    haas
    Padrão Recomendação de software de backup
    Estou procurando um software de backup com DVD, preciso que seja criado backup em multi-volume, qual seria o mais indicado?
    slice
    eu uso um script em shell bash para fazer backup multivolumes em cd das minhas maquinas, acho que a sintax não deve mudar muito em relação à gravação em dvd's...
    #!/bin/bash
    # Main Settings of Backup Script
    which="/usr/bin/which"
    cdrecord="`$which cdrecord`"
    tar="`$which tar`"
    touch="`$which touch`"
    # Drive for backup copy
    drive="/dev/hdc"
    # Size of Media
    cdsize="665600"
    # Speed for record CD
    speed="4"
    # Mount Point
    backup_dir="/tmp/backup"
    # Backup tmp dir for iso files
    backup_tmp_iso="/tmp/iso"
    # Section of cdrom
    track="`$cdrecord -msinfo dev=$drive 2> /dev/null | awk '{print $1}'`"
    #track="`$cdrecord -msinfo dev=$drive`"
    # Flag of compression tar file
    flag="-pczvf"
    # File extension of compression tar file
    ext="tar.gz"
    # Backup Daily including list
    daily_list="/etc/backup/daily.list"
    # Backup Full including list
    full_list="/etc/backup/full.list"
    # Backup LOG Dir
    log_dir="/var/log/backup"
    # Date of Backup
    date_name="`date +%d`"
    # Date of ISO
    date_iso="`date +%a`"
    # Date name of log
    date_log="`date +%d_%m_%Y`"
    # Today
    today="`date +%w`"
    main() {
    checkdir
    if [ $today = 0 ]; then
    backupfull
    isofull
    blank
    else
    backupdaily
    isodaily
    fi
    checksize
    burncd
    backupfull() {
    # Make LOG file
    $touch $log_dir/backup$date_log.log
    # Remove old backups
    rm -f $backup_dir/*
    # Make tar compressed files from Backup List
    for BACKUP_FILE in `grep -v ^# $full_list`
    do
    BACKUP_NAME="$backup_dir/`date +%a`-`echo $BACKUP_FILE|sed s+\/++g`.$ext"
    rm -f $BACKUP_NAME
    $tar $flag $BACKUP_NAME --exclude /usr/src $BACKUP_FILE
    echo "$BACKUP_NAME" >> $log_dir/backup$date_name.log
    done
    backupdaily() {
    # Make LOG file
    rm -f $backup_dir/*
    for BACKUP_FILE in `grep -v ^# $daily_list`
    do
    rm -f $BACKUP_NAME
    done
    isofull() {
    mkisofs -o $backup_tmp_iso/backup$date_iso.iso -JrT $backup_dir
    isodaily() {
    # Remove old iso files
    rm -f $backup_tmp_iso/*
    if [ $today = 1 ]; then
    # Make iso image of Monday backup
    else
    # Make iso image of other daily backups
    mkisofs -o $backup_tmp_iso/backup$date_iso.iso -JrT -C $track -M $drive $backup_dir
    fi
    checkdir() {
    # Check if exist backup_dir
    if [ -e $backup_tmp_iso ]; then
    echo "OK" > /dev/null
    else
    mkdir $backup_tmp_iso
    fi
    if [ -e $backup_dir ]; then
    else
    mkdir $backup_dir
    fi
    if [ -e $log_dir ]; then
    else
    mkdir $log_dir
    fi
    checksize() {
    if [ `ls -s $backup_tmp_iso/backup$date_iso.iso | sed 's/[A-Z]//g' | awk '{print $1}'` -lt $cdsize ] ; then
    echo "OK"
    else
    echo "A imagem nao cabe no CD!!!"
    exit 0
    fi
    burncd() {
    # Check first or others tracks
    $cdrecord dev=$drive -v speed=$speed -multi -data $backup_tmp_iso/backup$date_iso.iso
    eject $drive
    blank() {
    $cdrecord dev=$drive -blank=fast
    main
    karfax
    Amanda...
    []s,
    slice
    Hehehehe!!!!!
    Como a curiosidade matou o gato... Aproveitei uma promoção numa loja aqui em SJK e comprei um DVD+RW LG. Para minha surpresa, as coisas ficaram muito mais fáceis com o DVD...
    Veja como ficou a versão atualizada do script postado acima (CD+RW), para a utilização no drive de DVD...
    PS.: Não esqueça de criar os arquivos /etc/backup/daily.list e full.list, com os diretórios que serão incluídos no backup... tipo:
    #Diretorios de Backup
    /bin
    /boot
    /etc
    /home
    /root
    /usr
    #/win_xp
    #/debian
    /var
    #!/bin/bash
    growisofs="`$which growisofs`"
    tar="`$which tar`"
    drive="/dev/hdb"
    # Temp for Backup
    bkp_dir="/tmp/backup"
    flag="-pcjvf"
    # File extension of compressed tar file
    ext="tar.bz2"
    # Date of Backup
    # Today
    today="`date +%w`"
    main() {
    checkdir
    mkbkp
    burndvd
    checkdir() {
    # Check if exist bkp_dir
    if [ -e $bkp_dir ]; then
    else
    mkdir $bkp_dir
    fi
    mkbkp() {
    rm -f $bkp_dir/*
    # Make tar compressed files from Full Backup List
    list="$full_list"
    else
    list="$daily_list"
    fi
    # Make tar compressed files from Daily Backup List
    for BACKUP_FILE in `grep -v ^# $list`
    do
    BACKUP_NAME="$bkp_dir/`date +%a`-`echo $BACKUP_FILE|sed s+\/++g`.$ext"
    rm -f $BACKUP_NAME
    done
    burndvd() {
    $growisofs -Z $drive -R -J $bkp_dir
    else
    $growisofs -M $drive -R -J $bkp_dir
    fi
    main
    cara ja tentou o mondo?? www.mondorescue.org
    falows
    Padrão Instrucoes + script... adapte!
    Amigo, de uma lida nisso:
    http://geinf26.intranet.sefin.ro.gov...es%20Linux.htm
    Vou deixar disponivel por 2 dias... copie o HTML pra vc...
    Tente adaptar para /dev/hdc (drive DVD), pois o tutorial todo eh para /dev/st0 (dat)...
    flw...
