    thiagog
    Padrão WINE / WINEX
    boa noite pessoal,
    tenho um FEDORA CORE 2 padrao com Xserver + KDE tudo certim rodando uma maravilha;
    agora estou testando o wine;
    baixei , compilei e instalei tudo ok
    rodei jogos do windows, notepad tudo q tem de padrao no windows q nao precisa muito de DLLs para funcionar;
    qdo fui tentar todar o kazaa ERROS:
    - essa aplicacao nao roda em WINDOWS 98 :toim:
    o que eu devo fazer ?
    1. alguem aqui ja rodou CStrike no Linux ? (pode me ajudar)
    2. alguem aqui ja rodou MS Office no linux (tipo o MS ACCESS) ??
    Obrigado,
    --- meu config do WINE ---
    WINE REGISTRY Version 2
    ;; All keys relative to \\Machine\\Software\\Wine\\Wine\\Config
    ;; If you think it is necessary to show others your complete config for a
    ;; bug report, filter out empty lines and comments with
    ;; grep -v "^;" ~/.wine/config | grep '.'
    [wine]
    ;"ShowDirSymlinks" = "1"
    ;"ShowDotFiles" = "1"
    # [wineconf]
    [Version]
    ; Windows version to imitate (win95,win98,winme,nt351,nt40,win2k,winxp,win2k3,win20,win30,win31)
    ;"Windows" = "win98"
    ; DOS version to imitate
    ;"DOS" = "6.22"
    ; Be careful here, wrong DllOverrides settings have the potential
    ; to pretty much kill your setup.
    [DllOverrides]
    ; some dlls you may want to change
    "oleaut32" = "builtin, native"
    "ole32" = "builtin, native"
    "comdlg32" = "builtin, native"
    "shell32" = "builtin, native"
    "shfolder" = "builtin, native"
    "shlwapi" = "builtin, native"
    "shdocvw" = "builtin, native"
    "advapi32" = "builtin, native"
    "msvcrt" = "native, builtin"
    "mciavi.drv" = "native, builtin"
    "mcianim.drv" = "native, builtin"
    "d3drm" = "native, builtin"
    "d3dxof" = "native, builtin"
    "dpnhpast" = "native, builtin"
    ; you can specify applications too
    ; this one will apply for all notepad.exe
    ;"*notepad.exe" = "native, builtin"
    ; this one will apply only for a particular file
    ;"C:\\windows\\regedit.exe" = "native, builtin"
    ; default for all other dlls
    "*" = "builtin, native"
    [x11drv]
    ; Number of colors to allocate from the system palette
    "AllocSystemColors" = "100"
    ; Use a private color map
    "PrivateColorMap" = "N"
    ; Favor correctness over speed in some graphics operations
    "PerfectGraphics" = "N"
    ; Color depth to use on multi-depth screens
    ;;"ScreenDepth" = "16"
    ; Allow the window manager to manage created windows
    "Managed" = "Y"
    ; Use a desktop window of 640x480 for Wine
    ;"Desktop" = "640x480"
    ; Use XFree86 DGA extension if present
    ; (make sure /dev/mem is accessible by you !)
