    Geromel
    Padrão Jabberd - nao inicializa
    Pessoal,
    Estou com problemas no jabberd, quando tento inicializar o servico aparece a seguinte erro :
    20050701T18:56:06: [notice] (-internal): initializing server
    20050701T18:56:06: [alert] (-internal): io_select unable to listen on 5222 [ 192.168... ]: jabberd already running or invalid interface?
    20050701T18:56:06: [alert] (-internal): io_select unable to listen on 5269 [ 192.168... ]: jabberd already running or invalid interface?
    20050701T18:57:43: [notice] (-internal): shutting down server
    estou com 40 usuarios parados ... urgente .....
    Valeu e obrigado galera ....
    If you haven't already, you need to add the following in /etc/rc.conf:
    jabberd_enable="YES"
    jabberd_user={user}
    http://jabberd.jabberstudio.org/1.4/doc/adminguide
    http://lists.nycbug.org/pipermail/ta...ay/005363.html
    Geromel
    so, my linux is red hat , it isn´t have this file rc.conf !!!
    i don´t no !!!!
    help ...
    g geromel
    Citação Postado originalmente por MAJOR
    jabberd_user={user}
