  1. galera estou enfreentando dificuldade para instalar o mrtg e o nagios em um cliente meu. sera que alguem pode me ajudar com este problema.
  2. #!/bin/bash
    # Copyright (C) 2005 Pitanga, Marcos
    # This program is free software; you can redistribute it and/or
    # modify it under the terms of the GNU General Public License
    # as published by the Free Software Foundation; either version 2
    # of the License, or (at your option) any later version.
    # This program is distributed in the hope that it will be useful,
    # but WITHOUT ANY WARRANTY; without even the implied warranty of
    # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
    # GNU General Public License for more details.
    # You should have received a copy of the GNU General Public License
    # along with this program; if not, write to the Free Software
    # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
    # Script inicial para instalacao rapida do MRTG em ambiente Red Hat / Fedora
    # By Marcos Pitanga - 2005 - mpitanga@gplus.com.br
    #Definindo as variaveis
    WWWHOME="/var/www/html/mrtg"
    CONFIG="/etc/mrtg"
    printf "****************************************************************************\n"
    printf "** Este script facilita a instalacao do Multi Router Traffic Grapher **\n"
    printf "** By Marcos Pitanga **\n"
    # Somente o root pode executar o script
    CMD_RESPONSE=$(whoami)
    case $CMD_RESPONSE in
    root) ;;
    *) printf "Voce de ser root para rodar este script\n"; exit ;;
    esac
    # Criando o diretorio de configuracao
    # Senao existir crio os diretorios
    printf " \n"
    printf " Verificando a existencia dos diretorios\n"
    if [ ! -d $WWWHOME ]
    then
    mkdir $WWWHOME
    fi
    if [ ! -d $CONFIG ]
    then
    mkdir /etc/mrtg
    fi
    sleep 3
    printf " \n"
    printf "Qual o endereco IP da interface do roteador que desejas monitorar?\n"
    read IP
    #Criando o arquivo de configuracao
    cfgmaker --global 'WorkDir: $WWWHOME' --global 'Options[_]: bits,growright' --output $CONFIG/router.cfg $IP >$CONFIG/router.cfg
    #Criando a pagina inicial index.html
    indexmaker $CONFIG/router.cfg >$WWWHOME/index.html
    #Gerando as paginas para o MRTG
    mrtg $CONFIG/router.cfg
    clear
    # Ativando o MRTG para capturar de 15 em 15 minutos
    crontab -l > /tmp/crontab.mrtg
    echo "*/15 * * * * mrtg /etc/mrtg/router.cfg --logging /var/log/mrtg.log" >> /tmp/crontab.mrtg
    crontab /tmp/crontab.mrtg -u root
    rm /tmp/crontab.mrtg
    printf " MRTG configurado \n"
    service httpd restart
    clear
    printf " Ativando o Mozilla \n "
    mozilla http://localhost/mrtg
  3. Qual a dúvida relacionado ao nagios?
  4. a minha questão é a seguinte vou apenas monitorar, os serviços, de e-mail, web, ftp, e o consumo da banda do meu link. o nagios eu até instalei mas ele não abre as seções.
    so possuo um modem adsl e um servidor rodando atras deste modem.
    agradeço se puder me ajudar.
    acrufino
    Existe neste site dicas de como instalar o Nagios e seus plugins. O Nagios trabalha com associações de arquivos. Em /usr/local/nagios/etc verifique os arquivos: hosts.cfg e veja se o objeto de monitoramento está com o IP correto, no arquivo hostgroups.cfg verifique se o objeto está no grupo com o mesmo nome do arquivo hosts.cfg,veja também o arquivo hostextinfo.cfg, enfim os arquivos devem conter detalhes de configuração associados para não ocorrer problemas. Ao carregar o Nagios , #./ nagios start > anote a mensagem de erro para ficar algo mais específico.
    Espero ter ajudado.
  1. Problemas na configuração do monitor no CL9
    Por vonlinkerstain no fórum Servidores de Rede
    Respostas: 12
    Último Post: 07-11-2004, 07:51
  2. problema na instalacao do nagios
    Por muganga no fórum Servidores de Rede
    Último Post: 28-10-2004, 07:51
  3. Problemas na configuracao do dominio
    Por standart no fórum Servidores de Rede
    Respostas: 14
    Último Post: 02-10-2004, 10:02
  4. Problemas na Execução do NAGIOS
    Por jricardo no fórum Servidores de Rede
    Respostas: 8
    Último Post: 03-09-2004, 07:50
  5. problema na configuração do vsftpd
    Por roggy no fórum Servidores de Rede
    Último Post: 03-05-2004, 12:54