    "UseDGA" = "Y"
    ; Use XVidMode extension if present
    "UseXVidMode" = "Y"
    ; Use XRandR extension if present
    "UseXRandR" = "Y"
    ; Use the take focus protocol
    "UseTakeFocus" = "Y"
    ; Use primary selection in addition to clipboard
    "UsePrimarySelection" = "N"
    ; Enable DirectX mouse grab
    "DXGrab" = "N"
    ; Create the desktop window with a double-buffered visual
    ; (useful to play OpenGL games)
    "DesktopDoubleBuffered" = "N"
    ; Run in synchronous mode (useful for debugging X11 problems)
    ;;"Synchronous" = "Y"
    ; Use the Render extension to render client side fonts (default "Y")
    ;;"ClientSideWithRender" = "Y"
    ; Fallback on X core requests to render client side fonts (default "Y")
    ;;"ClientSideWithCore" = "Y"
    ; Set both of the previous two to "N" in order to force X11 server side fonts
    ; Anti-alias fonts if using the Render extension (default "Y")
    ;;"ClientSideAntiAliasWithRender" = "Y"
    ; Anti-alias fonts if using core requests fallback (default "Y")
    ;;"ClientSideAntiAliasWithCore" = "Y"
    [fonts]
    ;Read the Fonts topic in the Wine User Guide before adding aliases
    ;See a couple of examples for russian users below
    "Default" = "-adobe-helvetica-"
    "DefaultFixed" = "fixed"
    "DefaultSerif" = "-adobe-times-"
    "DefaultSansSerif" = "-adobe-helvetica-"
    ;; default TrueType fonts with russian koi8-r encoding
    ;"Default" = "-monotype-arial-*-*-*--*-*-*-*-*-*-koi8-r"
    ;"DefaultFixed" = "-monotype-courier new-*-*-*--*-*-*-*-*-*-koi8-r"
    ;"DefaultSerif" = "-monotype-times new roman-*-*-*--*-*-*-*-*-*-koi8-r"
    ;"DefaultSansSerif" = "-monotype-arial-*-*-*--*-*-*-*-*-*-koi8-r"
    ;; default cyrillic bitmap X fonts
    ;"Default" = "-cronyx-helvetica-"
    ;"DefaultFixed" = "fixed"
    ;"DefaultSerif" = "-cronyx-times-"
    ;"DefaultSansSerif" = "-cronyx-helvetica-"
    ; the TrueType font dirs you want to make accessible to wine
    [FontDirs]
    ;"dir1" = "/usr/X11R6/lib/X11/fonts/TrueType"
    ;"dir2" = "/usr/share/fonts/truetype"
    ;"dir3" = "/usr/X11R6/lib/X11/fonts/TT"
    ;"dir4" = "/usr/share/fonts/TT"
    [ppdev]
    ;; key: io-base of the emulated port
    ;; value : parport-device{,timeout}
    ;; timeout for auto closing an open device ( not yet implemented)
    ;"378" = "/dev/parport0"
    ;"278" = "/dev/parport1"
    ;"3bc" = "/dev/parport2"
    [spooler]
    "FILE:" = "tmp.ps"
    "LPT1:" = "|lpr"
    "LPT2:" = "|gs -sDEVICE=bj200 -sOutputFile=/tmp/fred -q -"
    "LPT3:" = "/dev/lp3"
    [ports]
    ;"read" = "0x779,0x379,0x280-0x2a0"
    ;"write" = "0x779,0x379,0x280-0x2a0"
    [Debug]
    ;"RelayExclude" = "RtlEnterCriticalSection;RtlLeaveCriticalSection"
    ;"RelayInclude" = "user32.CreateWindowA"
    ;"RelayFromExclude" = "user32;x11drv"
    ;"RelayFromInclude" = "sol.exe"
    ;"SnoopExclude" = "RtlEnterCriticalSection;RtlLeaveCriticalSection"
    ;"SpyExclude" = "WM_SIZE;WM_TIMER;"
    ; List of all directories directly contain .AFM files
    [afmdirs]
    "1" = "/usr/share/ghostscript/fonts"
    "2" = "/usr/share/a2ps/afm"
    "3" = "/usr/share/enscript"
    "4" = "/usr/X11R6/lib/X11/fonts/Type1"
    [WinMM]
    ; Uncomment the "Drivers" line matching your sound setting.
    "Drivers" = "wineoss.drv" ; default for most common configurations
    ;"Drivers" = "winearts.drv" ; for KDE
    ;"Drivers" = "winealsa.drv" ; for ALSA users
    ;"Drivers" = "winejack.drv" ; for Jack sound server
    ;"Drivers" = "winenas.drv" ; for NAS sound system
    ;"Drivers" = "wineaudioio.drv" ; for Solaris machines
    ;"Drivers" = "" ; to disable sound
    "WaveMapper" = "msacm.drv"
    "MidiMapper" = "midimap.drv"
    [dsound]
    ;; HEL only: Number of waveOut fragments ahead to mix in new buffers.
