    Padrão help mysql.
    [email protected]#/usr/bin/mysql_install_db
    Installing all prepared tables
    Fill help tables
    To start mysqld at boot time you have to copy support-files/mysql.server
    to the right place for your system
    PLEASE REMEMBER TO SET A PASSWORD FOR THE MySQL root USER !
    To do so, start the server, then issue the following commands:
    /usr/bin/mysqladmin -u root password 'new-password'
    /usr/bin/mysqladmin -u root -h frigoking password 'new-password'
    See the manual for more instructions.
    NOTE: If you are upgrading from a MySQL <= 3.22.10 you should run
    the /usr/bin/mysql_fix_privilege_tables. Otherwise you will not be
    able to use the new GRANT command!
    You can start the MySQL daemon with:
    cd / ; /usr/bin/mysqld_safe &
    You can test the MySQL daemon with the benchmarks in the 'sql-bench' directory:
    cd sql-bench ; perl run-all-tests
    Please report any problems with the /usr/bin/mysqlbug script!
    The latest information about MySQL is available on the web at
    http://www.mysql.com
    Support MySQL by buying support/licenses at https://order.mysql.com
    eu tento mudar a senha mas da pau!
    da permission denied...
    wrochal
    Padrão help mysql.
    Caro,
    Basta arrumar o dono do MySQL no dir /var/lib/mysql
    chown mysql.mysql -Rf /var/lib/mysql
    Falou,
