  1. Aeh galera, vejam meu firewall, o que acontece é que o samba não funciona, alguém pode me dar uma luz
    #Tabela filter
    /sbin/iptables -t filter -P INPUT DROP
    /sbin/iptables -t filter -P OUTPUT ACCEPT
    /sbin/iptables -t filter -P FORWARD DROP
    # Tabela nat
    /sbin/iptables -t nat -P PREROUTING ACCEPT
    /sbin/iptables -t nat -P OUTPUT ACCEPT
    /sbin/iptables -t nat -P POSTROUTING ACCEPT
    #Permite tráfego local
    #/sbin/iptables -t filter -A INPUT -i lo -j ACCEPT
    #Limita pings a 1 por segundo, request and reply
    /sbin/iptables -A block -p icmp -d 192.168.0.1 --icmp-type echo-request -m limit --limit 1/s -j ACCEPT
    /sbin/iptables -A block -p icmp -d 192.168.0.1 --icmp-type echo-reply -m limit --limit 1/s -j ACCEPT
    /sbin/iptables -A block -p icmp -d 127.0.0.1 --icmp-type echo-request -m limit --limit 1/s -j ACCEPT
    /sbin/iptables -A block -p icmp -d 127.0.0.1 --icmp-type echo-reply -m limit --limit 1/s -j ACCEPT
    #Limita a um maximo de 6 conexões por segundo
    /sbin/iptables -A block -p tcp --syn -m limit --limit 6/s
    #Aceita conexões para http e dns
    /sbin/iptables -A block -p tcp -d 192.168.0.1 --syn --destination-port 80 -j ACCEPT
    /sbin/iptables -A block -p tcp -d 192.168.0.1 --syn --destination-port 53 -j ACCEPT
    #Permite o samba funcionar
    /sbin/iptables -A block -p tcp -s 192.168.0.0/24 -i eth0 --destination-port 137:139 -j ACCEPT
    /sbin/iptables -A block -p tcp -s 192.168.0.0/24 -i eth0 --destination-port 445 -j ACCEPT
    /sbin/iptables -A block -p udp -s 192.168.0.0/24 -i eth0 --destination-port 137:139 -j ACCEPT
    /sbin/iptables -A block -p udp -s 192.168.0.0/24 -i eth0 --destination-port 445 -j ACCEPT
    #Bloqueia acesso a todas as outras portas
    /sbin/iptables -A block -p tcp -d 192.168.0.1 --destination-port 0:1024 -j DROP
    /sbin/iptables -A block -p udp -d 192.168.0.1 --destination-port 0:1024 -j DROP
    #Aceita conexões exceto as vindas de ppp0
    /sbin/iptables -A block -m state --state NEW -i ! ppp0 -j ACCEPT
    /sbin/iptables -A block -m state --state ESTABLISHED,RELATED -j ACCEPT
    /sbin/iptables -A block -j DROP
    ## Saltar das chains INPUT e FORWARD para a CHAIN block.
    /sbin/iptables -t filter -A INPUT -j block
    /sbin/iptables -t filter -A FORWARD -j block
    e mais uma coisa, se eu colocar a regra
    depois das regras de policiamento padrão, eu consigo fazer o ssh para 192.168.0.1 memo temdo a regra
    no final do script por que isso? a regra --dport :1024 nao deveria bloquear o ssh?
  2. Amigo da onde vc tirou esse script ??? Vc mesmo desenvolveu isso deacordo com suas necessidades???
    Valeu !!!
  1. LIBERAR DHCP NO FIREWALL - SUSE 9.3
    Por rfdasilva1 no fórum Servidores de Rede
    Último Post: 09-09-2005, 07:02
  2. Liberar portas no firewall
    Por Dhaushin no fórum Servidores de Rede
    Último Post: 12-08-2005, 11:22
  3. Liberar VPN no firewall
    Por cristianff no fórum Servidores de Rede
    Respostas: 16
    Último Post: 06-04-2005, 14:43
  4. Liberar Citrix no firewall
    Último Post: 06-01-2005, 10:51
  5. Liberar portas no firewall
    Respostas: 9
    Último Post: 08-11-2004, 17:38