    ;"HELmargin" = "5"
    ;; HEL only: Number of waveOut fragments ahead to queue to driver.
    ;"HELqueue" = "5"
    ;; Max number of fragments to prebuffer
    ;"SndQueueMax" = "28"
    ;; Min number of fragments to prebuffer
    ;"SndQueueMin" = "12"
    ;; Forces emulation mode (using wave api)
    ;"HardwareAcceleration" = "Emulation"
    ;; Sets default playback device (0 - number of devices - 1)
    ;"DefaultPlayback" = "0" ; use first device (/dev/dsp)
    ;"DefaultPlayback" = "1" ; use second device (/dev/dsp1)
    ;"DefaultPlayback" = "2" ; use third device (/dev/dsp2)
    ;; Sets default capture device (0 - number of devices - 1)
    ;"DefaultCapture" = "0" ; use first device (/dev/dsp)
    ;"DefaultCapture" = "1" ; use second device (/dev/dsp1)
    ;"DefaultCapture" = "2" ; use third device (/dev/dsp2)
    [Network]
    ;; Use the DNS (Unix) host name always as NetBIOS "ComputerName" (boolean, default "Y").
    ;; Set to N if you need a persistent NetBIOS ComputerName that possibly differs
    ;; from the Unix host name. You'll need to set ComputerName in
    ;; HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\ComputerName\ComputerName, too.
    ;"UseDnsComputerName" = "N"
    ;; sample AppDefaults entries
    ; 3 InstallShield versions who like to put their full screen window in front,
    ; without any chance to switch to another X11 application.
    ; So just catch them in a desktop window.
    [AppDefaults\\_INS0432._MP\\x11drv]
    [AppDefaults\\_INS0466._MP\\x11drv]
    [AppDefaults\\_INS0576._MP\\x11drv]
    [AppDefaults\\_INS5176._MP\\x11drv]
    [AppDefaults\\_INS5576._MP\\x11drv]
    "Desktop" = "800x600"
    ;[AppDefaults\\iexplore.exe\\DllOverrides]
    ;"shlwapi" = "native"
    ;"rpcrt4" = "native"
    ;"ole32" = "native"
    ;"shdocvw" = "native"
    ;"wininet" = "native"
    ;"shfolder" = "native"
    ;"shell32" = "native"
    ;"shell" = "native"
    ;"comctl32" = "native"
    ;[AppDefaults\\setup.exe\\x11drv]
    ;"Desktop" = "800x600"
    ;[AppDefaults\\sol.exe\\Version]
    ;"Windows" = "nt40"
    ;; Some games (Quake 2, UT) refuse to accept emulated dsound devices.
    ;; You can add an AppDefault entry like this for such cases.
    ;[AppDefaults\\pickygame.exe\\dsound]
    ;"EmulDriver" = "N"
    [Drive A]
    "Path"="/mnt/floppy"
    [Drive C]
    "Type"="hd"
    "Path"="win/c"
    [Drive D]
    "Type"="cdrom"
    "Path"="/mnt/cdrom"
    # [/wineconf]
    --- EOF ---
    Padrão WINE / WINEX
    kra... o winetools tem um lance q cria um pseudo ambiente pra vc poder executar aplicacoes comuns como o office
    jah o kazaa... tem q rodar uma versao mto antiga dele pra funcionar.. nao eh legalz!! usa o sharezaa.. q instala blzinha
    quanto ao cs... olha o nosso forum d games... q tem varias instrucoes d como fazer o kra funcionar lah
    []'s
    thiagog
    Padrão valeu demiurgo ..
    :good:
    Padrão WINE / WINEX
    Cara com o wine nunca rodei cstrike, mas com o cedega e winex, e rodou legal, com o ultimo cedega ate ordeio cs:source, mas tem alguns problemas que não consegui resolver em relação a pegar a lista de servidores so dando pra conectar direto, mas ate rodoulegal.
    sei que MS Office com o cross office ja vem os isntaladores de padrao.
    falows
