- Erro no complilador C
Salve lista. Estou com o seguinte problema e gostaria de um help de vocês.
Tenho um cl8 e sempre que tento instalar algum programa usando o ./configure ele me apresenta o seguinte problema:
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking for C compiler default output file name... configure: error: C compiler cannot create executables
See `config.log' for more details.
Alguem pode me dá uma luz?!
Abaixo segue o arquivo config.log.
Grato
Athalimar
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.59. Invocation command line was
$ ./configure
## Platform. ##
hostname = linux.rifoles.com.br
uname -m = i686
uname -r = 2.4.18-2cl
uname -s = Linux
uname -v = #1 Mon Mar 11 01:53:17 BRT 2002
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = i686
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /usr/lib/kde3/bin
PATH: /usr/bin
PATH: /bin
PATH: /usr/sbin
PATH: /sbin
PATH: /usr/bin/X11
PATH: /usr/games
PATH: /usr/local/bin
PATH: /home/thales/bin
## Core tests. ##
configure:1342: checking build system type
configure:1360: result: i686-pc-linux-gnu
configure:1368: checking host system type
configure:1382: result: i686-pc-linux-gnu
configure:1448: checking for gcc
configure:1464: found /usr/bin/gcc
configure:1474: result: gcc
configure:1718: checking for C compiler version
configure:1721: gcc --version </dev/null >&5
2.95.3
configure:1724: $? = 0
configure:1726: gcc -v </dev/null >&5
Reading specs from /usr/lib/gcc-lib/i386-conectiva-linux/2.95.3/specs
gcc version 2.95.3 20010315 (release)
configure:1729: $? = 0
configure:1731: gcc -V </dev/null >&5
gcc: argument to `-V' is missing
configure:1734: $? = 1
configure:1757: checking for C compiler default output file name
configure:1760: gcc -g conftest.c >&5
/usr/bin/ld: cannot open crt1.o: No such file or directory
collect2: ld returned 1 exit status
configure:1763: $? = 1
configure: failed program was:
| /* confdefs.h. */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| /* end confdefs.h. */
| int
| main ()
| return 0;
configure:1802: error: C compiler cannot create executables
## Cache variables. ##
ac_cv_build=i686-pc-linux-gnu
ac_cv_build_alias=i686-pc-linux-gnu
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_host=i686-pc-linux-gnu
ac_cv_host_alias=i686-pc-linux-gnu
ac_cv_prog_ac_ct_CC=gcc
## Output variables. ##
BINDIR=''
CC='gcc'
CFLAGS=''
CPP=''
CPPFLAGS=''
DEFS=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
EXEEXT=''
HTMLDIR=''
LDFLAGS='-g'
LIBOBJS=''
LIBS=''
LTLIBOBJS=''
MANDIR=''
OBJEXT=''
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
SHELL='/bin/sh'
SYSCONFDIR=''
ac_ct_CC='gcc'
bindir='${exec_prefix}/bin'
build='i686-pc-linux-gnu'
build_alias=''
build_cpu='i686'
build_os='linux-gnu'
build_vendor='pc'
datadir='${prefix}/share'
exec_prefix='NONE'
host='i686-pc-linux-gnu'
host_alias=''
host_cpu='i686'
host_os='linux-gnu'
host_vendor='pc'
includedir='${prefix}/include'
infodir='${prefix}/info'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localstatedir='${prefix}/var'
mandir='${prefix}/man'
oldincludedir='/usr/include'
prefix='NONE'
program_transform_name='s,x,x,'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
configure: exit 77
vc tem o GCC instalado nessa maquina?
parece que é erro de versão de gcc, mas fiquei um pouco confuso...
gcc instalado
tenho o gcc instalado sim. gcc.2.95.3-.36cl
também tenho o glib-1.2.10-4cl
pelo menos no Debian a versão é a 3.0
Eu acho que ainda ta faltando alguma coisa !!!
resolvido
isso mesmo gatoseco. Estava faltando as bibliotecas task-c-devel
task-c++-devel
instalei e funcionou 100%
muito grato e fiquem com Deus
Cara tente atualiza suas bibliotes gcc ta desatualizada
O problema ja foi resolvido !!!
