- senha mysql
senha mysql
[email protected]/tmp# mysqladmin -u root password senha
mysqladmin: connect to server at 'localhost' failed
error: 'Access denied for user 'root'@'localhost' (using password: YES)'
fui criar a senha e não funciona...
detalhe que n aparece senha nenhuma como padrao
senha mysql
vc jah usou o mysql-install-db?
[]'s
#MOVED TO BANCO DE DADOS :twisted: :twisted: :twisted:
senha mysql
quando uso da este erro.
[email protected]#/usr/bin/mysql_install_db
Installing all prepared tables
Fill help tables
To start mysqld at boot time you have to copy support-files/mysql.server
to the right place for your system
PLEASE REMEMBER TO SET A PASSWORD FOR THE MySQL root USER !
To do so, start the server, then issue the following commands:
/usr/bin/mysqladmin -u root password 'new-password'
/usr/bin/mysqladmin -u root -h frigoking password 'new-password'
See the manual for more instructions.
NOTE: If you are upgrading from a MySQL <= 3.22.10 you should run
the /usr/bin/mysql_fix_privilege_tables. Otherwise you will not be
able to use the new GRANT command!
You can start the MySQL daemon with:
cd / ; /usr/bin/mysqld_safe &
You can test the MySQL daemon with the benchmarks in the 'sql-bench' directory:
cd sql-bench ; perl run-all-tests
Please report any problems with the /usr/bin/mysqlbug script!
The latest information about MySQL is available on the web at
http://www.mysql.com
Support MySQL by buying support/licenses at https://order.mysql.com
senha mysql
su mysql -c /usr/bin/mysql_install_db
mysql -u root -p
senha
dai funcionoou :good:
senha mysql
# su mysql
mysql_install_db
mysql -u root -p
senha
primeiro logue-se com mysql depois execute o comando e altere a senha!!!
Tem um material no propio under explicando como fazer isso, escrito pelo seco veio aqui da uma olhada vai te ajudar !!!
Ta na sessao mysql !!!
Valeu
