Estou construindo um script de firewall mas este dá erro e depois a internet para de funcionar.
Código :
#!/bin/bash
WORKING = $PWD
. $WORKING/variaveis
clear
echo '############################################################################################################################'
echo '#        #'
echo '#        #'
echo '#                                                        Script IPTABLES                                                   #'
echo '#                                             by White_Tiger - [email]itihoitiho@gmail.com[/email]                                        #'
echo '#        #'
echo '#        #'
echo ''
echo ''
#    Deleta todas as regras do firewall
printf "Limpando as Regras."
iptables -t filter -F
iptables -t filter -X
iptables -t nat    -F
iptables -t nat    -X
iptables -t mangle -F
iptables -t mangle -X
printf "        \033[40;32m [OK] \033[m\n"
# Desabilitando o trafego IP Entre as Placas de Rede
printf "Desabilitando o tráfego entre as placas de rede."
echo "0" > /proc/sys/net/ipv4/ip_forward
iptables -A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
# Configurando a Protecao anti-spoofing
printf "Configurando a proteção anti-spoofing."
for spoofing in /proc/sys/net/ipv4/conf/*/rp_filter; do
        echo "1" > $spoofing
done
# Remove modulos do ipchains para evitar conflitos
#printf "Removendo módulos do ipchains."
#rmmod ipchains
#printf "                                                              \033[40;32m [OK] \033[m\n"
# Inseri modulos iptables
printf "Inserindo modulos iptables."
$MOD ip_tables
$MOD ip_nat_ftp
$MOD ip_conntrack_ftp
$MOD ipt_MASQUERADE
$MOD iptable_nat
$MOD ip_conntrack
$MOD iptable_filter
# Barra a porta Wincrash e cria log da tentativa de acesso
printf "Barrando Wincrash."
iptables -A INPUT -p tcp --dport 5042 -j LOG --log-prefix "Serviço: Wincrash"
iptables -A INPUT -p tcp --dport 5042 -j DROP
# Barra a porta NetBus e cria log da tentativa de acesso
printf "Barrando NetBus."
iptables -A INPUT -p tcp --dport 12345 -j LOG --log-prefix "Serviço: NetBus"
iptables -A INPUT -p tcp --dport 12345 -j DROP
#Protecao quanto a ataques DoS
#printf "Protegendo contra ataque DoS."
#iptables -A FORWARD -m unclean -j DROP
#nat da rede
printf "Fazendo Nat na rede."
iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
#Bloqueando conexão via SSh
case $SSH in
        'S'|'s')
                printf "Bloqueando Acesso por SSH."
                iptables -A INPUT -p tcp --destination-port 22 -j DROP
esac
#Habilitando o squid
case $SQUID in
	'S'|'s')
		printf "Redirecionando a porta 80 para server squid na porta 3128."
