    yamazaki
    Padrão Duvida APT para Suse 9.2
    Pessoal, instalei os pacotes apt-lib e apt. Configurei o arquivo sources.list porem ao executar o comando apt-get install para instalar qualquer arquivo com base nos repositorios do meu source.list eh apresentado o erro abaixo. Alguem poderia me ajudar?
    yamazaki:/home/yamazaki # apt-get install synaptic
    Reading Package Lists... Done
    Building Dependency Tree... Done
    E: Couldn't find package synaptic
    Segue conteudo do meu sources.list:
    # Uncomment the line below, in case you want to use SuSE's patch rpms.
    # Read the information about patch rpms at http://linux01.gwdg.de/apt4rpm
    # rpm ftp://ftp.gwdg.de/pub/linux/suse/apt/ SuSE/9.2-i386 update-prpm security-prpm
    # A very basic sources.list line. Fastest repository first.
    # Remove "base" in case you are behind a
    # slow connection. Fastest repository first.
    # Visit the server to determine which apt components are provided.
    # rpm ftp://mirrors.mathematik.uni-bielefe...inux/suse/apt/ SuSE/9.2-i386 update security
    rpm ftp://ftp.gwdg.de/pub/linux/suse/apt/ SuSE/9.2-i386 update security base funktronics update misc mozilla suser-rbossuser-guru suser-gbv packman packman-i686 wine suse-projects kde3-stable
    # The list with all available components can be found at:
    # http://linix01.gwdg.de/apt4rpm
    # Some components provide experimental software, select wisely!
    # http://ftp.gwdg.de/pub/linux/suse/ap...urces.list.FTP
    # Consult the link above if you want to include uri's for src rpms
    yamazaki
    Padrão dificuldade p/ instalar via apt
    Citação Postado originalmente por yamazaki
    da um apt-get update antes .
    falows
