    Diogenes
    Como faço para configurar um CISCO 2600 com 4(quatro) portas seriais, a configuração que fiz o provedor só consegue exergar uma das portas.
    grt
    Vascon
    Olá pessoal
    Para facilitar a minha configuração atual é a seguinte, na verdade só umas das portas conseguir acessar, alguém poderia fazer uma analise ver se tem algum erro: São 4 portas seriais e 2 ethernet
    router#sh int f0/0
    FastEthernet0/0 is up, line protocol is up
    Hardware is AmdFE, address is 0012.80e5.45e0 (bia 0012.80e5.45e0)
    Description: *** LIGADA A PORTA X DO SWITCH Y ***
    Internet address is 10.63.0.126/25
    MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
    reliability 255/255, txload 1/255, rxload 1/255
    Encapsulation ARPA, loopback not set
    Keepalive not set
    Auto-duplex, Auto Speed, 100BaseTX/FX
    ARP type: ARPA, ARP Timeout 04:00:00
    Last input never, output 00:33:47, output hang never
    Last clearing of "show interface" counters never
    Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
    Queueing strategy: fifo
    Output queue: 0/40 (size/max)
    5 minute input rate 0 bits/sec, 0 packets/sec
    5 minute output rate 0 bits/sec, 0 packets/sec
    0 packets input, 0 bytes
    Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
    0 watchdog
    0 input packets with dribble condition detected
    2 packets output, 120 bytes, 0 underruns
    0 output errors, 0 collisions, 0 interface resets
    0 babbles, 0 late collision, 0 deferred
    2 lost carrier, 0 no carrier
    0 output buffer failures, 0 output buffers swapped out
    FastEthernet0/1 is up, line protocol is up
    Hardware is AmdFE, address is 0012.80e5.45e1 (bia 0012.80e5.45e1)
    Internet address is 10.63.0.254/25
    Keepalive not set
    Last input never, output 00:35:39, output hang never
    0 watchdog
    Serial0/0 is down, line protocol is down
    Hardware is PowerQUICC Serial
    Description: *** CIRCUITO SDR5055705 ***
    MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec,
    Encapsulation FRAME-RELAY IETF, loopback not set
    Keepalive set (10 sec)
    LMI enq sent 0, LMI stat recvd 0, LMI upd recvd 0, DTE LMI down
    LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
    LMI DLCI 0 LMI type is CCITT frame relay DTE
    Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0
    Last input never, output never, output hang never
    Last clearing of "show interface" counters 00:36:57
    0 packets input, 0 bytes, 0 no buffer
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
    0 packets output, 0 bytes, 0 underruns
    0 output errors, 0 collisions, 1 interface resets
    0 carrier transitions
    DCD=up DSR=up DTR=down RTS=down CTS=up
    Serial0/1 is down, line protocol is down
    Description: *** CIRCUITO AAA1234567 ***
    Last clearing of "show interface" counters 00:37:39
    Serial0/2 is down, line protocol is down
    Description: *** CIRCUITO AAA1234568 ***
    Last clearing of "show interface" counters 00:38:04
    Serial0/3 is down, line protocol is down
    Description: *** CIRCUITO AAA1234569 ***
    Last clearing of "show interface" counters 00:39:08
    Serial0/0.2 is down, line protocol is down
    Description: *** CONECTADA AO SITE CENTRAL ***
    Internet address is 10.63.240.2/30
    Serial0/1.2 is down, line protocol is down
    Internet address is 10.63.240.6/30
    Serial0/2.2 is down, line protocol is down
    Internet address is 10.63.240.10/30
    Serial0/3.2 is down, line protocol is down
    Internet address is 10.63.240.14/30
    router#sh flash
    System flash directory:
    File Length Name/status
    1 17725320 c2600-is-mz.123-13.bin
    [17725384 bytes used, 15829044 available, 33554428 total]
    32768K bytes of processor board System flash (Read/Write)
  1. Configuração roteador cisco 1700
    Por Denilsonluis no fórum Cisco
    Respostas: 6
    Último Post: 29-10-2011, 12:57
  2. Roteador CISCO Configuração
    Por Prime no fórum Sistemas Operacionais
    Último Post: 29-03-2010, 08:00
  3. Configuração Roteador Cisco 1721
    Por portalink no fórum Servidores de Rede
    Respostas: 6
    Último Post: 03-01-2008, 15:44
  4. QoS em Roteador Cisco 2600 Serie
    Por cebolark no fórum Redes
    Último Post: 23-02-2006, 11:47
  5. Respostas: 3
    Último Post: 19-02-2003, 16:04
