    whinston
    Nocat instalado com radius e mysql instalados!
    Nenhum funcionou pq não consegui entender o cgi que eu tenho que ter e nem o retorno que ele deve fz pra funcionar a bagaça. Talvez com passwd seja mais fácil.
    [Fri May 27 20:30:07 2005] [error] [client 192.168.0.2] Can't locate NoCat.pm in @INC (@INC contains: ../lib/ /usr/local/lib/perl5/5.8.6/i686-linux /usr/local/lib/perl5/5.8.6 /usr/local/lib/perl5/site_perl/5.8.6/i686-linux /usr/local/lib/perl5/site_perl/5.8.6 /usr/local/lib/perl5/site_perl .) at /usr/local/apache-2.0.54/cgi-bin/login line 22.
    whinston
    Citação Postado originalmente por whinston
    [Fri May 27 21:13:59 2005] [error] [client 192.168.0.2] Compilation failed in require at /usr/local/lib/perl5/5.8.6/i686-linux/IO/Handle.pm line 260., referer: http://192.168.0.254/login.html
    [Fri May 27 21:13:59 2005] [error] [client 192.168.0.2] BEGIN failed--compilation aborted at /usr/local/lib/perl5/5.8.6/i686-linux/IO/Handle.pm line 260., referer: http://192.168.0.254/login.html
    [Fri May 27 21:13:59 2005] [error] [client 192.168.0.2] Compilation failed in require at /usr/local/lib/perl5/5.8.6/i686-linux/IO/Socket.pm line 11., referer: http://192.168.0.254/login.html
    [Fri May 27 21:13:59 2005] [error] [client 192.168.0.2] BEGIN failed--compilation aborted at /usr/local/lib/perl5/5.8.6/i686-linux/IO/Socket.pm line 11., referer: http://192.168.0.254/login.html
    [Fri May 27 21:13:59 2005] [error] [client 192.168.0.2] Compilation failed in require at /usr/local/nocat/authserv/lib/NoCat/AuthService.pm line 4., referer: http://192.168.0.254/login.html
    [Fri May 27 21:13:59 2005] [error] [client 192.168.0.2] BEGIN failed--compilation aborted at /usr/local/nocat/authserv/lib/NoCat/AuthService.pm line 4., referer: http://192.168.0.254/login.html
    [Fri May 27 21:13:59 2005] [error] [client 192.168.0.2] Compilation failed in require at /usr/local/nocat/authserv/lib/NoCat.pm line 345., referer: http://192.168.0.254/login.html
    [Fri May 27 21:13:59 2005] [error] [client 192.168.0.2] Premature end of script headers: login, referer: http://192.168.0.254/login.html
    [Fri May 27 21:13:59 2005] [error] [client 192.168.0.2] File does not exist: /var/www/html/www/favicon.ico
    [Fri May 27 21:13:59 2005] [error] [client 192.168.0.2] File does not exist: /var/www/html/www/var
  1. CGI em C
    Por augustolynx no fórum Servidores de Rede
    Último Post: 04-09-2003, 17:23
  2. 1 IP 2 dominios + cgi-bin virtual
    Respostas: 8
    Último Post: 07-02-2003, 14:05
  3. permissões de CGI
    Por dboom no fórum Linguagens de Programação
    Respostas: 8
    Último Post: 13-01-2003, 00:11
  4. Respostas: 3
    Último Post: 30-12-2002, 16:31
  5. Suporte CGI na virtaulhost
    Por adcorp no fórum Servidores de Rede
    Último Post: 16-12-2002, 11:33
