    Padrão Módulo P2P Iptables
    Ola pessoal to implementando o módulo P2P do Iptables e to com um problema na hora de compilar, quem puder me dar uma luz... ficarei grato!! após o #make
    recebo a mensagem de erro abaixo!!! :cry: :cry:
    #make
    make -C iptables
    make[1]: Entrando no diretório `/home/install/iptables-p2p-0.3.0a/iptables'
    gcc -O2 -Wall -DIPTABLES_VERSION=\"1.2.7a\" -I../common -c -o libipt_p2p.o libipt_p2p.c
    In file included from /usr/include/iptables/iptables.h:5,
    from libipt_p2p.c:23:
    /usr/include/iptables/libiptc/libiptc.h:5:40: libiptc/ipt_kernel_headers.h: Arquivo ou diretório não encontrado
    In file included from /usr/include/linux/netfilter_ipv4/ip_tables.h:18,
    from /usr/include/iptables/libiptc/libiptc.h:6,
    /usr/include/linux/netfilter_ipv4.h:53: `INT_MIN' undeclared here (not in a function)
    /usr/include/linux/netfilter_ipv4.h:53: enumerator value for `NF_IP_PRI_FIRST' not integer constant
    /usr/include/linux/netfilter_ipv4.h:59: `INT_MAX' undeclared here (not in a function)
    /usr/include/linux/netfilter_ipv4.h:59: enumerator value for `NF_IP_PRI_LAST' not integer constant
    In file included from /usr/include/iptables/libiptc/libiptc.h:6,
    /usr/include/linux/netfilter_ipv4/ip_tables.h:26: field `src' has incomplete type
    /usr/include/linux/netfilter_ipv4/ip_tables.h:26: field `dst' has incomplete type
    /usr/include/linux/netfilter_ipv4/ip_tables.h:28: field `smsk' has incomplete type
    /usr/include/linux/netfilter_ipv4/ip_tables.h:28: field `dmsk' has incomplete type
    /usr/include/linux/netfilter_ipv4/ip_tables.h:29: `IFNAMSIZ' undeclared here (not in a function)
    /usr/include/linux/netfilter_ipv4/ip_tables.h:30: `IFNAMSIZ' undeclared here (not in a function)
    make[1]: ** [libipt_p2p.o] Erro 1
    make[1]: Saindo do diretório `/home/install/iptables-p2p-0.3.0a/iptables'
    make: ** [linux-2.4] Erro 2
    cara, o código tá bugado! vc pode tentar corrigir ou deixar pra lá e esperar que alguém o faca!
    Citação Postado originalmente por 354mp
    Mas ja tem gente usando!!! e baixei da mesma fonte, :toim: :toim:
    veja o link http://www.slackware-brasil.com.br/w...eto.php?aid=74)
    segundo ele ta funcionando perfeito, e a instalação não tem segredo!!!
    brother, tambem quiz usar o iptables-p2p no trustix, mas num consegui de jeito nenhum. Tambem tava dando pau na instalação... :@:
    Citação Postado originalmente por roggy
    kraca!!! mas não desisti ainda.. to quebrando a cabeça!!!! :@: :@:
    quando tiver Ok... vou dar um look aki....
    ok... fico no aguardo!!
    sinestro
    Eu ate consegui compilar, mas nao funciona nem fudendo depois. A regra que vem junto com o pacote de limitacao nao roda e nem a de simples bloqueio. Acho que esse modulo ai é bugado mesmo.
    Alguem tem uma solucao pra isso?
    jgomes
    Padrão P2P Iptables
    Eu tenho isso funfando em varios servidores sem problemas. :clap:
    Qualquer duvida/ajuda email-me direto ok.
    Abraço,
    José Gomes
    jgomesjr em gmail.com
