usr/lib/qt3/translations/qt_fr.qm
./usr/lib/qt3/translations/qt_iw.qm
./usr/lib/qt3/translations/qt_ru.qm
./usr/lib/qt3/translations/qt_sk.qm
./usr/src/packages/SPECS/qt.spec
./usr/src/packages/SOURCES/qt.diff
./usr/src/packages/SOURCES/qt-x11-opensource-4.0.0-b2.tar.bz2
./usr/src/linux-2.6.11.8/drivers/char/qtronix.c
./usr/src/linux-2.6.11.8/drivers/char/qtronixmap.map
./usr/src/linux-2.6.11.8/drivers/char/qtronixmap.c_shipped
./usr/share/doc/packages/qt3
./usr/share/susehelp/meta/Development/Libraries/qt-devel-doc.desktop
./usr/share/susehelp/meta/Development/Libraries/qt3-devel-doc.desktop
./usr/share/susehelp/meta/Development/Libraries/qt3.desktop
./usr/share/susehelp/meta/Development/Libraries/qt.desktop
./usr/share/susehelp/meta/Manuals/Productivity/qtecasound.desktop
./usr/share/susehelp/meta/Manuals/Productivity/qtpcr.desktop
./usr/share/susehelp/meta/Manuals/Productivity/qttudo.desktop
./usr/share/applications/qtconfig.desktop
./usr/share/desktop-data/qtrc
./home/itiho/qt-4.0.0beta2-3.src.rpm
./home/itiho/linux-2.6.11.8/drivers/char/qtronix.c
./home/itiho/linux-2.6.11.8/drivers/char/qtronixmap.map
./home/itiho/linux-2.6.11.8/drivers/char/qtronixmap.c_shipped
find: ./media/cdrom: No medium found
find: ./media/floppy: No medium found
Compilando kernel
no seu /etc/profile, acrescente: e feche o terminal e abra novamente e, dentro do diretório com os fontes do kernel,
Compilando kernel
Continua a mesma coisa. Estou ficando com raiva disso.
