    Padrão Samba PDC não guarda perfil
    Segue meu smb.conf
    Código :
    #======================= Global Settings =====================================
    [global]
    	workgroup = REDEMAX2
    	server string = Server Linux
    	printcap name = /etc/printcap
    	printing = lprng
    	guest account = root
    	log file = /var/log/samba/log.%m
    	max log size = 50
    	debug level = 1
    	password level = 20
    	username level = 8
    	unix password sync = yes
    	socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    	remote browse sync = 192.168.1.254
    	remote announce = 192.168.1.254
    	os level = 99
    	domain master = yes
    	preferred master = yes
    	name resolve order = wins lmhosts bcast
    	wins support = yes
    	preserve case = no
    	short preserve case = no
    	case sensitive = no
    	create mask = 0664
    	admin users = @root
    	valid users = @root, @diretoria, @engenharia, @suporte, @administracao, @suprimentos, @comercial
    	update encrypted = yes
    	time server = yes
    	domain admin group = @suporte, @root
    	logon path = \\%L\Profiles\%U
    	logon script = %G.bat
    	add machine script = /usr/sbin/useradd  -c Machine -d /var/lib/nobody -s /bin/false %m$
    	ldap idmap suffix = ou=Idmap
    	ldap machine suffix = ou=Computers
    	ldap suffix = dc=example,dc=com
    	encrypt passwords = yes
    	security = domain
    	domain logons = yes
    	local master = yes
    #============================ Share Definitions ==============================
    [homes]
    	path = /home
    	comment = Home Directories
    	browseable = no
    	read only = no
    [netlogon]
    	comment = Network Logon Service
    	path = /home/netlogon
    	guest ok = yes
    	share modes = no
    [qualidade]
    	path = /home/qualidade/
    	create mask = 0775
    	valid users = @root, @qualidade
    	guest ok = yes
    	read only = no
    	msdfs proxy = no
    [diretoria]
    	comment = Pasta de trabalho do grupo Diretoria
    	path = /home/diretoria
    	valid users = @diretoria, @root
    	create mask = 0770
    	read only = no
    [administracao]
    	comment = Pasta de trabalho do grupo Administração
    	path = /home/administracao/
    	valid users = @root, @administracao
    	create mask = 0770
    	msdfs proxy = no
    [suporte]
    	comment = Pasta de trabalho do grupo de informática
    	path = /home/suporte
    	valid users = @suporte, @root
    	create mask = 0770
    	read only = no
    [projetos]
    	comment = Pasta de trabalho do grupo Projetos
    	path = /home/projetos/
    	valid users = @root, @engenharia
    	create mask = 0770
    	guest account = itiho
    	msdfs proxy = no
    [suprimentos]
    	comment = Pasta de trabalho do grupo Suprimentos
    	path = /home/suprimentos
    	valid users = @suprimentos, @root
    	create mask = 0770
    	read only = no
    [publico]
    	comment = Pasta de trabalho publica
    	path = /home/publico
    	valid users = @root, @engenharia, @suprimentos, @suporte, @administracao, @diretoria
    	create mask = 0777
    	guest ok = yes
    	read only = no
    [comercial]
    	comment = Pasta de trabalho do grupo Comerial
    	path = /home/comercial
    	valid users = @comercial, @root
    	create mask = 0770
    	read only = no
    [Profiles]
    comment = Network User Profiles
    path = /home/profiles
    read only = no
    create mask = 0700
    directory mask = 0700
    O Windows não está guardando o perfil. Toda vez que eu logo ele está retornando ao normal com perfil temporáreo.
    jah usei o comando: #chmod -R 0777 /home/profiles
    karfax
    Traduza este parâmetro:
    Sds,
    Achei essa parte do código em alguns tutoriais.
    %L - o nome NetBIOS do servidor
    %U - nome de usuário da sessão
    também jah entontrei:
    logon path = \\%N\profiles\%u
    onde:
    %N - o nome do servidor NIS
    %u - o nome do usuário conectado
    Nenhuma funcionou.
    Meu profiles está em /home/profiles
    Ele está logando sem problemas mas não guarda o perfil. Na hora de logar ele dá duas mensagens de erro dizendo que não consegue contactar o servidor de perfis. Na outra ele diz que vai entrar com um perfil temporáreo e que não vai guardar as alterações quando fizer logoff.[/quote]
    karfax
    Voce não entendeu: pela sua configuração, sua pasta Profiles deveria estar em \\servidor\Profiles\fulano, foi voce quem definiu isso com:
    Mas não está. Está em /home/profiles. Ou voce move a pasta, ou muda o parâmetro.
    Sds,
    Jah troquei. Coloquei agora:
    Código :
    logon path = \\servidor-linux\profiles\
    Mas continua dando erro. Já estou ficando com raiva disso.
    Como eu faria para ele autenticar e acessr o samba mas o perfil ficar na máquina mesmo?
    whinston
    Padrão teste
    Citação Postado originalmente por White_Tiger
    Código :
    pq vc nao faz 1 teste + simples, no esquema 1 passo por vez pra tentar isolar?
    configura no braço onde vai ficar e vai usando 1 variavel por tentativa. ate vc achar onde ta pegando
    Brigadu pela ajuda mas jah resolvi. Tive que fazer algo parecido com isso. Agora estou querendo que alguns usuários em especial tenham permição para instalar programas.
    Alguem ae se abilita.
    Depois posto meu .conf pra galera que quer fazer algo parecido.
    rafaeu
    Padrão QUAL A VERSÃO DO WINDOWS???
    [size=18px][/size]QUAL A VERSÃO DO WINDOWS??
    [size=12px][/size] Se for 98 tive uma porra de problema...
    Bom como resolvi.?
    Primeiro defini o profile path = \\%L\profile\%U
    porque os homes do clientes
    depois criei o usuario no win98 Painel de controle->Adicionar usuario
    Lembre-se de efetuar logon na REDE.
    compartilhamento em SMB.conf
    [homes]
    path = /home/%U
    browseable = no
    writable = yes
    Lembre-se paresse locura, mas as coisas variam de instalação pra instalação ehheeehehheeh ......
    Já me ferrei um monte com logon script
    hauahua
    vlw
    rafaeu
    Bom camarada para os usuarios ter permissão de instalar programas no windows xp e 2000 funciona assim....
    primeiro vc cria um grupo que queira deixar como administrador exemplo "addgroup admin" (como kiser)
    depois vc tem que setar esse grupo como administrador no LINUX
    da seguinte forma!!
    net groupmap modify ntgroup="Domain Admins" unixgroup=admin --> conforme nosso exemplo.
    Claro que depois vc vai ter que setar os usuarios para o grupo q vc criou como administrador.
