Eu uso oslackware 10.1 e não esrtou conseguindo acentuar as palavras no openoffice, eu acentuo todas as palavras nos outros aplicativos mas no open não estou conseguindo.
j[á procurei na net varias formas de ativar a acentiação no openoffice e não deu serto.
Está aqui meu arquivo /etc/profile que nãome deixa mentir.:
Código :# /etc/profile: This file contains system-wide defaults used by # all Bourne (and related) shells. # Set the values for some environment variables: export MINICOM="-c on" export MANPATH=/usr/local/man:/usr/man:/usr/X11R6/man export HOSTNAME="`cat /etc/HOSTNAME`" export LESSOPEN="|lesspipe.sh %s" export LESS="-M" export LC_ALL=pt_BR export LANG=pt_BR # If the user doesn't have a .inputrc, use the one in /etc. if [ ! -r "$HOME/.inputrc" ]; then export INPUTRC=/etc/inputrc fi # Set the default system $PATH: PATH="/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/usr/games" # For root users, ensure that /usr/local/sbin, /usr/sbin, and /sbin are in # the $PATH. Some means of connection don't add these by default (sshd comes # to mind). if [ "`id -u`" = "0" ]; then echo $PATH | grep /usr/local/sbin 1> /dev/null 2> /dev/null if [ ! $? = 0 ]; then PATH=/usr/local/sbin:/usr/sbin:/sbin:$PATH fi fi # I had problems using 'eval tset' instead of 'TERM=', but you might want to # try it anyway. I think with the right /etc/termcap it would work great. # eval `tset -sQ "$TERM"` if [ "$TERM" = "" -o "$TERM" = "unknown" ]; then TERM=linux fi # Set ksh93 visual editing mode: if [ "$SHELL" = "/bin/ksh" ]; then VISUAL=emacs # VISUAL=gmacs # VISUAL=vi fi # Set a default shell prompt: #PS1='`hostname`:`pwd`# ' if [ "$SHELL" = "/bin/pdksh" ]; then PS1='! $ ' elif [ "$SHELL" = "/bin/ksh" ]; then PS1='! ${PWD/#$HOME/~}$ ' elif [ "$SHELL" = "/bin/zsh" ]; then PS1='%n@%m:%~%# ' elif [ "$SHELL" = "/bin/ash" ]; then PS1='$ ' else PS1='\u@\h:\w\$ ' fi PS2='> ' export PATH DISPLAY LESS TERM PS1 PS2 # Default umask. A umask of 022 prevents new files from being created group # and world writable. umask 022 # Set up the LS_COLORS and LS_OPTIONS environment variables for color ls: if [ "$SHELL" = "/bin/zsh" ]; then eval `dircolors -z` elif [ "$SHELL" = "/bin/ash" ]; then eval `dircolors -s` else eval `dircolors -b` fi # Notify user of incoming mail. This can be overridden in the user's # local startup file (~/.bash.login or whatever, depending on the shell) if [ -x /usr/bin/biff ]; then biff y fi # Append any additional sh scripts found in /etc/profile.d/: for profile_script in /etc/profile.d/*.sh ; do if [ -x $profile_script ]; then . $profile_script fi done unset profile_script # For non-root users, add the current directory to the search path: if [ ! "`id -u`" = "0" ]; then PATH="$PATH:." fi [[ -f "/etc/autopackage/paths-bash" ]] && . "/etc/autopackage/paths-bash"
o meu openoffice esta instalado no diretório Raiz / será que isto influencia alguma coisa?
Abraços a todos gostariade ajuda.
Citação
