    MVZS
    Padrão instalando MLDonkey
    Olá Pessoas!
    Baixei e instalei o MLDonkey porém não consigo rodar ... oque está errado?
    [root@localhost MLDonkey]# mlnet
    No /root/.mldonkey/installer.ini found
    Resolving [localhost] ...done
    Using threads
    Network Global Shares registered
    Network Gnutella registered
    Network G2 registered
    Network Fasttrack registered
    Network FileTP registered
    Network BitTorrent registered
    Network Donkey registered
    No ./results.ini found
    Network.save_complex_options not implemented by BitTorrent
    Options correctly saved on localtime: 29/ 5, 20:54:16
    LOADING SHARED FILES AND SOURCES
    Network.load_complex_options not implemented by BitTorrent
    Network.load_complex_options not implemented by FileTP
    Network Donkey enabled
    Network BitTorrent enabled
    Network FileTP enabled
    Network Fasttrack disabled
    Network G2 disabled
    Network Gnutella disabled
    [DKKO] create_search
    [DKKO] create_search done
    Looks like you have no servers in your servers.ini
    You should either use the one provided with mldonkey
    or import one from the WEB
    op_network_recover_temp ++++++++++++++++++++++++++
    enable
    enabling...
    XXXXXXXXXXXXXXX
    Network.recover_temp not implemented by BitTorrent
    Network.recover_temp not implemented by FileTP
    Connection refused : connect
    chat_app_host=localhost chat_app_port=5036
    SHARING ./incoming PRIO 0
    Welcome to MLdonkey client
    Check http://www.mldonkey.net/ for updates
    To command: telnet 127.0.0.1 4000
    Or with browser: http://127.0.0.1:4080
    Welcome to MLdonkey
    Core started on localtime: 29/ 5, 20:54:16
    Disabling output to console, to enable: stdout true
    cttrondonia
    MVZS... instala o aMule... pq o mldonkey é banido em muitos servers ed2k
    MVZS
    Valew cttrondonia ! Estou com aMule instalado mas falta um pequeno detalhe. Ele informa ao iniciar que minha porta 4662 está fechada e isso vai deixar tudo lento. Como faço para abilitar esta porta?
    Cara qual eh o seu tipo de conexao se for adsl tem de liberar a porta no router, se for radio tem de pedir pra empresa, e se for virtua provavelmente eh so seu firewall.
    falows
    PS: no mldonkey na rede e2k vai dar esse mesmo problema
