    Padrão Estaçoes nao navega no Squid instalado no Slackware 10
    ola amigos
    estou tendo um problema com o Squid aqui....
    as estaçoes dos clientes quando tentar navegar olha so o q da no log:
    1116348348.515 1 192.168.254.1 TCP_DENIED/403 1380 GET http://cb.icq.com/cb/icqsrp/2032/srp.cb? - NONE/- text/html
    e na tela do cliente aparece isso:
    > The following error was encountered:
    Access Denied.
    > Access control configuration prevents your request from being allowed at
    > this time. Please contact your service provider if you feel this is
    > incorrect.
    > Your cache administrator is root.
    nao consigo navegar em nada!!!
    PQ Sera?
    alguem me da uma luz?
    segue abaixo meu squid.conf
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    # Only allow cachemgr access from localhost
    http_access deny manager
    # Deny requests to unknown ports
    http_access deny !Safe_ports
    # Deny CONNECT to other than SSL ports
    acl porno url_regex -i "/etc/squid/sitesmaus/siteblock.txt"
    acl sites dstdomain "/etc/squid/sitesmaus/sites.txt"
    acl unporno url_regex -i "/etc/squid/sitesmaus/sites.txt"
    acl ipsdiretoria src "/etc/squid/sitesmaus/ipsdiretoria.txt"
    acl ipsfunc src "/etc/squid/sitesmaus/ipsfunc.txt"
    acl rede_interna src 192.168.1.0/24
    http_access allow porno ipsdiretoria
    http_access allow sites ipsfunc rede_interna
    http_access deny porno !unporno ipsfunc
    http_access allow rede_interna
    http_access deny all
    Padrão squid proxy
    cara , esse ip da rede interna tem algum problema com ele!
    tente trocar o "acl rede_interna src 192.168.1.0/24" por acl rede_interna src 192.168.254.0/24
    troquei...mesma coisa....
    sera algo relacionado com o iptables ou 100% no SQUID MESMO!
    obrigado
    Padrão squid
    cara, me adiciona aew no seu MSN [email protected] pra gente resolver isso free mesmo!
    Coisa rápida!!!
