    sady
    Padrão configuração do mrtg
    instalei ele bonitinho... sem erro nenhum... mas na hora q dei esse comando pra configurar:
    ./cfgmaker --global 'WorkDir: /var/www/mrtg' --global 'Options[_]: bits,growright' --global 'RunAsDaemon:Yes' --output /home/sady/mrtg-2.11.1/mrtg.cfg 129.13.145.160
    ele da essas msg:
    --base: Get Device Info on [email protected]:
    SNMP Error:
    no response received
    SNMPv1_Session (remote host: "129.13.145.160" [129.13.145.160].161)
    community: "public"
    request ID: -1028107200
    PDU bufsize: 8000 bytes
    timeout: 2s
    retries: 5
    backoff: 1)
    at /usr/local/mrtg-2/bin/../lib/mrtg2/SNMP_util.pm line 627
    SNMPWALK Problem for 1.3.6.1.2.1.1 on [email protected]::::::v4only
    at ./cfgmaker line 796
    WARNING: Skipping [email protected]: as no info could be retrieved
    --base: Writing /home/sady/mrtg-2.11.1/mrtg.cfg
    o q ta dando de errado?
    Bili
    Padrão SNMP
    opa...
    bom.. vc tem o SNMP instalado e rodando. ???
    o problema ta nisso o mrtg nao tá conseguindo
    buscar a informação nescessaria para gerar a estatistica...
