    grmuniz
    Padrão Problemas para startar o named
    Alô pessoal
    Estou tendo problemas com o meu dns, já tentei de tudo e sempre que executo o comando service named restart recebo a serguinte mensagem:
    Parando o named: rndc: connect failed: connection refused
    [FALHOU]
    Iniciando named: [ OK ]
    Não consegui achar erros nos arquivos de configuração, mas estou mandando-os junto com os logs do sistema.
    Estou mandando os logs do sistema e os meus arquivos de configuração, se alguém poder me dar uma ajuda sou grato.
    PS: uso Fedora 2
    #--> /var/log/messages
    [[email protected] named]# tail /var/log/messages
    Jul 3 14:39:11 secinfo1 named: desligar named failed
    Jul 3 17:39:13 secinfo1 named[4955]: starting BIND 9.2.3 -u named -t /var/named/chroot
    Jul 3 17:39:13 secinfo1 named[4955]: using 1 CPU
    Jul 3 17:39:13 secinfo1 named[4955]: loading configuration from '/etc/named.conf'
    Jul 3 17:39:13 secinfo1 named[4955]: /etc/named.conf:6: change directory to '/var/named' failed: permission denied
    Jul 3 17:39:13 secinfo1 named[4955]: /etc/named.conf:6: parsing failed
    Jul 3 17:39:13 secinfo1 named[4955]: loading configuration: permission denied
    Jul 3 17:39:13 secinfo1 named[4955]: exiting (due to fatal error)
    Jul 3 14:39:13 secinfo1 named: início de named succeeded
    #--> /etc/named.conf
    #--> /var/named/chroot/etc/named.conf
    [[email protected] named]# cat /etc/named.conf
    //etc/named.conf
    options {
    directory "/var/named";
    query-source address * port 53;
    forwarders { 200.215.1.35; 200.180.128.69; };
    forward only;
    // a caching only nameserver config
    controls {
    inet 127.0.0.1 allow { localhost; } keys { rndckey; };
    zone "." IN {
    type hint;
    file "named.ca";
    zone "localhost" IN {
    type master;
    file "localhost.zone";
    allow-update { none; };
    zone "0.0.127.in-addr.arpa" IN {
    type master;
    file "named.local";
    zone "rede.net" IN {
    type master;
    file "rede.net.hosts";
    // allow-update { none; };
    zone "10.168.192.in-addr.arpa" IN {
    type master;
    file "10.168.192.in-addr.arpa.zone";
    include "/etc/rndc.key";
    [[email protected] named]# cat /var/named/rede.net.hosts
    $TTL 86400
    $ORIGIN rede.net.
    @ 1D IN SOA @ root.rede.net. (
    42 ; serial (d. adams)
    3H ; refresh
    15M ; retry
    1W ; expiry
    1D ) ; minimum
    1D IN NS rede.net.
    1D IN A 192.168.10.1
    [[email protected] named]# cat 10.168.192.in-addr.arpa.zone
    $TTL 86400
    @ IN SOA rede.net. root.rede.net. (
    1997022700 ; Serial
    28800 ; Refresh
    14400 ; Retry
    3600000 ; Expire
    86400 ) ; Minimum
    IN NS rede.net.
    5 IN PTR rede.net.
    [[email protected] arquivos]# cat /etc/hosts
    # Do not remove the following line, or various programs
    # that require network functionality will fail.
    127.0.0.1 localhost.localdomain localhost
    192.168.10.1 secinfo1.rede.net secinfo1
    [[email protected] arquivos]# cat /etc/rndc.conf
    * Sample rndc configuration file. */
    options {
    default-server localhost;
    default-key "rndckey";
    server localhost {
    key "rndckey";
    [[email protected] arquivos]# cat /etc/rndc.key
    key "rndckey" {
    algorithm hmac-md5;
    secret "OioXIKD6D7S1Vglq52Xf7vFbkf300Zef39tcUd2OCUdhNCEUWGHNsZL8cTQY";
    Jan 2004
    Capital do Triângulo
    "/etc/named.conf:6: change directory to '/var/named' failed: permission denied"
    veja este erro ae... seu named estah enjaulado? reveja as permissoes... e mude seu secretkey depois, pois vc o divulgou aqui. :good:
    grmuniz
    Enjaulado???
    Como isso funciona???
    isso... se ele estah em chroot...
    pra mais detalhes.. d uma olhada nesse artigo
    https://under-linux.org/noticia4337.html
    []'s
    Padrão Re: Problemas para startar o named
    Foi vc que configurou esse dns ???
    grmuniz
    sim, faltava uma linha no .conf, mas já corrigi