		iptables -t nat -A PREROUTING -i $INT_REDE -p tcp  --dport 80 -j REDIRECT --to-port $SQUID_PORT
		itables –-A FORWARD -s 192.168.1.0/24 –-p tcp --dport 3128 –-j ACCEPT
esac
#Habilitando o Terminal Service do RWindows
case $TS in
	S|s)
		printf "Redirecionando porta 3389 para Terminal Service.";
                iptables -A PREROUTING -t nat -p tcp --dport 3389 -j DNAT --to $TERM_IP;
		printf "                                                              \033[40;32m [OK] \033[m\n";;
esac
#Bloqueando o Yahoo messenger
case $YAHOO in
	S|s)
		printf "Bloqueando o Yahoo Messenger.";
		iptables -A FORWARD -d cs.yahoo.com -j REJECT;
		iptables -A FORWARD -d scsa.yahoo.com -j REJECT;
esac
#Bloqueando o Msn messenger
case $MSN in
        S|s)
                printf "Bloqueando o MSN Messenger.";
		iptables -A FORWARD -p TCP --dport 1863 -j REJECT;
		iptables -A FORWARD -d 64.4.13.0/24 -j REJECT;
esac
#Bloqueando o ICQ
case $ICQ in
        S|s)
                printf "Bloqueando o ICQ.";
		iptables -A FORWARD -p TCP --dport 5190 -j REJECT;
		iptables -A FORWARD -d login.icq.com -j REJECT;
esac
#Bloqueando o AIM
case $AIM in
        S|s)
                printf "Bloqueando o AIM";
		iptables -A FORWARD -d login.oscar.aol.com -j REJECT;
esac
#Bloqueando P2P
case $P2P in
	S|s)
		printf "Bloqueando P2Ps.";
		#iMesh
		iptables -A FORWARD -d 216.35.208.0/24 -j REJECT;
		#BearShare
		iptables -A FORWARD -p TCP --dport 6346 -j REJECT;
		#ToadNode
		#WinMX
		iptables -A FORWARD -d 209.61.186.0/24 -j REJECT;
		iptables -A FORWARD -d 64.49.201.0/24 -j REJECT;
		#Napigator
		iptables -A FORWARD -d 209.25.178.0/24 -j REJECT;
		#Morpheus
		iptables -A FORWARD -d 206.142.53.0/24 -j REJECT;
		iptables -A FORWARD -p TCP --dport 1214 -j REJECT;
		#KaZaA
		iptables -A FORWARD -d 213.248.112.0/24 -j REJECT;
		for IP in `cat $WORKING/bloqueios/ip-kazaa-10.txt`
		do
	   		iptables -A FORWARD -i $OUT_IFACE -d $IP -j DROP
		done;
		#Limewire
		#Audiogalaxy
		iptables -A FORWARD -d 64.245.58.0/23 -j REJECT;
		#GNUTella
		iptables -A FORWARD -p tcp --dport 6346 -j REJECT;
		#eDonkey
		iptables -A FORWARD -p tcp --dport 4661:4662 -j REJECT;
		iptables -A FORWARD -p udp --dport 4665 -j REJECT;
		#Napster
		iptables -A FORWARD -d 64.124.41.0/24 -j REJECT;
		#Bearshare
		#ToadNode
esac
#Bloqueando Spyware
case $SPY in
        S|s)
                printf "Bloqueando SPYWARES.";
		CONT=0;
		for SPYW in `cat $WORKING/bloqueios/spyware cut -d : -f1`
		do
			iptables -A INPUT -s $SPYW -j DROP
			CONT=`expr $CONT + 1`
			if [ $CONT -eq 110 ]
			then
				echo -n "."
				CONT=0
			fi
		done;
esac
# Habilitando o trafego Ip, entre as Interfaces de rede
printf "Habilitanto o tráfego entre as redes."
echo "1" > /proc/sys/net/ipv4/ip_forward
printf "\n\n"
printf "Instalação do Firewall completa.                                                           \033[40;32m [OK] \033[m\n"
O conteudo de $working/variaveis é:
Código :
#!/bin/bash
#Declaração das variáveis globais
INT_NET = 'eth0'            #Interface de conecção com a internet.
INT_REDE = 'eth1'           #Interface de conecção com a rede.
SQUID = 'S'                 #Configura se o servidor possue proxy squid rodando. (S) Sim ou (N) Não.
SQUID_PORT = 3128           #Porta do squid (3128 é o padrão)
TS = 'S'                    #Configura se possue um servidor terminal service na rede e redireciona a porta (S) ou (N)
TERM_IP='192.168.1.250'     #IP do servidor rodando terminal service na rede
YAHOO = 'S'                 #Bloqueia Yahoo messenger
MSN = 'N'                   #Bloqueia Msn messenger
ICQ = 'S'                   #Bloqueia ICQ
AIM = 'S'                   #Bloqueia AIM
P2P = 'S'                   #Bloqueia Kazaa
SPY = 'S'                   #Bloqueia Spyares conhecidos
SSH = 'N'                   #Bloqueia acesso por SSH
MOD=`which modprobe`        #Modulos do iptables
# Fim da declaração de variáveis
